40x60 shop
Discussion in 'Garage / Workshop' started by 95 taco, Feb 25, 2016.
  1. Feb 26, 2016 at 12:04 PM
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    The initial build budget (slab, exterior walls, and roofing) is up to 15K.
    All we will hire done will be the slab, everything else we will be doing ourselves.
  2. Feb 26, 2016 at 1:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How much is concrete / yard delivered in your area ?
  3. Feb 26, 2016 at 2:45 PM
    95 taco
    Last I checked it was a little under $100/Cubic yard.
    We're estimating 45 Cubic yards for the slab (6" thick).
    Elevated likes this.
  4. Feb 26, 2016 at 2:50 PM
    OZ-T
    Peter North
    British Columbia
    You should consider going with a 32 mpa mix if you are going to put heavy vehicles / equipment in it . Thats code here anyway . Your concrete cost is about the same as here when you factor in currency exchange
  5. Feb 26, 2016 at 2:54 PM
    95 taco
    We're planning on asking the guys at the plant what they would recommend, but we will likely go with the 32 MPa.
  6. Feb 26, 2016 at 2:58 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    What's your plans for heat/cool? You said you're down here in the south so heat isn't a major concern but that generally means cool is... There are some pretty slick thermal heating setups that once built are basically maintenance free and their only cost is the build, I imagine there are similar ones for cooling but haven't looked into those very much yet.
  7. Feb 26, 2016 at 3:01 PM
    95 taco
    As of right now swamp coolers and fans for the main shop, and if we do an office then likely a window AC unit.
    But we are going to look into a detailed cost of the slab heating and cooling system that OZ recommended.
  8. Feb 26, 2016 at 3:04 PM
    OZ-T
    Peter North
    British Columbia
    Well double check your pricing cause as the mpa goes up so does the cost per yard
  9. Feb 26, 2016 at 3:05 PM
    95 taco
    Will do :thumbsup:
  10. Feb 26, 2016 at 3:08 PM
    OZ-T
    Peter North
    British Columbia
    Check these guys out , their open direct system is a lower cost way to go
    http://www.radiantec.com/systems-sources/open-system.php
  11. Feb 26, 2016 at 3:15 PM
    Clearwater Bill
    Billy
    Largo Florida
  12. Feb 26, 2016 at 3:20 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Don't forget to put pulling anchors in the concrete. Foam under the slab. This will prevent the slab from sweating during rapid changes in temp and humidity.
    If you are indeed in the south, radiant tube is really not that big of a benefit. I have it and it is awesome, but its cold here 1/3 of the year. Radiant tube heater in ceiling are a great way for instant heat. With in-floor heat, the boiler has to be running all the time. that means that you are burning gas when you are not there.
    You really only need a 100 amp service for this building. All those tools can't run at the same time. I have my 240 plasma cutter, compressor and welder all on one circuit.
    I think you are going to rapidly eat up the square feet with the big items in there. Consider a smaller structure with an unheated lean-to area for the stuff that doesn't need to stay warm.
    With 16' ceilings, think about a work shop area under a loft type storage area. You will be acquiring more items as you get older.
    These are just some things I can think of quickly.
  13. Feb 26, 2016 at 3:22 PM
    OZ-T
    Peter North
    British Columbia
    Check out the Radiantec open direct system I linked , you don't need a traditional boiler
  14. Feb 26, 2016 at 3:23 PM
    Styx2015
    Styx2015 Well-Known Member
    Paul
    2008 White Tacoma DCSB TRD Off Road
    Refrigerator an absolute must as well. Can't forget the cold ones.
  15. Feb 26, 2016 at 5:00 PM
    #35
    Elevated
    Elevated Well-Known Member
    Sergey
    Tracy, CA
    97 Tacoma Extended Cab. 3.4L
    Original Tacoma: 6" lift, air bags in the rear, 17x9.5 XD Series rims w/ 35" Cooper STT Pro tires. Body Armor rear bumper with swing arm tire mount, TRD Exhaust, URD True Cold Air intake, TRD Front Brakes, RIGID INDUSTRIES grill and LED bar installed in it, LED Rear Lights, TracRack rack system, tool box. Sold the truck. Bought 2016 ram 2500 Laramie diesel. (7/2016) Picked up 97 Tacoma 4x4 Extended Cab 3.4L. Building motor now. (8/2017)
    FYI that's a two pack for 59.99.. In my Costco, they are $22 because of PGE rebate.. That being said, $30/light is still cheaper than Home Depot.
    I would go into your local Costco and see if they have them. I also buy all the LED can light trims. They are $24 or so for a two pack.. Way cheaper than Home Depot..
  16. Feb 26, 2016 at 5:25 PM
    #36
    koditten
    Kirk
    Central Michigan
    For that big of a structure, a boiler will almost have to be required.
    Regardless, I don't see you heating this big of a building 24/7. Radiant does not respond to quick temp changes. I turn mine on in November and turn it off in April.
  17. Feb 26, 2016 at 7:21 PM
    #37
    OZ-T
    Peter North
    British Columbia
    Nope , my house is run on a 38 gal HWT , my dad built a mini storage building as big as the OP's building and it runs on a HWT too , my electrical contractors shop is 30 x 40 also run on a small HWT , all are low cost solutions because once at temperature the thermal mass of the slab will store the heat energy , none of them are the open direct system that I linked from Radiantec because here we have limited use for summer cooling but thats the system I would use if I desired cooling as well as heated at a relatively low cost .
  18. Feb 26, 2016 at 7:31 PM
    #38
    koditten
    Kirk
    Central Michigan
    I'm pretty sure open loop systems are not allowed in the states. Heating water and domestic water must be completely separate. Maybe I missed it, is a heat exchanger used on that system to separate the 2?
  19. Feb 26, 2016 at 7:36 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Radiantec is a US company , and the tubing you use is rated for potable water , they have a code compliancy section on their website if you're interested , no heat exchanger in that system , the slab loops are essentially external capacity of the domestic hot water tank
