45,000 mile checkup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trabo, May 8, 2019.
  1. May 9, 2019 at 2:56 PM
    #41
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    A quick 10-second spray from a can of CRC Throttle Body Cleaner and a $200 charge on the invoice.
    AmateurTaco1313 likes this.
  2. May 9, 2019 at 3:09 PM
    #42
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    I just had mine done and didn't do all the extras stuff. I did have them replace the corroded battery cable though.
  3. May 9, 2019 at 3:48 PM
    #43
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    What the hek is air refresh service?
  4. May 9, 2019 at 3:59 PM
    #44
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i once had a shop quote me on replacing a rear main seal in a wrangler, they said also replace pan gasket, ok. they went to the labor book and got the time to replace pan gasket then the time to replace rear main and added the two together, they have to remove the pan to replace the rear main seal that is part of the labor built into the seal job.. duh i ain't that stupid.
    trabo[OP] likes this.
  5. Dec 15, 2021 at 4:02 PM
    #45
    zeerak
    zeerak Member
    2017 TRDOR
    So I just did an engine oil and filter change for $100. I think it's too high.
    Oil: $25
    Premium oil additive: $25
    Not sure what the heck is that needed for, and when I said I don't want it, they said they'll still charge me for it anyways. Then I said put it if you're gonna charge me for it.
    Filter: $6
    Drain plug gasket: $1.45
    Shop supplies: $5
    Labor: $35
    And the guy tried so hard to get me to do the following services, and I declined.
    It's recommended NOT required.
    As someone said stealership lol.
    Front brake pads and machine rotors: $199.95
    Evaporator core cleaner: $69.95
    Brake fluid exchange: $130.95
    Throttle body service: $89.95
    Transmission conditioner: $69.95
    4X4 service: $249.95
    Top D-crab kit: $189.95
    Fuel injection service: $199.95
    Subtotal: $1200
    Shop charges: $59.58
    Tax: $38.08
    Total: $1298.66
    I said no thanks lol
    Your thoughts?
  6. Dec 15, 2021 at 4:16 PM
    #46
    eosrory
    eosrory Well-Known Member
    2019 Tacoma TRD OFFROAD Quicksand
    If your power steering fluid is low, just add some. That is what mine looks like. No need to change at this time at all. For the brake fluid, just check if there is any water in it with an instrument. It should be good at this mileage.
  7. Dec 15, 2021 at 4:27 PM
    #47
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    I'm at 105k on my 2016, have not done any of that stuff, just the regular oil changes, did change my plugs at 100k
    my 90k recommended list from dealer was:
    Brakes flush $170
    4x4 fluids $385
    Front pads soon $385
    Drive Belt $272
    Clean throttle and
    air flow sensor
    replace PCV valve $285
    I will probably have them do drive belt and
    my brakes I can do for about $100
  8. Dec 15, 2021 at 8:28 PM
    #48
    Central Oregon Taco
    Central Oregon Taco Member
    Central Oregon
    2013 TOYOTA TACOMA DBL CAB LONG BD
    35's Wrangler Duratrac all-season tires Method 16" wheels Fabtec 6" lift Bilsteins suspension rear Dirt Logic coil over shocks w/ external reservoir C4 bull bar with Baja Designs amber fog lights and light bar Warn Winch VR Evo 10S w/ remote Wet Okole neoprene seat covers bed canopy w/ racks next: rock rails
    Where can I find a list of necessary fluid change/service and the corresponding mileage? Trying to avoid the upsell.
    My 2013 Tacoma now has 65K miles. Do I wait until 90K for diff, etc and all the rest?
  9. Dec 15, 2021 at 8:33 PM
    #49
    zeerak
    zeerak Member
    2017 TRDOR
    Dowoad the PDF file here to see the maintenance schedule.
    Personally, I perform the required services only. Recommended is for extreme situations and use, and more like a cash cow for dealers.
    Please make your decision
    https://www.toyota.com/owners/resources/warranty-owners-manuals.tacoma.2013
  10. Dec 17, 2021 at 10:46 AM
    #50
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    You can get a pack of little test strips made by Phoenix systems for about $20 that tests both your coolant and brake fluid if you’re worried about it. Id go by those than the dealership’s recommendation any day. I’ve used them on my truck and have tested known brand new and known really old brake fluid and coolant on another car and the results seem quite accurate.
  11. Dec 17, 2021 at 11:24 AM
    #51
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Something I do with the power steering fluid is a couple times a year i take a syringe and extract all the fluid in the reservoir and pour in fresh fluid, just to keep it somewhat new, drive it for a week or so and repeat.
  12. Dec 17, 2021 at 11:24 AM
    #52
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Yup, my dealer got it done in a hour for my 30K miles service.
    The bold part in your post: Front end brake pads can be replaced in 15 mins (more or less) depends on how quick you work on. The rear end which are drum brakes probably take little bit longer or quicker depending on how quick you work on. Brake inspection takes a few seconds each all around.
