$485dlls for a dumpster
Discussion in 'Off-Topic Discussion' started by Rakso, May 13, 2013.
  1. May 13, 2013 at 3:59 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    So I called wm this morning to rent a dumpster for my house since ill b taking 2k sq ft of sod off my front yard. They want $485 for a 10cu yd dumpster. I thought it was too much so I'll rent a trailer and dump it myself at the dump site.
    What do you guys think ?
    Any suggestions ?
    Anybody has a utility trailer I can borrow?
  2. May 13, 2013 at 4:01 PM
    Manwithoutaplan
    ID
    i have a flat bed 8x10 trailer.
  3. May 13, 2013 at 4:04 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Call a landscaper, they might come take the sod for free and sell it to someone else for their yard.
  4. May 13, 2013 at 4:09 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    Where is it?
    The sod is garbage. Main reason I'm getting rid of it.
  5. May 13, 2013 at 4:10 PM
    Pugga
    Massachusetts
    F-150 Mod
    Oh... that changes things a bit then :eek:
  6. May 13, 2013 at 4:12 PM
    Manwithoutaplan
    ID
    I live in pasadena area.
  7. May 13, 2013 at 4:23 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Rent a rototiller , till in the sod , done
  8. May 13, 2013 at 4:27 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    just take a few trips with the truck. will take more trip then with a trailer, but still gets the work done.
  9. May 13, 2013 at 4:31 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    A bit far from me. Thanks though
    I'm already renting the sod cutter. I'll consider this.
  10. May 13, 2013 at 6:54 PM
    Larry
    Larry CARL
    CARL
    I pay about $250.00 for a 20 yard roll-off dumpster...
    I'm on #3 at my new home under construction.
  11. May 13, 2013 at 10:57 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    That's cheap
  12. May 13, 2013 at 11:02 PM
    OZ-T
    Peter North
    British Columbia
    Maybe Larry can rent one for you
    I pay about $375 , I'll see about sending one down
  13. May 13, 2013 at 11:04 PM
    OZ-T
    Peter North
    British Columbia
    Might wanna think about your waste stream management if you are at 60 cubic yards of waste on one house already
  14. May 14, 2013 at 4:56 AM
    Larry
    Larry CARL
    CARL
    house...guest house...detached garage/shop. brick and drywall scrap are the biggest filler. one can was 1/2 filled with ground debris from cleaning up the wooded areas surrounding my home.
    and there will probably be a #4.
    what's there to think about? can't burn the trash...can't eat it...cost too much to ship it to you so you can manage it how you best see fit?
  15. May 14, 2013 at 11:15 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2 2nd Gen T4R's
    So much Yota I can't explain!
    I don't know how different things are over there, but I don't even pay that for a 30 yard dumpster! Sounds like WAY too much to me.
  16. May 14, 2013 at 1:38 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    going out on a limb here, but if you ask to borrow a trailer, it might help to post up your location..no?
    i'd trailer it. i borrowed my buddies 3 yarder, and did several trips. i found a compost yard that took it for free.
  17. May 14, 2013 at 1:39 PM
    aficianado
    back to bone stock.
    hey WM has those debris bags right? you fill it, and they boom truck it away.
  18. May 14, 2013 at 1:50 PM
    OZ-T
    Peter North
    British Columbia
    Bagster
  19. May 14, 2013 at 1:54 PM
    Pugga
    Massachusetts
    F-150 Mod
    They're not very big though and pick up charges can be pricey. They're only 4' x 8' and the sides are about 2' with a capacity of about 3,500 # if I recall correctly. Filling it with sod would be a PITA because the sides aren't rigid. I used a couple for a small project, cost $30 to buy the thing and only $120 for a pick up. Some neighboring towns, the pickups were over $200 because they were in the sticks. If you think you realistically need a 10 cy dumpster, a Bagster is not a good alternative as it will end up costing you a lot more in the end.
