$450 Bolt On Rock Sliders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Apr 8, 2019.
  1. Apr 9, 2019 at 9:46 AM
    #41
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    I’m going to go out on a limb and say if I don’t see a seam then it’s in the DOM more difficult to see category.
    MR E30[QUOTED] likes this.
  2. Apr 9, 2019 at 9:47 AM
    #42
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I would definitely agree.
  3. Apr 9, 2019 at 9:59 AM
    #43
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    SOS Concepts has some nice sliders, no drilling and they are beefy AF.
    therealprotaco[OP] likes this.
  4. Apr 9, 2019 at 11:27 AM
    #44
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I'm not an expert by any means, but I don't follow. The curb weight of a Tacoma is what, 4,200#? Yield strength of ASTM36 steel is 36,000PSI? A 2x2 angle is stronger than the truck frame!
    Again, not an expert, but using a modulus of elasticity of 30000000 lb/inch2, supported at both ends for a length of 6' with a full 4,200# load and a moment of inertia of 24 yields only .045" of deflection.
    Boghog1 and therealprotaco[OP] like this.
  5. Apr 9, 2019 at 11:33 AM
    #45
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Shh get out of here with physics, you're forgetting to factor in the EAF constant and the sticker coolness ratio. Amateur mistake in this business!
    YumaTRD and therealprotaco[OP] like this.
  6. Apr 9, 2019 at 1:29 PM
    #46
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    There is a little more then yield strength when designing mounting points on a dynamically loaded part. 99% of the time when the sliders contact the ground will be dynamic loading far exceeding the forces of the curb weight of the truck. The little angle plates are not what's going to fail on these sliders, the frame of the truck is going too fail from having under sized mounting points if and when there is a failure. Those frame plates should have a much larger contact point then 2x2 with triangular top mounted gussets to minimize deflection.
    Simply making the plates thicker does not make them stronger your just moving the failure point to the frame of the truck.
  7. Apr 9, 2019 at 1:53 PM
    #47
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    2.5x2.5 still isnt enough. Most are around 5 to 6 inches. 3/16 is plenty strong for the thickness. I've got welded on HREW and they have held up. DOM or not I wouldn't worry about it
    Exact numbers I would have gotten if I sat behind you in school.
  8. Apr 9, 2019 at 2:07 PM
    #48
    MR E30
    Michael
    Precisely.
    If the truck even falls for a fraction of a second before the slider contacts the rock/solid object below, the resulting force is increased drastically. Using the work-energy principle to solve for its velocity at impact, a 4200# truck, falling 6 inches, with an arrest time of .1 seconds generates of force of over 14,800 lbs.
    Also, the width of the plate (which is tiny in this case) is the 'section width' used to determine the maximum allowable bending force in a rectangular cross section of steel plate. These plates are simply not wide enough for a bolted connection to make much sense. The force is too concentrated, exacerbated by the fact that the mounting plate is terribly thick and offers little to no plastic deformation to help dissipate the energy of impact, for the thinner truck frame to handle. The slider will be fine, but your frame will pay the price.
    Also, the idea of creating a bolted moment connection with bolts along the center line of the load is the shit of nightmares. *shudders
  9. Apr 9, 2019 at 2:09 PM
    #49
    therealprotaco
    Gilbert, AZ
    Thanks for the additional info. Do you have any examples you can share of the frame failing due to mounting points like that? What is happening twisting of the frame itself at the mounting point?
  10. Apr 9, 2019 at 2:16 PM
    #50
    MR E30
    Michael
    Here you go.
    The video does show some extreme situations, but nonetheless.
    https://www.youtube.com/watch?v=sdQPhzA44ms
    And this is with welded sliders, which do not interact with the frame the same way that a bolted connection does, fyi. Bolted connections are worse and the damage will be more severe.
    Basically, the frame will bend inward along the line that the thick mounting plate makes with the frame.
  11. Apr 9, 2019 at 2:30 PM
    #51
    therealprotaco
    Gilbert, AZ
    Man, I went to law school so I didn't have to do math and here I am worrying about math on my truck! So what type of frame failure are we potentially looking at here? Twisting, bending, cracking? With light wheeling (never any crawling or anything that a TRD Pro can't do on stock suspension and tire size) what are your thoughts as to failure probability?
    Tigerian and MR E30[QUOTED] like this.
  12. Apr 9, 2019 at 2:39 PM
    #52
    MR E30
    Michael
    That's why you, and the designer of these sliders, pay guys like me to do it for you.
    In all reality you will probably never have any issues, especially if you drive and use the truck as you described above. In all honesty, the 3/8" bolts are too small under a loosely fitted shear and tension connection. A serious fall would most likely affect those, especially due to their terrible placement, before you will suffer severe frame damage.
    My comments are mainly directed towards others who may want this cheaper bolt on slider, but that will be out there putting them through the paces on the trail. For those folks, this currently is not the best answer, or even a relatively good answer (again, not purposefully attempting to knock the manufacturer, just extrapolating on what I see).
  13. Apr 9, 2019 at 3:06 PM
    #53
    JLee
    Jerry
    Grass valley CA
    I would say your fine for the type of wheeling your going to do. I'm just pointing out the weak aspects of the design more so the builder can rethink the design before he sells to the masses and people start beating on them and they fail.
  14. Apr 9, 2019 at 9:36 PM
    #54
    therealprotaco
    Gilbert, AZ
    Well you guys have me worried and comforted at the same time. What a feeling. I guess the only thing to do now is paint them and see what happens next!
    Skydvrr likes this.
  15. Apr 10, 2019 at 7:47 AM
    #55
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Worst case move the rear leg farther forward and put on a bigger piece of angle iron or weld them to the frame
  16. Apr 10, 2019 at 7:58 AM
    #56
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
  17. Apr 10, 2019 at 2:37 PM
    #57
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    Damn, those things can take some abuse. I have RCI sliders on order. Hope they are as good. Although I don't expect to be dropping the truck from 2 feet.
  18. Apr 10, 2019 at 2:46 PM
    #58
    MR E30
    Michael
    I agree. TBH, this video really solidified my decision to go with 4X Innovations.
    I dont plan on dropping my truck 2 feet either!
  19. Apr 10, 2019 at 2:48 PM
    #59
    MAKAIRA
    MAKAIRA Well-Known Member
    Tim
    GET BACK TO WELDING:poking::stirthepot::D
  20. Apr 10, 2019 at 4:02 PM
    #60
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    That’s what I got. :D
