4banger Custom Wedge Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ke4640d20, Jul 27, 2018.
  1. Jul 27, 2018 at 3:18 PM
    ke4640d20
    ke4640d20 [OP] Well-Known Member
    Kirill
    2012 Tacoma SR5, 2.7L, 4x4, Stock
    Stock
    Follow the build on IG @https://www.instagram.com/s/aGlnaGxpZ2h0OjE3OTA2NzUxMTk2MjQ0NzI2/
    0317EFBE-03B8-4437-AEEE-D4E37E7F4AEC.jpg 391D5935-F9D6-4B9C-B27C-67CF01F658E2.jpg
    Truck
    2012 SR5, 2.7L 4x4
    Suspension
    Icon Stage 2
    SPC Upper Control Arms
    Dakar Heavy Leaf Pack
    Wheels/Tires
    Relations Race Wheels, RR1 16x8
    285/75/16 Falken Wildpeak AT3W
    Misc
    Dometic CFX40W Fridge
    Home Built Wedge Camper (Post #2)
    Truck Weight and Balance
    *Since this truck is a 4 cylinder, I am trying to keep it as light as possible. Here are my results after each major modification.
    Pre-Light Weight and Heights (3/4 Tank of Gas)
    Driver Front 1150lbs Passenger Front 1150lbs
    Driver Rear 880lbs Passenger Rear 850lbs
    Total 4030lbs.
    Front Ride Height: 34"
    Rear Rider Height: 36.25"
    Post-Lift, Wheels and Tires Weight and Heights (1/2 Tank of Gas)
    Driver Front 1210lbs Passenger Front 1150lbs
    Driver Rear 920lbs Passenger Rear 830lbs
    Total 4110lbs
    Front Ride Height: 37" (+3" per ICON)
    Rear Rider Height: 38" (+1.75")
  2. Jul 27, 2018 at 3:18 PM
    ke4640d20
    Kirill
    Stock
  3. Jul 27, 2018 at 3:18 PM
    ke4640d20
    Kirill
    Stock
    Reserved 2
  4. Jul 27, 2018 at 3:34 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Super cool. Interested to see the wedge camper come together.
    BassAckwards and ke4640d20[OP] like this.
  5. Aug 10, 2018 at 3:49 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Interesting....
    the_tacocamper likes this.
  6. Aug 12, 2018 at 8:28 AM
    ke4640d20
    Kirill
    Stock
    Update: Dropped off the deposit for the frame to get welded up. I was originally looking to do aluminum but the welder recommended doing a thinner steel for rigidity and longevity. We'll see how it turns out. Should have some pictures up end of next week. So the frame will be 1.5" Steel square tubing 1/8" thick. I am estimating the weight to be around 80lbs. Trying to make this camper as light as possible.
    Also ordered a RTIC 45 cooler this week for the build. They were having a 20% off sale on all order over $200. So I ended up getting the Cooler, Divider and 2 baskets for $190.00 shipped. Anyone have experience with the RTIC? We used a YETI on our cross-country and were pretty impressed with the ice retention, but not the $$$$.
    the_tacocamper and 69 Jim like this.
  7. Aug 14, 2018 at 8:43 AM
    ke4640d20
    Kirill
    Stock
    Update: Ordered a few swatches from fabricwholesaledirect.com, and ripspotbytheroll.com. Ripspotbytheroll.com recommended I go with their HyperD 300, which they said would be good against UV, it would be waterproof but no breathable. I also spoke to @sportsmobile in IG, and they said they basically used convertible top material for their builds. So I ordered some waterproof canvas as well.
    My take on the material:
    HyperD 300 (BLACK, GREEN, GREY) Looks pretty durable, I tried to put a paid of scissors through it under tension and they did not go through with moderate force. I don't know how durable it will be overtime, and I don't really want to replace the tent over time. It is waterproof, but non breathable. Overall a decent material.
    Waterproof Canvas (TAN, GREY) This stuff is tough, but obviously its comes with the downfall, its non-breathable. When I owned my EZ-Topper Lift set up, the walls were made of this stuff, and it held up very well.
    1.6oz RipStop: (ORANGE) Don't think I am going to even entertain this idea, it is very light, and basically see through. It would be good for other applications such as a hammock, but not a wedge tent camper. On the Brightside. It is breathable.
    Let me know what ya'll think!
  8. Aug 26, 2018 at 8:45 AM
    ke4640d20
    Kirill
    Stock
    Well! The frame is almost done.....it was supposed to be done about two weeks ago, but the shop has been busy. And unfortunately when it comes to small jobs like this, they generally get pushed to the right.
    Stopped by the other day to see fitment and it was all off. To narrow and to tall, so it’s getting redone. Hopefully not to much more of a wait.
