"40's & 50's" Midlife crisis/GTFO my lawn thread.
Discussion in 'Off-Topic Discussion' started by Matic, Jun 18, 2011.
  1. Jul 16, 2018 at 1:15 PM
    Matic
    Matic [OP] The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Where is that? It seems I pass the sign on the way up home. Am I wrong?
    robssol and MQQSE like this.
  2. Jul 16, 2018 at 1:16 PM
    Matic
    Tricky Dick
    Easley, SC
    :wave: DICK!!!!!
    scocar and DoorDing like this.
  3. Jul 16, 2018 at 2:13 PM
    VE7OSR
    VE7OSR Well-Known Member
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Last nite's messing with Darwin. pics below, At this 200' waterfall, in the winter when its cold enough the water fall becomes an ice cone, and several rock weeps also freeze up, and you can ice climb in there. Access is down a crazy traverse of the steep canyon wall, so sometimes the quicker access in the winter it to rappel in from the top. The rope was left behind still anchored from 2 winters ago, so now some folks in the summer that go into the base of the water fall think this rope makes a really exciting swing to climb up on a boulder, swing out on the rope over or through the water fall to the other side. Challenge is at one point in the middle, you are 35' off the deck. Darwin decided that would be a great place to slip off the now weathered rope that has lost its protective mantel cover. dude falls down onto the rockfall below. Of course this happens in the evening, and to have his buddy get a call out for help is a 20 minute hike back up to the top of the canyon, and back to a car, then a crazy drive down logging roads for 16 miles to where a cell phone call can be made.
    We called in 442 squadron (Marine and Aeronautical military SAR), from Vancouver island to hoist the poor fellow out. Next best option was to wait until daylight (04:30) and fly him out by HETs (dope on a rope). The 3rd option was the rope rescue up the waterfall, and hump out throught the bush over the windfalls, and that wouldn't be so good for the fellow given his injuries.
    The Cormorant helicopter was hovering below the top of the waterfall. The rotor wash sucked the water fall away from the wall into the rotors, so the folks below were in a mini hurricane. It had to hover that low because at the top of the waterfall plateau is a forest of widow makers, - a stand of burnt trees, and his rotor wash could start knocking trees down.
    waterfall in the summer.
    Hoisting Operation.
    top of the canyon scramble, rope team, paramedics, and two bystanders coming back up after all is done. Me in the yellow, as the RIT team lead, available to grab any materials up the steeper part of the trail.
    robssol, MQQSE, G.T. and 3 others like this.
  4. Jul 16, 2018 at 2:19 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB, '97 4Runner SR5 5spd
    I certainly hope there is a stupid tax applied when shit like this happens.
  5. Jul 16, 2018 at 2:22 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    No, and as the responders we don't want that. We do get that response often though.
    So if you are a visitor to Canada, even from the US, and end up doing something silly, where you get hurt, we come and get you out of the pickle you are in by all the available resources necessary, and do so with no charge to you.
    robu, MQQSE and DoorDing like this.
  6. Jul 16, 2018 at 2:24 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    A "This is what this SHOULD cost you" letter would be a nice touch, but then that becomes bragging material.
    i guess i'm just too used to dealing with the low level idiots in what i do
  7. Jul 16, 2018 at 2:25 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    We kinda gave the bystanders shit for swinging on questionable rope, that they had no idea how well it was anchored. Even the existing handlines traversing the slope of the canyon are in very bad shape. We brought our own, and did not leave them behind. I suspect there maybe a clandestine operation to remove the crappy stuff in the very near future.
    G.T. likes this.
  8. Jul 16, 2018 at 2:31 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    Was the rope he was swinging a static rope or dynamic rope left over from the winter? Not that it matters I suppose but either way the rope was going to give at some point do to excessive use, dust and debris caught in the rope fibers, torn fibers from the rocks themselves, and uv exposure.
    I've got to say that looks like a very skilled helicopter pilot that had to fly in danger close quarters. Sounds like one hell of a rescue and it looks like you guys did a great job in horrible conditions. Well done my friend!
    DoorDing and VE7OSR like this.
