.45 JHP's TRD Pro- Build & Adventure Thread
Discussion in '4Runner Builds' started by .45 JHP, Dec 27, 2015.
  1. Dec 27, 2015 at 11:22 AM
    .45 JHP
    .45 JHP [OP] Doesn't even own a Tacoma
    37.3582115,-121.9281197
    2015 4Runner TRD Pro
    THE BUILD
    I started this build with the idea that it'd be just a mild expedition setup. I don't plan on doing any heavy wheeling, but most of the mods are planned around being as capable as possible while still being mild mannered. With that in mind, don't expect anything crazy here :)
    CURRENT MODS
    Engine
    TRD Cold Air Intake
    Interior
    Flashlight Mod- Surefire P3X Fury Tactical
    5K LED Interior Lighting
    Husky Weatherbeaters
    Canvasback Cargo Liners
    Customized RAM Mount w/ Proclip Vent Clip for iPhone
    Hard-wired Dash Cam
    Custom rear cargo drawer setup
    Truck Fridge/Indel-B TF51 w/ Wagon Gear hinge flip kit
    Armor/Recovery
    Demello Front Bumper (Triple Hoop)
    Shrockworks Front Bumper
    Warn M8000-S
    Factor 55 Flatlink/Fairlead
    BAMF Bolt-on Rock Sliders
    CBI Rear Bumper (Dual Swing Out)
    RCI Full Steel Skids (Engine/Tranny/Transfer Case)
    Exterior
    Bajarack Spy Utility Rack
    Eezi-Awn K9 2.2M Rack w/ 40mm legs
    Low profile XM antenna mod
    ARB 2000mm Awning
    ARB Awning Room
    Maggiolina Airlander RTT
    Electrical/Lighting
    40" Single Row LED light bar on K9 Rack
    Xenon Depot HID kit w/ Philips 4300k bulb upgrade
    Adventure Trailers Solar Plug mounted in hood cowl trim
    Renogy 100W folding solar panel
    Odyssey PC3150 Group 31M Deep Cycle Battery
    National Luna Single Battery Monitor
    Tacomapros Bussman Relay Box
    OTTRATTW Switches in center console
    Suspension/Wheels
    Front TRD suspension swapped for Bilstein 6112, set at 2.5" front lift
    Rear TRD 5160 stock shocks w/ Toytec Superflex 2" lift springs
    BF Goodrich KO2 34x10.5x17
    Spidertrax 1.25" Wheel Spacers
    No-Loss Valve stem caps
    Comms
    Full Size CB (Bearcat 980SSB) in center console
    Firestik 2' CB Antenna
    Diamond K400 3/8C on hatch
    Hustler CB Quick Release
    PLACES WE'VE BEEN
    Death Valley NP (CA)- 04/2017
    Joshua Tree/Berdoo Canyon (CA)- 03/2017
    Black Rock Desert (NV)- 03/2017
    North Rim of the Grand Canyon (UT/AZ)- 11/2016
    Mojave Road (Mojave, CA)- 09/2016
    Eastern Sierra Mountains (Bodie/Mammoth/others, CA)- 09/2016
    Eagle Lakes/Signal Peak (Tahoe National Forest, CA)- 08/2016)
    Joshua Tree/Berdoo Canyon & Prewitt Ridge (CA)- 05/2016
    Prewitt Ridge/South Coast Ridge Road (CA)- 04/2016
    Joshua Tree National Park (CA)- 03/2016
    Crater Lake National Park (OR)- 01/2016
    Jedidiah Smith Redwoods State Park (CA)- 08/2015
    Vancouver and Victoria, BC (Canada)- 08/2015
    Portland/Seattle from San Diego (CA/OR/WA)- 08/2015
  2. Dec 27, 2015 at 11:23 AM
    .45 JHP
    Flashlight Mod
    Mounted my Surefire in the little shelf below the driver's side handle. I used 1" clips from Beckson Marine. Total install time was about 5 minutes.
    In case anyone is interested in the flashlight, you can find the same one here:
    SureFire P3X Fury Tactical Compact LED Flashlight
    It's a single output, 1000 lumen flashlight. Since it's so bright, I normally only use it as an emergency spotlight, as it will wipe out your night vision when turned on.
    ChadsPride likes this.
  3. Dec 27, 2015 at 11:25 AM
    .45 JHP
    Full Size CB Install
    I had this from my other 4Runner and never really got around to figuring out how to install it. Unfortunately there just aren't very many spots where you can mount a full sized CB in the 5th gen. After looking into several options and coming up empty, I decided to mount it inside the center console.
    The unit is a Uniden Bearcat 980SSB. I chose it mainly for the SSB features, and because it looks cool :)
    Dremeled the hell out of the center console and tried to make it as clean as possible. I was originally going to build a bracket to hold the CB inside, but ended up only friction fitting it- it's pretty snug in there.
