40mph, 1100rpm shudder/ buck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DHerrm, Sep 6, 2018.
  1. Sep 6, 2018 at 7:25 PM
    DHerrm
    DHerrm [OP] Well-Known Member
    Daniel
    2018 SR5
    I've got a two inch tapered Block in the rear. I have no axle wrap or shudder or anything like that on initial acceleration. Frequently though, when I am accelerating on fairly Flat Road, then I hit a slight incline, it seems to not want to downshift and I get down to about 40 miles an hour and 1100 RPMs. Unless I mash the gas usually hard to make it down shift it starts to shutter or buck. It's like the gear can't handle the incline but it doesn't want to downshift. i believe it's in 5th at that time. It's also actually the very same feeling under a very similar load that my wife's old 2009 Buick Enclave did. That was due to bad coils. I do believe I remember this happening before I put the blocks in but has anyone else noticed this and/ or do you think it's the transmission or just the blocks?
    I had a technician at my dealership ride in it and he said it was a stupid transmission. Yes that's really what he said. I'm trying to decide whether or not I want the service director to look at it for me.
    Thanks
  2. Sep 6, 2018 at 7:27 PM
    DHerrm
    Daniel
    2018 SR5
    It's still got the original tires.
  3. Sep 6, 2018 at 10:06 PM
    AffordBrad
    AffordBrad Active Member
    Brad
    Fredericksburg VA
    2018 super white Tacoma TRD PRO, 1997 SR5 EXCAB 4x4 Tacoma camo wrapped
    I believe it has to do with the transmission as well or the torque converter in the trans, but we will see. And if I find out me info I will post on here.
    DHerrm[QUOTED][OP] likes this.
  4. Sep 7, 2018 at 6:11 AM
    DHerrm
    Daniel
    2018 SR5
    I had the service director drive it this morning. He made the shudder happen for himself, but not the buck. I am not sure how the buck happened as it's only happened one time.
    He said there has been a lot of unhappiness with the gen 3 engine and transmission computers and this is one of the issues. He mentioned that the torque converters on gen 3s "lock up" in either 2nd or 3rd gear, where as older ones didn't lock up until top gear, for fuel economy. I'm not too familiar with torque converters and didn't understand what that meant. He said, "I'd never suggest that you need to change your driving style, but IF you were to, do you think this wouldn't be an issue." I said yes for the most part. The normal shudder I feel I know when it's coming and as long as I mash the gas much harder than I am inclined to, it will downshift. So he basically said I would never suggest you need to, but I am suggesting you need to. As I expected, there's nothing working incorrectly here. He's seen this many times and there are a lot of people not happy with the driveability of the gen 3.
    I got a similar explanation from GM of "it's working as designed" on a truck I recently completed a Lemon buy back on. Saying that makes me feel like I am being overly picky.... again......
  5. Oct 28, 2018 at 2:58 PM
    jp5
    jp5 *jp5parkles*
    JP
    AZ
    '16 DCSB TRD sport
    same thing is happening to me on my 2106 2wd at 72k, never once have I felt it before. It does only happen when im limited by people doing the speed limit in my tiny town and Im more calmly driving. It is still scaring the shit out of me though as the shuddering cant be good at all for the drive line components. Has anyone figured anything out?
  6. Oct 28, 2018 at 3:27 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Tsb 58 or tsb 62. Works for me
  7. Oct 29, 2018 at 6:49 AM
    DHerrm
    Daniel
    2018 SR5
    I have the update. It didn't do anything for me. I still have the EXACT issue in 58 as well. Surges 40-50mph. The Toyota tech (not a dealership tech) said that there is nothing wrong with my truck. It still shakes/bucks in just about every gear now. He mentioned the driveline angle but said that was NOT causing this (as I would expect because it was doing it prior to the rear lift).
  8. Oct 29, 2018 at 9:31 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    It wouldn't hurt to fix your angles. I'm not sure if the TSB fixed my truck or I just learned how the gas pedal works but my truck doesn't buck or anything of the sort.
  9. Oct 29, 2018 at 9:38 AM
    DHerrm
    Daniel
    2018 SR5
    It's got a 2" block. I have the angle somewhere and it's like 1* off. Either way, the Toyota tech said that wasn't causing the problem in addition to the fact that I was having the problem before the block.
  10. Oct 29, 2018 at 9:53 AM
    EF
    EF Well-Known Member
    Upstate NY
    2015 TRD Off Road Blue Ribbon
    Not that it compares 100%, but my 2015 exhibits this exact thing. Has done it for some time, but not the entire 50k miles. Another guy online said he got his trans flushed and refilled and it solved it. I am at 50k and am going to try it.