  9. Jul 16, 2018 at 2:39 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    There were two bystanders that stayed with the subject, and did their job well, with no real knowledge, and moved the fellow out of the cold water, despite his injuries, and his screaming. That was a positive outcome move. The rescue crew down below took care of the bystanders and also give them little jobs to do to keep them busy, and in sight. The other two bystanders, that went for help, now at the topside, decided to try and come back in while the operation was underway. They BS'd me that they received permission to hike back in. I ignored the obvious lie, and respected their wishes to be closer to their friend but firmly denied them further progress back into the scene on the basis that such action created a hazard, especially when the helicopter arrives. Explained that I was being bossy, because we're now responsible for their well being as well as the folks down below. They co-operated, and explained to them the steps taking place to get their friend out, to make them feel a part of what is going on. I get their emotional involvement, and not going to be too much of a dick to them. They were escorted back out by a team of two to the parking lot when they were getting cold.
    robssol, MQQSE and DoorDing like this.
  10. Jul 16, 2018 at 2:45 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Dynamic - climber folks that set the ropes in place, though considering the mantle was shredded and the amount of times its been swung on, a lot of the twist in the strands has likely been stretched out. That helicopter is big..same one in my sig. Worked with them before on another call that they flew right down into a canyon at night. We were working on setting up the ground side operation should the air operation not be succeed and had to kill our headlamps, and stay still so no one dropped anything down into the canyon below us. Last night, those of us at the canyon rim pulled back away so we were not at risk of windfall.
    Video
    https://globalnews.ca/news/4334145/...-man/?utm_medium=Facebook&utm_source=GlobalBC
    robssol and DoorDing like this.
  11. Jul 16, 2018 at 2:55 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    but why not?? your buddy just did, and told all his friends on social media.
    wilcam47 and DoorDing like this.
  12. Jul 16, 2018 at 2:56 PM
    RearViewMirror
    Craig Christ
    You sometimes wish there was such thing as a stupid tax but there isn't most anywhere in the nation that I'm aware of. That is your tax dollars at work that fund the FD to show up for rescues, house fires, etc... The only extra charge on our FD was excessive false fire alarms to the same location. IIRC if more than five false alarms were dispatched to certain businesses than a fine would be levied for each additional false alarm. Other than that... this is your tax dollars at work.
    robssol, MQQSE, VE7OSR and 2 others like this.
  13. Jul 16, 2018 at 3:19 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Our concern is folks will delay asking for help, if they think its going to cost money, or resolve the circumstance themselves, potentially causing further harm to people, and yes I've heard the pros & cons to both sides of the debate. Truth is we've all done dumb shit that in hindsight we think better of and thank our lucky stars, or guardian angels that 90% of the time, nothing bad happened. As responders, we don't base our response on how stupid we think the person's choices were; they are just folks that need attention now.
    Bastek, sandjunkie, MQQSE and 4 others like this.
  14. Jul 16, 2018 at 3:24 PM
    RearViewMirror
    Craig Christ
    You're right about that. Of all the stupid shit that I've done I'm surprised that I've lived to this age.
  15. Jul 16, 2018 at 4:33 PM
    G.T.
    G.T.
    CONUS
    A couple of complimentary snacks could go a long way.
  16. Jul 16, 2018 at 4:41 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Brownies and clean water?
    G.T. likes this.
  17. Jul 16, 2018 at 5:01 PM
    wilcam47
    wilcam47 Well-Known Member
    Arizona now!!!
    RearViewMirror likes this.
  18. Jul 16, 2018 at 5:13 PM
    G.T.
    G.T.
    CONUS
    Complimentary smacks...
    Duck you autocorrect.
    But I’m game to check out the brownies.
  19. Jul 16, 2018 at 5:53 PM
    RearViewMirror
    Craig Christ
    X2 for the "brownies" ;)
  20. Jul 16, 2018 at 6:31 PM
    MQQSE
    MQQSE Chief Pal Guy
    Rob III
    Palmer, Alaska
    Cav Blu '19 DCSB OR MT
    In for brownies...:hungry:
    Thank you for the amazing work and sacrifices ... “That Others May Live.” Rob
    VE7OSR likes this.
