****42 DRAFT DESIGNS OIL CATCH CAN GROUP BUY****
Discussion in 'Group Buys' started by Justus, Jun 27, 2013.
Thread Status:
Not open for further replies.
  1. Jun 27, 2013 at 1:28 PM
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Alright folks, here we go.... This group buy will be for the 42 Draft Designs Oil Catch cans.
    group buy is now closed, thank you for playing
    This will include these models:
    • ULTIMATE CATCH CAN
    • STEALTH CATCH CAN
    BOTH CATCH CANS WILL BE AVAILABLE WITH 1/2" NPT FEMALE BUNGS (BEST FOR A CLEAN LOOK) OR A 3/4" BEAD ROLLED INLET/OUTLET.
    • MSRP $250 for Ultimate Oil Catch Can with 1/2" NPT
    • MSRP $145 for Stealth Oil Catch Can with 1/2" NPT
    • MSRP $235 for Ultimate Oil Catch Can with 3/4" bead rolled in/outlets
    • MSRP $130 for Stealth Oil Catch Can with 3/4" bead rolled in/outlets
    Discount info:
    10 OF EITHER THE ULTIMATE OR STEALTH catch cans minimum for a group buy discount on that model. After the initial 10 of each, we can combine the numbers. We need at least ten of each to process the order tho.
    10 catch cans minimum of each model= 10% discount
    15 catch cans = 15% discount
    25 catch cans = 20% discount
    This means we can have 15 stealths and 10 ultimates for a total of 20% off of both items since we met our 25 order TOTAL quota. But remember....we need that initial ten pieces of stealth and ten of ultimate
    Flat rate shipping of $12.35 to most places in the U.S.
    also available (no discount due to cost) is the quick drain kit here http://store.42draftdesigns.com/Catch-Can-Quick-Drain-Kit_p_325.html
    which runs $14.00 and comes with:
    Quick Drain Fitting
    3/8" ID Drain Tubing (36")
    Zip-Ties
    OR, just the quick drain valve for (again no discount) $8.00
    http://store.42draftdesigns.com/Catch-Can-Quick-Drain-Fitting_p_324.html
    You will need to send me NO MONEY....but I will need:
    • YOUR USERNAME
    • YOUR EMAIL ADDRESS
    • WHAT MODEL (STEALTH OR ULTIMATE) AND (1/2" NPT OR 3/4" INLET)
    • IF YOU WANT A QUICK DRAIN VALVE, QUICK DRAIN VALVE KIT OR NEITHER
    PLEASE SEND THIS INFO TO THIS EMAIL ADDY catch_can@yahoo.com
    This information will be sent to the supplier Saturday July 27th at 12am Pacific in a batch file. The supplier will then be in touch with you via email and send you each a PayPal direct invoice which accepts any major credit card or PayPal account balance.
    Remember, I need your info before that date.... the sooner the better. You wont be charged anything and wont even get an invoice till after the 27th because I will be submitting it all at that time, no sooner.
  2. Jun 27, 2013 at 1:29 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I have 1 ultimate and 1 stealth for picture purposes only
    ultimate is brushed finish and has the 3/4 fittings
    the stealth is black powder coated, (this finish won't be available in group buy) and has the 1/2" NPT fittings
    Here I have installed 2 fittings on the stealth...... I got them at a local hardware store.
    Not pictured is the 2 CNC machined mounting brackets for the ultimate can
    more info can be found here
    http://www.tacomaworld.com/forum/gr...-designs-oil-catch-cans-group-buy-feeler.html
    or manufacturer direct here
    http://store.42draftdesigns.com/Oil-Catch-Cans_c_71.html
  3. Jun 27, 2013 at 1:29 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    reserved just in case
  4. Jun 27, 2013 at 1:42 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    just so we can keep track of people.....
    Ill update a list in this post as I get emails
    Ultimate catch can buyers:
    1. Torspd
    2. nfs257
    3. Kh7nm
    4. Luka
    5. Luka
    6. Dravyss
    7. BrokenTusk
    8. BrokenTusk
    9. BrokenTusk
    10. NICK54
    11. NUT
    12. BRODEY26
    13. .
    14. .
    15. .
    16. .
    17. .
    18. .
    19. .
