4Banger and 35s Q
Discussion in '4 Cylinder' started by YotaBoyz, Dec 1, 2012.
  1. Mar 26, 2013 at 7:23 PM
    #41
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    I use it a lot actually, not in traffic though.
  2. Mar 26, 2013 at 7:30 PM
    #42
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    Do you still get decent mpgs when you do this. Ive done it in mine to on hills but figured it would make the truck really drink gas. I dont drive on the interstate much and dont have a scangauge to check
  3. Mar 26, 2013 at 7:34 PM
    #43
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Doesn't mean anything.
    I can tweak the calibration on my Ultragauge to display 40mpg if I want.
    How many miles did you get out of your last tank, and how many gallons did you put in when you filled it up?
    If you never completely fill your tank, you will never know your true mileage.
  4. Mar 26, 2013 at 7:36 PM
    #44
    kcbmx
    Marco
    2tr-fe 4wd
    On the hills yes i see what you mean, I do let off and granny the gas.
  5. Mar 26, 2013 at 7:40 PM
    #45
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
    I drove 272 miles on this tank (60 was hauling an ATV on a trailer) and it took 15.308 gallons to fill it back up. 272/15.308= 17.76 since my tires are 11% bigger in circumference my speedometer spins 11% slower so 17.76 x 1.11= 19.7 mpgs
  6. Mar 26, 2013 at 7:44 PM
    #46
    kcbmx
    Marco
    2tr-fe 4wd
    its always between 320-350 when my gas light comes on. Sure I've seen a tad worse but nothing to freak out about. Fill up with 17 gallons take or leave. Im happy with my gas milage:D
  7. Mar 26, 2013 at 7:52 PM
    #47
    kcbmx
    Marco
    2tr-fe 4wd
    Idk its been like that ever since i got my smog done, I also have an abs light and the airbag light on. Im collecting them all like Pokemon lmao.
  8. Mar 26, 2013 at 7:55 PM
    #48
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
    What happened to your airbag light
    If its a bad clock spring/spiral cable they had a recall and it can be fixed for.free
  9. Mar 26, 2013 at 7:57 PM
    #49
    kcbmx
    Marco
    2tr-fe 4wd
    Im pretty sure its the clock spring, it just showed up recently. Ill need to check if im still eligible.
  10. Mar 26, 2013 at 8:04 PM
    #50
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
    I think since its a recall and not a tsb it applies to everyone even if the factory warrenty is up
  11. Mar 26, 2013 at 8:09 PM
    #51
    kcbmx
    Marco
    2tr-fe 4wd
    Jeff, are you planning to re-gear?
  12. Mar 26, 2013 at 8:24 PM
    #52
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
    No ill most likely go back to 33s when these tires wear out.
  13. Mar 27, 2013 at 4:17 PM
    #53
    bzzr2
    bzzr2 Well-Known Member
    my 09 reg cab with 3 inch lift and 267/75/16 dick cepek mud country tires is lucky to get 19mpg on a hilly hwy ride, the elevations are only 6-700 vertical ft at most and on flatter rides with better flowing traffic i get 20. i'm driving along at probably an avg of 70mph on these rides, if i granny it down to 60mph i'm sure it's better but not very much. consistent daily real world driving 20+mpg on 35's just is not realistic for those thinking oh yeah i should still get good mpg's...
