"40's & 50's" Midlife crisis/GTFO my lawn thread.
Discussion in 'Off-Topic Discussion' started by Matic, Jun 18, 2011.
  1. Sep 14, 2019 at 9:42 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    My advice (even though you didn't ask for it) is if you can still pay all your bills and live a comfortable lifestyle I'd say go for it. You only live once and might as well do something that you love and get paid for it in the process.
    VE7OSR and shane100700 like this.
  2. Sep 14, 2019 at 9:45 AM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB 2019 TRD PRO 4runner
    You’ll never work a day in your life if you’re doing something you love to do.
    Hardscrabble and shane100700 like this.
  3. Sep 14, 2019 at 9:47 AM
    medic2230
    Murph
    Bama! Roll Tide
    That’s because I know you enjoy the finer things in life.
    Also because Brittfarticus. :anonymous:
    You have your need and I gave you the solution. For the record I also gave a affordable solution also. :D
    Or do what the pros do and have a dedicated rig that does exactly what you desire in both separately.
    RearViewMirror likes this.
  4. Sep 14, 2019 at 11:35 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    This^.
    If it covers bills and think you’ll love it... why the hell not. I’m assuming the plan would be for the boat to travel around, free world visits sounds good to me!!
  5. Sep 14, 2019 at 11:41 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    It would be out of here. Bahamas if someone wants but his goal is to have 5 or 6 so eventually I would be like the GM running all of them.
    shane100700 likes this.
  6. Sep 14, 2019 at 11:58 AM
    RearViewMirror
    Craig Christ
    Superglue is the dumbest invention ever created. The only thing it is good for is sticking your fingers together. Fuck superglue
    / rant
    98tacoma27, wilcam47 and shane100700 like this.
  7. Sep 14, 2019 at 12:01 PM
    VE7OSR
    VE7OSR Well-Known Member
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    @Pchop I see you have a storm headed your way, the numbered kind you don't worry about too much, but still looks like ti could give you a bit of a lashing.
  8. Sep 14, 2019 at 12:05 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    what about tie wraps? :spy: for the record in my past work, hated tie wraps that were not cut properly so they leave no sharp end. They are quick & handy, but for telecom work we still use string. Takes less space, can really get bundles tight together, and is an artform when done properly.
  9. Sep 14, 2019 at 12:34 PM
    medic2230
    Murph
    Bama! Roll Tide
    Do instruct us how oh great master of telecom.
  10. Sep 14, 2019 at 12:35 PM
    medic2230
    Murph
    Bama! Roll Tide
    I’m sure some scissors and zip ties would be able to get your fingers apart. :cool:
  11. Sep 14, 2019 at 12:38 PM
    wilcam47
    wilcam47 Well-Known Member
    Will
    Arizona now!!!
    what you trying to glue??other than your fingers..??;)
  12. Sep 14, 2019 at 12:39 PM
    RearViewMirror
    Craig Christ
    A tie wrap on a broken stone coaster to sit your drink on wouldn't be ideal. I've not found one single thing that superglue is good for except, as mentioned before, sticking your fingers together or closing a cut on your finger lol. It excels at those two things.
  13. Sep 14, 2019 at 12:39 PM
    RearViewMirror
    Craig Christ
    And a trip to the ER (again) :oops:
    medic2230 likes this.
  14. Sep 14, 2019 at 12:49 PM
    medic2230
    Murph
    Bama! Roll Tide
    I use to use contact cement when I’d cut my hand installing Formica.
  15. Sep 14, 2019 at 12:55 PM
    RearViewMirror
    Craig Christ
    A coaster that my daughter accidentally dropped. I've let it sit for 24 hrs and I can literally break it apart with little to no effort. I've tried almost every brand available and none work.
    wilcam47 likes this.
  16. Sep 14, 2019 at 1:03 PM
    wilcam47
    Will
    Arizona now!!!
    Id say epoxy
    CXYyuppie and medic2230 like this.
  17. Sep 14, 2019 at 1:12 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    https://www.youtube.com/watch?v=4iU8sYRG9-I
    https://www.youtube.com/watch?v=McqCUfw7AYU
    just search telecom cable lacing, or cable stitching.
    here is the type of string that is used, - waxed, polyester string.
    https://www.amazon.com/WAXED-LACING-POLYESTER-TENSILE-STRENGTH/dp/B00IYOW2ZU
    and look up cable dressing - you can get 'combs' to deal with untangling bundles, but your five fingers work just as easily.
    wilcam47, medic2230 and CXYyuppie like this.
  18. Sep 14, 2019 at 1:41 PM
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    Never heard that one before, but I'm not in that industry. Kind of like crackhead dental floss huh?
  19. Sep 14, 2019 at 1:56 PM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Its kinda nasty if you work with it all day. The wax dries your skin out, and pulling the string tight digs into the inside folds of your fingers. There are stitching tools we use to sneak the thread through tight spaces.
    https://tecratools.com/pages/telecom/cable_tools.html
    Fiber cables are easier, but much more delicate at times - no string or zap straps allowed - use Velcro, and trays to store slack. Scissors still involved though. A riser cable with bundles of fibers is protected by a fiberglass rod to limit the bend radius and Kevlar strands to protect against abrasion. Those Kevlar strands are nasty to work with as well, kinda like fiberglass wool.
    wdb, medic2230 and CXYyuppie like this.
  20. Sep 14, 2019 at 2:01 PM
    CXYyuppie
    Craig
    SE.LA
    So, could this be used to tidy-up the wiring in the attic of a house before reinsulating? Planning on adding some blown fiberglass this winter. I would rather have everything in cable tray, but that's a bit expensive. I also don't want a fire hazard. Thanks in advance for the info.