    In the mean time, I found a guy giving away a Leer topper from his 1998 taco, and lucky for me! It had an intact rear slider. So I ripper it out and scrapped the topper. Which was nice because that saved me about $350.00 in buying a new slider.
    Also! The cooler came in, and we took it for a weekend bike trip to Santa Cruz, performed as expect.
    Side note: if you own a rotomold cooler, always pre cool them (I use ice from the ice machine at work) and use blocker ice not store bought ice. Basically get a silicone or metal loaf pan, and freeze a block everyday until you have like 10 of them. I can fit 6 in mine perfectly at the bottom and it lasted all weekend. I was also able to salvage a few and refreeze then.
    the_tacocamper and henryrose like this.
  9. Aug 31, 2018 at 1:23 PM
    ke4640d20
    Kirill
    Stock
    Rack is done!
    magicgus323 likes this.
  10. Aug 31, 2018 at 1:30 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    This is awesome. Wouldn't mind building one of these one day myself. I'm sure you've thought about this, but some bed stiffeners might do you some good once this becomes a permanent setup for your truck. Hate to see the bed start to split on you.
  11. Aug 31, 2018 at 1:34 PM
    ke4640d20
    Kirill
    Stock
    Thanks man! It been a month since I dropped off the deposit. Feels like forever lol.
    I’ve actually never heard of Bed stiffners, I am going to look into this.
  12. Aug 31, 2018 at 1:36 PM
    Jerneyman
    Wes
    Huntsville, AL
    There's plenty of variations on them out there and plenty of info here on TW. You'll definitely find some that fit the bill.
  13. Sep 1, 2018 at 2:50 PM
    ke4640d20
    Kirill
    Stock
    Some better pictures of the 80/20 placement and how far it will extended past the bed, and over the cab. Total 8’ by 56” wide. It’s not pretty (yet) but still will need the corners for the mounts rounded and use of some better hardware, and finally powder coating.
    the_tacocamper and BassAckwards like this.
  14. Sep 1, 2018 at 2:51 PM
    ke4640d20
    Kirill
    Stock
    Also ordered these last night cause it was a killer deal. 16x8 RR1 w/4.5” backspacing. Was a total of $500.00 shipped to the house. Now gotta find a good deal on wheels around Black Friday. And eventually a lift.
    BassAckwards likes this.
  15. Sep 9, 2018 at 5:15 PM
    whitundra
    whitundra Well-Known Member
    Cooper
    Bend, OR
    Flippac'd First Gen Taco
    I just ordered a set of RR1's too! Do you have any pics of them mounted up?
  16. Sep 9, 2018 at 6:26 PM
    ke4640d20
    Kirill
    Stock
    I don’t man, I honestly only bought them cause it was a good deal. I realistically won’t mount them until the topper is built. Mainly because I want to run 285’s and I need a lift for that and I don’t know what lift I will be using until I have the camper weight on the back, to see the rear sag.
    whitundra[QUOTED] likes this.
  17. Sep 30, 2018 at 6:24 PM
    ke4640d20
    Kirill
    Stock
    Not to much progress in the last few weeks. My fiancé and I are moving into a home, so it’s taking some funds away from the build. On the bright side! Put the taco through some paces this weekend at Bowman Lake.
  18. Sep 30, 2018 at 6:34 PM
    magicgus323
    magicgus323 Well-Known Member
    Gustavo
    Visalia Ca. East LA LBC
    2016 White Tacoma Sr 2.7
    TRD rims and suspension, TRD grill, stereo iPhone mirroring stormtrooper decal backflip bed cover painted bumper and mirror caps
    Badass lol
    ke4640d20[OP] likes this.
  19. Oct 10, 2018 at 12:25 PM
    ke4640d20
    Kirill
    Stock
    Little update;
    Found a kick ass deal on a set of 5 wheels and tires. Purchased 04 Falken Wildpeak AT3W in a 285/75/16, 2 were brand new, 2 new slightly used. As well as a full size spare (off brand) all mounted on a early 2000's 4runner wheels for $350.00. The spare is some M/T wheel but it will be nice to have a full-size spare.
    Also! Had a buddy who works for a "company" who got me a deal on a CFX40 Dometic Fridge for $260.00, soooooo the RTIC 45 is getting sold. anyone want one?
    I will be ordering the lift probably from headstrong off road (they seem to have awesome reviews and prices) end of November. 3" OME with DAKAR springs. So that should be a fun project!
    Also totally going to nerd out and weight the truck before and after all the mods on some aircraft scales, to see the weight difference I will see before and after lift/wheel/tires. Keep ya'll update!
  20. Oct 10, 2018 at 12:32 PM
    jowybyo
    Joe
    Baltimore, MD
    Is this the CFX-40W (with wifi)? That's more than a deal. Dealer pricing is way way way more than that.