    Now it was time to run the mount and cabling. I'm using the Diamond K400 mount. The new mount comes with a 13.5' coax cable pre-installed, which eliminates the need to run additional cables. It's also extremely thin, making it really easy to run through the interior.
    Ran all the wiring
    Put it back together and testing everything. Make sure that your SWR is within limits before operating to not damage any of your equipment. I managed a 1.05 SWR right out of the box- I'm not sure if I can get any better.
  4. Dec 27, 2015 at 11:26 AM
    .45 JHP
    Full Size CB Install (cont.)
    After experimenting with some different spring setups (both medium and heavy), I still felt like the CB antenna was too stiff. I also kept hitting the top of my garage every time I pulled in, which started to bend the mount and antenna.
    I decided to add a Huster QD2 quick release to the setup. It installs between the K400 stud and the Firestik antenna. I just push down, and turn it about a quarter turn to remove or release it. I mounted this upside down so that water/debris wouldn't get stuck inside of the quick release when not in use.
    ChadsPride, Loganc08 and Dcsleeper408 like this.
  5. Dec 27, 2015 at 11:27 AM
    .45 JHP
    BAMF Rock Sliders
    I ordered a set of BAMF bolt-on sliders from Jerry with full length plating, bump-outs, and also had him customize the angle to be flatter so my wife could use them as steps- final angle was 15 degrees if I recall correctly.
    ChadsPride and 06HAOLE like this.
  6. Dec 27, 2015 at 11:27 AM
    .45 JHP
    ARB 2000mm Awning + Fourtreks Mounts
    My wife ended up getting me an ARB awning as a Christmas gift, and I just needed a way to mount it to the Bajarack. I opted to use the beefier Fourtreks mounts vs. using the Bajarack awning mounts.
  7. Dec 27, 2015 at 11:28 AM
    .45 JHP
    TRD Intake Install
    Not much to see here, just wanted to show off this pretty little intake. It probably doesn't do much, but I scored a great deal on it brand new so I can't complain.
    For 2014+ models, it does fit despite TRD not listing it as an application. There is some harness re-routing hardware that you won't be able to use to to added emissions hardware.
  8. Dec 27, 2015 at 11:29 AM
    .45 JHP
    Hardwired Dash Camera
    I didn't want to run the bulky 12V cigarette lighter plug with my dash cam, so I ended up hardwiring a 12V to micro USB plug directly to the fuse box.
    I tucked the dash cam right behind the mirror, and ran the wiring through the headliner, down the A-pillar, which dropped me right behind the dash to the fusebox. If you do this make sure you route the wires into the existing harness clips to avoid interfering with the airbag.
    ChadsPride and Dcsleeper408 like this.
  9. Dec 27, 2015 at 3:31 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Looking good.:thumbsup:
    ChadsPride and .45 JHP[OP] like this.
  10. Jan 1, 2016 at 5:10 PM
    .45 JHP
    A friend and I decided to take a spur of the moment trip to hopefully see some Aurora Borealis from that solar storm. Sadly we didn't see anything but we did freeze our asses off catching an awesome view of Crater Lake at sunrise. Also got a chance to explore some forest roads.
    ChadsPride, Cavedog, 06HAOLE and 2 others like this.
  11. Feb 5, 2016 at 5:21 AM
    Mad T
    Mad T Well-Known Member
    Thomas
    Georgia
    Looks awesome! Subb'd
  12. Feb 11, 2016 at 12:41 AM
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    I love my tacoma, but god damn, i love the 4runners too.
    ChadsPride, Cavedog and .45 JHP[OP] like this.
  13. Mar 23, 2016 at 3:17 PM
    .45 JHP
    Electrical/Solar Setup
    I've been lagging pretty bad on updating this with some recent additions on account of getting this all ready quickly between work and a big camping trip that we took. I just finished up a big electrical project to keep up with my solar setup, fridge, and just to keep things clean for upcoming electrical mods.
    First, I purchased a new Odyssey Group 31M to replace my regular starting battery. I opted to go with a single battery setup vs. a dual battery setup specifically to keep things simple. I also plan on supplementing this with a solar panel to keep juice flowing to the Indel-B fridge I just picked up.
    Odyssey Group 31 Battery Install (in factory tray)
    I started out by disconnecting the factory battery cables and removing the OEM battery
    Since the new Odyssey is a bit larger, I needed to trim a portion from the OEM battery tray
    Muscle the new Odyssey in- looks a little like this
    Needed to purchase some Mil-Spec terminals and mated them to the factory terminals. Buttoned everything up.
    DISCLAIMER:
    When performing this mod, it is important to note that the OEM alternator is not rated high enough to charge the Odyssey to 100% charge. Battery lifespan may suffer if you do not fully charge the Odyssey on a Battery Tender or something similar every so often.
    ChadsPride and squint0241 like this.
  14. Mar 23, 2016 at 3:17 PM
    .45 JHP
    Electrical/Solar Setup (continued)
    Bussman Fuse Box install
    I opted to go with a Bussman Fuse Box setup instead of a Blue Sea fusebox because of the weather sealing and the additional relays. I ordered a pre-made kit from Tacomapros, complete with a Bussman 90A relay, switchbacks (to make wiring in the OTRATTW switches a little easier), and an aluminum plate to hold it all down.
    Mounting it all up and drilling holes
    Running the cabin harness (which contains the switchback harness to the OTRATTW switches) through the main harness firewall pass-through
    Back side of the main harness pass-through- this is where it exits into the interior
    Tie it all back into the mil-spec battery terminals on the Odyssey and you're done!
    Plugged into the OTRATTW switches
    ChadsPride and rob1208 like this.
  15. Mar 23, 2016 at 3:17 PM
    .45 JHP
    National Luna Battery Monitor
    Since I have everything running off a single battery, I wanted to make sure that I wasn't left stranded should my battery drop below starting voltage. Even though the Indel-B fridges come with a settable low voltage cutoff, this was just some added insurance to prevent coming back to a dead battery. The National Luna Single Battery Monitor comes with a low voltage alarm and a voltmeter that shows battery charge.
    I decided to mount this in the panel next to the factory jack in the trunk.
    Also, in preparation for my solar setup, I sourced a solar plug from Adventure Trailers to tie in to the Odyssey battery. Since the panel I'm running has a solar charge controller mounted directly to the panel itself, I can plug it straight into the AT Solar Plug. Also, since it has SAE connectors, I can use it to plug a Battery Tender directly to the battery. I mounted this in the plastic trim on the drivers side windshield.
    Started by drilling a hole in the panel
    Squeezed some marine sealant on it for added waterproofing
    Stainless self tapping hardware
    Mounted
    When needed, I can simply plug in the solar panel to the AT Solar Plug
    ChadsPride, spaculley, Leppz and 2 others like this.
  16. Mar 23, 2016 at 3:18 PM
    .45 JHP
    Renogy 100W Solar Setup
    So I wanted to add that I'm running a Renogy 100W solar suitcase to power my single battery setup, which in turn runs my Indel-B fridge and charges other small electronics (i.e my iPad, camera batteries, etc.). I'm getting about 6+ amps per charge in direct sunlight, which equates to about 60-70 watts. I tested this setup over the weekend on my recent Joshua Tree trip, and my battery never dipped below 12.5V the entire weekend.
    Here's a link to the panel I have:
    http://www.amazon.com/Renogy-Watts-Monocrystalline-Foldable-Suitcase/dp/B00HR8YNK6/
    The nice thing about the Renogy Solar Suitcase is that it packs down nicely into a soft protective cover which makes packing it easy. Also since the charge controller is already mounted inside the solar panel, it negates the need for additional controller. You could run a MPPT solar charge controller for better charging, but the included one works just fine for me.
    Solar panel in action
  17. Mar 23, 2016 at 3:50 PM
    Dcsleeper408
    Dcsleeper408 Well-Known Member
    Mark
    San Jose
    2000 Sr5 xtra cab
    Fishing pole antenna
    Dope build!!
  18. Mar 23, 2016 at 8:50 PM
    .45 JHP
    Same here man, too bad we didn't get to talk much. Nice seeing you around here, maybe we can catch up the next time we're down that way :thumbsup:
    Thanks!!!
    ChadsPride and dtaco06[QUOTED] like this.
  19. Mar 23, 2016 at 8:52 PM
    .45 JHP
    @Baoser @w3tw0rks @sytfu510 and I (along with a few friends) headed down to Socal to join in on their festivities in Joshua Tree. We ended up getting a nice primitive site about 30-45 minutes from the gates, and avoided most of the crowds that were there over the weekend.
    Leaving San Jose.
    Ran across this sweet Unimog that had literally been all over the globe. Spotted at the local Walmart.
    Set up camp. I had a couple friends with me who used the ARB awning + room as their sleeping quarters, which ended up being pretty useful. Got to use the solar setup.
    Night shots
    Linked up with the rest of the group the next morning. @dtaco06 @YotaGurlIAm @bustabenl and others (I can't remember everyone)
    bakasam, ChadsPride, .J. and 7 others like this.
  20. Mar 23, 2016 at 8:54 PM
    .45 JHP
    Did a few trail runs
    Went shooting on some BLM land and found some cool classic cars to shoot at.
    Some shots of Alex's cool expo Tacoma build.
    Group photo of the crew
    rob1208, Thesandaddict and dtaco06 like this.
