4banger Junkyard build
Discussion in '1st Gen. Builds (1995-2004)' started by 4banger4x4, Oct 1, 2013.
  1. Jan 9, 2014 at 8:20 PM
    #81
    4banger4x4
    4banger4x4 [OP] Probably should'nt have done that.
    Eric
    Whorelando, Fl
    np!
  2. Jan 12, 2014 at 8:16 PM
    #82
    ryan27
    ryan27 Active Member
    2000 tacoma sr5 4x4 automatic
    i have a 2000 toyota tacoma and was wondering what kind of gas mileage you get i get about 200 per tank, which is horrible... im thinking something is wrong in my engine to cuase this
  3. Jan 12, 2014 at 8:33 PM
    #83
    4banger4x4
    Eric
    Whorelando, Fl
    when my speedo was working is was getting about 220-260 to a tank and that was willing up 14-15 gallons it was roughly 16mpg if i remember correct. I was setup with 3.58 gear, 5spd, manual hubs and 31s. Now that ive got 4.56s and 33s my ultra gauge is showing me im getting around 15 city and 19 highway.
  4. Jan 12, 2014 at 8:46 PM
    #84
    ryan27
    wow thats way better than mine haha i definitly think i have a problem now :mad:
  5. Jan 12, 2014 at 9:09 PM
    #85
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves, 33x13.50 Super Swamper LTBs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, Lincoln Locked front diff, Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 20" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods.
    I'm averaging about 15mpg over the last 571 miles with 33s and factory (I'm presuming) 4.10 gears. I'm thinking I could do better with a better set of spark plugs. Mileage can go down if you don't have good plugs in it...or if your plugs are shot.
  6. Jan 12, 2014 at 9:16 PM
    #86
    ryan27
    haha funny thing is i just swapped spark plugs... i was thinking it might be a vacum prob what do you think
  7. Jan 12, 2014 at 9:19 PM
    #87
    4banger4x4
    Eric
    Whorelando, Fl
    I would be running rough if it was vac. Clean your MAF, plugs, wires, air filter, and you could do the o2 sensors if you have some extra cash laying around. Also how many miles on your truck and how heavy on the gas are you
  8. Jan 12, 2014 at 9:19 PM
    #88
    4banger4x4
    Eric
    Whorelando, Fl
    Also did you gao your plugs?
  9. Jan 12, 2014 at 9:21 PM
    #89
    Taco No Baka
    Lee
    Tampa, FL
    Is it running rough? Also, what does the exhaust smell like? Does it have a strong smell of any kind?
  10. Jan 12, 2014 at 9:23 PM
    #90
    ryan27
    ya i did and 142k not really that heavy on the gas but i am a teenager
  11. Jan 12, 2014 at 9:25 PM
    #91
    ryan27
    ya kinda does have an abnormal exuast smell
  12. Jan 12, 2014 at 9:31 PM
    #92
    Taco No Baka
    Lee
    Tampa, FL
    K, then if it's not running rough, then it's probably a sensor issue, either MAF or O2 causing it to make the fuel mixture a bit rich. I'd recommend taking it somewhere and having it put on the computer to see what's going on.
    Edit: you don't have to let them fix it, but they'll probably charge you for diagnosing it if you don't.
  13. Jan 12, 2014 at 9:33 PM
    #93
    ryan27
    thanks i will do that and thanks for the advice again!
  14. Jan 13, 2014 at 3:28 AM
    #94
    4banger4x4
    Eric
    Whorelando, Fl
    Just clean the MAF before you take it anywhere. All it is, is two screws spray it down with electrical cleaner or MAF cleaner and put it back on
  15. Jan 13, 2014 at 5:14 AM
    #95
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, I meant to say that, but the CRS got me again. :eek:
  16. Jan 18, 2014 at 9:01 PM
    #96
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    nice truck. 4 banger FTW
  17. Jan 18, 2014 at 9:06 PM
    #97
    4banger4x4
    Eric
    Whorelando, Fl
    if i could swap a motor in i would. im not crazy about a 4banger
  18. Jan 18, 2014 at 9:26 PM
    #98
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    me too but still cool to see a nice 4 banger though. I think i would supercharge before i did an engine swap
  19. Jan 18, 2014 at 9:27 PM
    #99
    4banger4x4
    Eric
    Whorelando, Fl
    turbo charge>super charger> 3.4 swap> 4bt cummins
  20. Jan 18, 2014 at 9:30 PM
    #100
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    turbo would be cool as well. its a good motor just needs a little extra power.
