45k miles..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by themanbearpig012, Jan 21, 2018.
  1. Jan 21, 2018 at 3:57 PM
    themanbearpig012
    themanbearpig012 [OP] Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Just hit 45k in my '15 DCSB TRD Sport. As far as maintenance goes what needs to be done?
    *Tires are good but getting low on tread
    *Transmission fluid and been drained and refilled (drained it by mistake one day)
    *Brakes are good
    *Radiator flush?
    *Spark plugs?
  2. Jan 21, 2018 at 5:30 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Radiator flush is never a bad idea....
    themanbearpig012[OP] likes this.
  3. Jan 21, 2018 at 5:32 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    It's all outlined in your maintenance schedule that should be with your owners manual.
    themanbearpig012[OP] and yote like this.
  4. Jan 21, 2018 at 5:42 PM
    Skyway
    Ande'
    St.Pete
  5. Jan 21, 2018 at 5:42 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    What he said.
    The owners manual is like.... the Tacoma owners Bible
    cory02taco likes this.
  6. Jan 21, 2018 at 6:21 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    If you have to get new tires, you might as well lift it and spoon on some 285s. :D
  7. Jan 21, 2018 at 7:48 PM
    Pigpen
    Dan
    Northwest Montana
  8. Jan 21, 2018 at 8:05 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    ^ this....or just change the spark plugs
  9. Jan 21, 2018 at 8:16 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Coolant is good till 100k, carry on. Change spark plugs to iridium NGK's and be good for another 60k.
  10. Jan 22, 2018 at 12:48 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Hahahaha that’s awesome
  11. Jan 22, 2018 at 12:48 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Will do! Was kinda thinking of doing that
  12. Jan 22, 2018 at 12:50 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    I have fox 2.5 shocks in the front that leveled it out. Would love 285s but don’t want the hassle of doing a CMC or fender trimming. Plus, on a budget so have been looking at some 265/70r17’s
