4cy tacoma specs 05+
Discussion in '4 Cylinder' started by br217398, Jan 10, 2009.
  1. Jan 10, 2009 at 3:22 PM
    br217398
    br217398 [OP] Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    Here they are... hope they help somebody:
    2006 Toyota Tacoma Performance
    2,694 cc 2.7 liters in-line 4 front engine with 95 mm bore, 95 mm stroke, 9.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder 3RZ-FE
    Unleaded fuel 87
    Fuel economy EPA highway (mpg): 27 and EPA city (mpg): 20
    Multi-point injection fuel system
    21 gallon main unleaded fuel tank
    Power: 119 kW , 159 HP SAE @ 5,200 rpm; 180 ft lb , 361 Nm @ 3,800 rpm
    2006 Toyota Tacoma Handling
    Four-wheel ABS
    4.1:1 axle ratio
    Brake assist system
    Two disc brakes including two ventilated discs
    Electronic brake distribution
    Fullsize steel rim under body spare wheel
    Wishbone front suspension independent with stabilizer bar and coil springs , beam rear suspension rigid with leaf springs
    2006 Toyota Tacoma Exterior
    Black front and rear bumpers
    Driver and passenger internally adjustable black door mirrors
    External dimensions: overall length (inches): 190.4, overall width (inches): 74.6, overall height (inches): 69.9, ground clearance (inches): 9.5, wheelbase (inches): 110, front track (inches): 63, rear track (inches): 63.4 and curb to curb turning circle (feet): 36.1
    Complex surface lens halogen bulb headlights
    Mica paint
    Straight side pickup bed insert liner
    Fixed rear window
    Rear platform step
    Tinted glass on cabin and rear
    Underbody protection for engine
    Weights: gross vehicle weight rating (lbs) 5,000, curb weight (lbs) 3,360, gross trailer weight braked (lbs) 3,500 and max payload (lbs) 1,640
    Windshield wipers
    2006 Toyota Tacoma Interior
    12v power outlet: front and 1
    Fixed mast antenna
    Audio anti-theft protection: integrated in dash
    Manufacturer's own audio system with AM/FM and CD player
    Cargo area dimensions: length (inches): 73.5, front width (inches): 56.7, width between arches (inches): 41.5 and height (inches): 18
    Rear tailgate cargo doors
    Front seats cigar lighter
    Clock
    Full dashboard console with covered storage box , partial floor console with covered storage box
    Delayed/fade courtesy lights
    Front seats cup holders fixed
    Door ajar warning
    Door pockets/bins for driver seat, passenger seat and rear seats
    Floor covering: carpet in load area
    Driver front airbag intelligent , passenger front airbag with occupant switch off intelligent
    Bench driver, passenger and center seat
    Height adjustable 3-point reel front seat belts on driver seat , height adjustable 3-point reel front seat belts on passenger seat , lap static front seat belts on center seat
    Front seat center armrest
    Glove compartment
    Two height adjustable head restraints on front seats
    Internal dimensions: front headroom (inches): 40, front hip room (inches): 53.6, front leg room (inches): 41.7 and front shoulder room (inches): 58.1
    Low fuel level warning
    Low tire pressure indicator
    Power steering
    Front reading lights
    Rear view mirror
    Cloth seat upholstery with additional cloth
    Seating: three seats
    Service interval indicator
    Four speaker(s)
    Plastic steering wheel with tilt adjustment and telescopic adjustment
    Tachometer
    Passenger vanity mirror
    Ventilation system with recirculation setting
