"40's & 50's" Midlife crisis/GTFO my lawn thread.
Discussion in 'Off-Topic Discussion' started by Matic, Jun 18, 2011.
  1. Sep 16, 2019 at 1:20 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '15 DCLB S/C 4x4 Limited Pyrite Mica
    :anonymous:
    VE7OSR likes this.
  2. Sep 16, 2019 at 2:19 PM
    VE7OSR
    VE7OSR 'interfering with Natural Selection since 1990'
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    If you have Windows 8 and up, there is a Windows utility called the Snipping tool, which allows you to select what part of your screen you want to save as an image. Then you can print that image.
  3. Sep 16, 2019 at 3:02 PM
    wilcam47
    wilcam47 Well-Known Member
    North Idaho
    easy now...
    MQQSE and rmepilot like this.
  4. Sep 16, 2019 at 3:52 PM
    shane100700
    shane100700 Retired, now a stay at home husband!
    Montana
    2019 DCSB, OR
    Rocket Boosters
  5. Sep 16, 2019 at 3:58 PM
    JasonArizona
    JasonArizona Well-Known Member
    Tucson
    2014 TRD
    Windows Key + Shift + S -> Directly to the clipboard. Paste anywhere.
    Wizardry.
  6. Sep 16, 2019 at 4:07 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    wilcam47 likes this.
  7. Sep 16, 2019 at 4:38 PM
    rmepilot
    Rob
    Huntsville, AL
    He’s in denial...
  8. Sep 16, 2019 at 6:09 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    The last time was with Loctite superglue. Didn't work. Tried Gorilla glue and that was shit also. I've come to realize that there is no superglue that works on anything but skin.
    Tried that also. That actually came closer to making it stick.
    shane100700, CXYyuppie and wilcam47 like this.
  9. Sep 16, 2019 at 6:56 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    CA won't cut it. You need a 5 minute epoxy.
    ITW Consumer/Devcon 20845 High Strength 5-Minute Epoxy with 25mL Syringe, Begins to Harden in 8 to 10 Minutes, 0.84 oz Syringe, Clear (Pack of 6) https://www.amazon.com/dp/B00GRTERC0/ref=cm_sw_r_cp_apa_i_F0dGDbTNSEV5J
    wilcam47, shane100700, Pchop and 2 others like this.
  10. Sep 16, 2019 at 7:06 PM
    RearViewMirror
    Craig Christ
    I'll try that. Why is superglue even on the market if it won't hold ANYTHING together?
  11. Sep 16, 2019 at 7:11 PM
    98tacoma27
    Ben
    Beech Creek
    It's original purpose was for skin. It's great for plastics, especially acrylics since it is one.
    The moisture in your skin is what causes the instant bond.
  12. Sep 16, 2019 at 8:18 PM
    RearViewMirror
    Craig Christ
    I had always heard (don't know if this is true or not) but glue like this was created for closing wounds in a battleground situation? I could be completely mistaken on this though. I just know it sucks for most everything else.
  13. Sep 16, 2019 at 10:35 PM
    MQQSE
    MQQSE GOB
    Chief Pal Guy
    Palmer, Alaska
    "Stitch"
    :anonymous:
    exactly
    PM update to follow.
  14. Sep 17, 2019 at 5:12 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    :notsure:
  15. Sep 17, 2019 at 5:14 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  16. Sep 17, 2019 at 5:36 AM
    rmepilot
    Rob
    Huntsville, AL
    98tacoma27 likes this.
  17. Sep 17, 2019 at 6:50 AM
    MQQSE
    MQQSE GOB
    Chief Pal Guy
    Palmer, Alaska
    "Stitch"
    wilcam47 and Soul Surfer like this.
  18. Sep 17, 2019 at 6:58 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, CVT Mt. Bachelor, Uniden 520XL, WeatherTechs, TRD CAI, 1Up USA hitch rack, speaker upgrade, Total Chaos bed stiffeners
    That's a big hog!
    CA glue doesn't work on all plastics, especially the kind used in car interiors. I had a busted piece of trim once, and it just laughed at the CA glue. As usual, it got my fingers pretty good though.
    It would be nice if someone published a guide of the best adhesives to use for various materials. If you believe the marketing, all glues work awesome on all surfaces. I stick to epoxies on important stuff, but you always seem to waste so much.
  19. Sep 17, 2019 at 7:25 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Think thats a Tennessee thing :notsure:
    Right? I'm actually shocked one or more of his dogs didnt get killed. Those cutters are no fucking joke.
    Bet they had those bullet proof vests guys put on them to protect them from getting stuck.
  20. Sep 17, 2019 at 7:31 AM
    RearViewMirror
    Craig Christ
    Speaking of bullet proof vest for dogs... Any of you guys see the last John Wick movie? Very seldom does a movie come along and the sequels just get better and better. The dog scene was incredible.
    Crikeymike and wilcam47 like this.
