Discussion in 'Audio & Video' started by Gus Gorilla, Mar 23, 2017.
  1. Mar 23, 2017 at 6:26 PM
    Gus Gorilla
    Gus Gorilla [OP] Well-Known Member
    2016 White TRD OffRoad
    None...yet
    Trying to install a ********* EZQ using their harness and I'm hitting problems. The harness plugs into the factory head unit, then back to the existing harness and at that point it also splits off 11wires to run the EZQ. No sweat. But now that it has reconnected to the speakers via the harness, where do I connect my amp output for door speakers. Anywhere I splice in will cause my amp to feed back the amplified signal to the EZQ via this dang harness creating a loop. I can fix this no problem with a few cuts, but their instructions say DO NOT CUT. Figured I'd ask the community.
    Started 2 service chats with ********* now and as soon as I ask they stop replying. So basically, ********* if you're listening, I hope you catch your tiny sack in the zipper of your skinny-jeans. Flakes.
    I'm on my first ever stereo build, so there's that. But I turned wrench for years and have a solid electrical background.
    Any help from the community appreciated.
  2. Mar 25, 2017 at 5:27 AM
    Marine 8541
    Marine 8541 Well-Known Member
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    I was getting some engine noise so I ran a better ground from the EZQ.
  3. Mar 25, 2017 at 7:45 PM
    Gus Gorilla
    None...yet
    I ended up cutting the ezq wiring to make it work. It works fine. But now some light hissing on all types, engine on or off. So I'm thinking a grounding issue, or maybe RCA pickup. Haven't dug in yet.
  4. Mar 28, 2017 at 8:15 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
  5. Mar 28, 2017 at 8:18 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Good luck on resolving the hissing. Just thought id add that they wont be getting another cent or endorsement from me either. Luckily im only out about 13 bucks but thats more than 0.
  6. Mar 29, 2017 at 4:19 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Some equipment is just noisy and there's nothing you can do about it. I know TT rebrands BOSS equipment - possibly the source of the noise. I wish I could say I'm surprised, but looks like TT strikes again.
  7. Mar 29, 2017 at 6:54 PM
    Gus Gorilla
    None...yet
    Well, hissing found. It's the Entune HU itself. The system just amplified it to be annoying. I tried all combinations of Entune/TT/Amp. Hissing present to varying amounts in any configuration. Hooked up the factory everything and let my ears rest all night. First thing, turn on all as stock and I can hear it when I'm close to the speakers. Same sound. So I reconnect and can manipulate it via the TT input gain the best. So for now, I've dropped the input output gain and raised the amp gain to get a fair amount of power and a hiss I only hear with the engine off.
    TL;DR. I tried it all and it's the HU making a noise that I am then amplifying. It was always present at an unnoticeable level.