    It seems to be related to the torque converter and the very low RPM’s while under slight load like up a gentle incline that needs little effort.
    If you think about it, its like when a manual stays in gear all the way down to a low RPM. I think the converter is locked up at this time and behaves much like a manual. The isolated bang you heard could have been the converter locking unlocking in a strange situation.
    Would be helpful to know mileage on the vehicles affected and if they tow heavier loads. I have 50k and tow 4,700lbs occasionally.
  11. Oct 29, 2018 at 10:06 AM
    TRD_INFERNO
    TRD_INFERNO Well-Known Member
    INFERNO 2017 TRD OFF ROAD 4X4
    Transmission update helped me, but it will still bog down sometimes if I am going up a hill and it doesn't downshift. Just give it a little more gas and mine downshifts like it should. The transmission update made a world of difference
  12. Oct 29, 2018 at 10:26 AM
    DHerrm
    Daniel
    2018 SR5
    Mine started within 2,000 miles. It may have been at first but my wife drove it the first 2,000 miles. I've towed 5,000lbs once. Otherwise I a tow a small boat that might be about 500lbs with the trailer.
    They say it is due to TC lock up. The service manager at my dealership, a big dealership at that, says that "it is designed to shake the whole truck rather than downshift." I really hope he doesn't believe that. I can get it to downshift if I make it a point to push the pedal half way to the floor but I just don't drive like that. I hit that bad spot every single time I drive it.
    I hit the surges much less often but the surge is much more clearly the exact issue in TSB 58. I have the update and I am still surging. They can't tell me that it's supposed to surge because they already have a "repair" for it. You don't repair something that is working exactly how it's supposed to.
    A transmission flush might fix it. I have no idea. Toyota decided that nothing needed to be done to it. I'm waiting on them to respond to another letter about it.
  13. Oct 29, 2018 at 12:40 PM
    VaToy
    Parts Unknown
    I have about 3k miles on my tsb58 and the little bit of shaking I experienced is gone. Haven't heard many saying it returns,but some that have it come back disconnect the battery for 30 min .
  14. Oct 29, 2018 at 12:42 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Get ovtune and flash your ecu. Easy fix
  15. Oct 29, 2018 at 12:45 PM
    DHerrm
    Daniel
    2018 SR5
    I paid Toyota for a truck that worked right to begin with and I buy new so I don't have to do this kind of stuff myself. I'll keep pressing them to make it right.
  16. Jan 7, 2019 at 6:17 AM
    DHerrm
    Daniel
    2018 SR5
    This is still happening.
    Can anyone tell me if they have surges in power 40-50mph while under hard acceleration? I have the computer updates but this is still happening for me. It would normally up shift at 40mph or at 45mph but if I'm on the gas hard enough to keep the gear, I get surges of power at 40, 45 and again at 50mph. Anyone??
  17. Jan 7, 2019 at 6:51 AM
    rlc177
    rlc177 Well-Known Member
    The TSB for the 40-50 mph surge was a surge where the truck would stop accelerating when shifting with an almost felt like its in neutral for a second or two (Due to some TC lock behavior). However the engine has a surge of power at about the same speed during hard acceleration due to the ACIS intake mechanics, this however is not addressed by the TSB. They are similar behavior but different things. Can't really explain it by typing. The TSB fixed the jerky shift that occurred at that speed but not the ACIS surge in engine power. The issue is the TSB wording for all these problems is bad and I wish they would release a new TSB that just says something general rather than specific tiny patches.
  18. Jan 7, 2019 at 7:00 AM
    DHerrm
    Daniel
    2018 SR5
    I see. I definitely still have a surge. Now it's also shaking at idle. My engine has a lot of rattling at idle as well.
  19. Jul 6, 2024 at 1:39 PM
    AMGEUZE
    AMGEUZE Member
    I have a 2022 Toyota Tacoma XP V6 4x4, and mine has been in the shop for a week. First time they reset the TCM and now back again. 2nd round, resetting the TCM, and have to go back after 500 miles. Hope this helps, but was told that the help desk will compare the data and proceed from there. Don't know if this helps but your not alone in this.
  20. Jul 21, 2024 at 6:32 AM
    JHK
    JHK Active Member
    2023 Toyota Tacoma OR DCLB
    Stock
    Any updates on this issue? I am experiencing the same thing. I’m going to try lube guard and see if it helps. Verified fluid level. 2023 OR.
