458 SOCOM...Outrageous ammo cost.
Discussion in 'Guns & Hunting' started by badguybuster, Jul 17, 2011.
  1. Jul 17, 2011 at 2:30 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I am in the process of building a new lower and thinking of an upper. I've been looking at some different options and really like this caliber but OH, MY GOD!!! $2-3 dollars a round!! Thats obscene.
  2. Jul 22, 2011 at 7:58 PM
    0uTkAsT
    0uTkAsT Gunslingin' Gearhead
    Josh
    Gilbert, AZ
    Rock Flinging Expo Turd
    Stuff that makes it easier to run over other stuff.
    Forgive me if this comes off as cynical but what would you do with a .458 anyways? It's a specialized round designed for disabling light vehicles and their occupants inside 100 meters. It wouldn't be good for any particular kind of hunting unless you're charging at a moose or something, the ammo is way too expensive and parts are way too scarce to shoot it much, and it's not accurate enough to have one as a range toy.
    What are you planning to do with the build?
  3. Jul 22, 2011 at 7:59 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Waiting for the apocalypse
  4. Jul 22, 2011 at 8:02 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    If the apocalypse comes, good luck finding .458 ammo. And good luck being able to afford enough to stockpile. :D
  5. Jul 22, 2011 at 8:14 PM
    cummins6speed
    Thats why some of us reload:cool:
  6. Jul 22, 2011 at 8:55 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    Reloading for the .458 is still going to cost you many times more per round than a healthy mainstream .30 cal manstopper. :D
    I reload, by the way. ;)
  7. Aug 5, 2011 at 9:16 PM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    how bout a saiga .410 shotgun rechambered to .444 marlin?
  8. Aug 6, 2011 at 6:49 AM
    meeestirg
    meeestirg Well-Known Member
    D15, CA
    why don't you just get a .50 beowulf?
    it's designed for the same thing, it's slightly cheaper, replacement parts are easier to find, ammo is easier to find, ammo is cheaper etc...
    here is a post i found at ar15.com from a guy who has both.
    I have both.
    Beowulf:
    1. CorBon factory ammo in several loadings
    2. Lesser initial expense, production line uppers
    3. Readily available reloading components
    4. Modified mags
    5. Limited bullets for reloading
    6. Less expensive brass
    7. Limited reload recipes
    SOCOM:
    1. CorBon factory loads in several loadings
    2. Slightly higher expense, custom built uppers
    3. Readily avaliable reloading components
    4. Unmodified mags
    5. Dozens of bullets for reloading
    6. Slightly more expensive brass
    7. Extensive supply of reload recipes
    8. More reliable feeding
    Beowulf has the edge on cost and availability of factory loads as well as types of factory loads, as well as ease of reloading.
    SOCOM has the edge on accuracy (slightly), brass life, reloading, overall flexibility, and quality.
    Basically, you need to decide if you're a reloader or not. If not, no contest, Beowulf.
    I would NOT trade my SOCOM for anything, though, and it's the big bore that I favor.
    Tom