    Stealth catch can buyers:
    1. BradyT88
    2. armyoffoo
    3. armyoffoo
    4. MY50cal
    5. Frogsauce
    6. trusso24
    7. pavemobile
    8. CrackerJackMack
    9. mattgecko
    10. Biscuits
    11. Tuctaco
    12. WailuaTaco808
    13. QuadrupleEncore
    14. lawless
    15. BBOB
    16. TELUM01
    17. TELUM01
    18. TELUM01
    19. JSTABB
    20. .
    21. .
    22. .
    23. .
    24. .
    25. .
  5. Jun 27, 2013 at 2:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Torspd - Ultimate, 1/2" NPT (unless for some reason the Ultimate only comes with one fitting choice?) . No quick drain.
    I will email as well.
    Great Scott! Good Job sir. :thumbsup:
  6. Jun 27, 2013 at 2:06 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    ultimate and stealth come with both options of 1/2" NPT bung or the 3/4" barb type.
    I just didnt wanna have 4 catch cans in hand and be out more money just for pictures :)
    thank you Sir!
  7. Jun 27, 2013 at 2:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Well then! With the 1/2" NPT then. That way I can install AN fittings. :D Makes hose routing easier. :thumbsup:
    Otherwise I would buy that sexy Ultimate from you.
    Edit**** completely overlooked the mention that both can are available with both fitting choices. Doh.
  8. Jun 27, 2013 at 2:10 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Put me down for a stealth with the 1/2" NPT and the quick drain valve (not the kit, just the valve).
    Thanks man!!
    Email sent!!
  9. Jun 27, 2013 at 2:23 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    Silver 2012 DCSB 4x4 V6
    TRD SC, URD 2.8" pulley, NST Pulleys, Cometic Headgaskets, ARP Head studs, rod bolts, flex plate bolts, header studs, CP Pistons, Molnar Rods, Clevite Bearings, APR Exhaust cam gears, 170* thermostat, URD TCAI, DTLT Headers, URD Y Pipe, URD MK2 Catback exhaust, URD Fuel Pump upgrade, Fuelab Fuel filter, AEM Adjustable FPR, AEM Datalogger with AFR, Boost, Fuel Press, Oil Press, Oil Temp, Trans Press, Trans Temp, Coolant Temp Sensors, TR Drop Kit, StopTech BBK, TR Disc Conv, Stainless braided brake lines, -6AN Stainless braided Fuel lines from rail to tank, -6AN Stainless braided transmission cooler lines w/Earls Cooler, Stainless braided Powersteering lines w/Custom reservoir
    Email sent for 2 x 1/2" stealths with 2 x quick drain valves. Thanks for setting this up!
  10. Jun 27, 2013 at 2:37 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Sub'd for some epic cans.
  11. Jun 27, 2013 at 2:38 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    In for ultimate 1/2" NPT and Drain kit. Will send email tonight while bored on Duty.
  12. Jun 27, 2013 at 2:47 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    email sent FTMFWMF
  13. Jun 27, 2013 at 3:01 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Thank you
    got it, and thank you
    sweet!
    subbed?
    Get them talons clicking on the commit buttons :D
    hey, U wanna buy a boost gauge too?
    Awesome!
    good shiz!
  14. Jun 27, 2013 at 3:10 PM
    nfs257
    What you got laying around?
  15. Jun 27, 2013 at 3:18 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Can't wait till payday! :) Thank you Justus for all your hard work! Hopefully I'll have it installed just in time for race day.
    edit- Stealth can.
  16. Jun 27, 2013 at 3:23 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    So it says we have to get 25 orders and you listed those guys buying two as two separate orders. Do we have to get 25 orders, or just order 25 cans?
  17. Jun 27, 2013 at 3:24 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Ill Pm you
    U got it Robert......
    "becuz, racerunner"
    ur videos kill me..... just watching this big ol comfy truck pass by "sports car" after "sports car" is awsome!
  18. Jun 27, 2013 at 3:26 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    25 cans
  19. Jun 27, 2013 at 3:28 PM
    nfs257
    Where are these videos?!?!!?!!???
  20. Jun 27, 2013 at 3:30 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Phone call recieved and clarified.
    group buy numbers are per UNIT/catch can ordered.
    If I order 3 ultimates for instance..... Then that counts as 3, not 1 single order.
    feel free to order stuff for ur friends/relatives/ non members and know that EACH catch can will be counted ;)
    thanks guys
Thread Status:
