$450 Bolt On Rock Sliders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Apr 8, 2019.
  1. Apr 8, 2019 at 6:37 PM
    Ajsmith1990
    Ajsmith1990 Well-Known Member
    2016 Quicksand Tacoma OR DCSB
    All about deflection, lifting the truck is one thing, bouncing it down onto a rock is another thing! Atleast you have some protection and it’s mounted to the frame and not the body!
    therealprotaco[OP] likes this.
  2. Apr 8, 2019 at 6:38 PM
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    P.S. I guess the "feet" on this set are 2.5" angle and are 3/8" thick so he did apparently change it up a bit from previous sets.
    If all you want is the slider with no feet this guy's weld on sliders come just like mine are with the feet still detached. He's in Chandler. I'll PM you his contact info.
  3. Apr 8, 2019 at 6:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    FYI this is more or less how CBI sliders attach. What size bolts does it use? CBI's are 1/2" diameter.
  4. Apr 8, 2019 at 6:44 PM
    therealprotaco
    Gilbert, AZ
    3/8", three bolts per leg, four legs per slider.
  5. Apr 8, 2019 at 6:44 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I was thinking completely unassembled. He doesn't have any other contact than FB? I don't have one.
  6. Apr 8, 2019 at 6:45 PM
    therealprotaco
    Gilbert, AZ
    I would imagine he would probably sell just the pre-bent/cut tubing but not sure how much. I'll ask him if I can send his phone number.
  7. Apr 8, 2019 at 6:47 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Word! Thanks man!
  8. Apr 8, 2019 at 6:54 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    CBI is gusseted.
  9. Apr 8, 2019 at 7:01 PM
    therealprotaco
    Gilbert, AZ
    I may be wrong but it also looks like the frame mounts that most of these guys are using are a lot thinner than 3/8" so gussets may not be totally necessary with the thicker mounting plates.
    Edit: Looks like BAMF uses "CNC formed 3/16th laser cut legs and frame plates"
  10. Apr 9, 2019 at 7:06 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    @JLee the ones you sold me five years ago had holes for drilling into the bottom of the frame. I believe at the time you recommended it if you were going to hi-lift off the sliders
    I didn't realize you changed your design - my bad.
  11. Apr 9, 2019 at 7:26 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    No worries.
    Tigerian and therealprotaco[OP] like this.
  12. Apr 9, 2019 at 8:08 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Phew. Nice looking sliders, but yeah, that connection style.
    Speaking as someone who has serious steel design and engineering experience, this connection setup looks a bit sketch.
    Not trying to knock the guy for attempting to fill a desire in a market and make some extra coin, but perhaps he should talk with someone who knows a little bit more than he does about steel design before charging people for a product.
    As a quick FYI, mounting plate thickness is just one small variable in the design of a steel connection. Just because the mounting plate is as thick as molasses in winter time doesn't make the attachment method a good one. In fact, too thick and it surpasses the optimal thickness and begins to be detrimental to the truck.
    Skydvrr likes this.
  13. Apr 9, 2019 at 8:24 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    2x2 is not big enough for the frame mounting.
    I'd doubt its DOM being how cheap you got the sliders. It's probably HREW. There is nothing wrong with HREW and will probably serve you just fine. If the sliders are more for looks and light offroad your fine. If your going to use them as intended then the mounting will be the biggest concern.
    Skydvrr likes this.
  14. Apr 9, 2019 at 9:20 AM
    therealprotaco
    Gilbert, AZ
    Thank you for the constructive post! Does 2.5x2.5 x3/16”make it better or still undersized in your opinion? Like you said for light wheeling I’m not too worried about it but I know the builder is following this thread so he is probably interested in your opinion as well!
    The guy seems very genuine so I have no reason to believe he’s lying about the tubing type but is there any way to tell from the exterior of the tube whether it is DOM or HREW? I did talk to him last night as well and he said he stands by his work 100% and if I manage to bend or break them he’ll replace/repair for free.
  15. Apr 9, 2019 at 9:23 AM
    #35
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Would buy BAMF sliders over and over again. This guy knows what he’s talking about and doing.
  16. Apr 9, 2019 at 9:31 AM
    #36
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Hrew has a seam where it's been welded together. Dom is one continuous tube.
  17. Apr 9, 2019 at 9:33 AM
    #37
    therealprotaco
    Gilbert, AZ
    Should be easy enough to tell them. I’ll post back up later this afternoon when I go out to the truck.
  18. Apr 9, 2019 at 9:34 AM
    #38
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It'll look like a little black line that runs straight down the entire length of the tube.
  19. Apr 9, 2019 at 9:41 AM
    #39
    therealprotaco
    Gilbert, AZ
    Well you got me curious enough to go out and look. Definitely no seam on the tubing so looks like DOM it is!
  20. Apr 9, 2019 at 9:42 AM
    #40
    MR E30
    Michael
    This is not accurate.
    DOM has a seam, though it is more difficult to see.
