4cyl 4x4 in the mountains?
Discussion in '4 Cylinder' started by texastacobueno, Apr 27, 2011.
  1. Apr 27, 2011 at 3:50 PM
    texastacobueno
    texastacobueno [OP] Effin A Cotton, Effin A
    Andy
    College Station, Texas
    08 4x4 Sport
    Pop N Lock - Westin sportsman guard - Hella 500 fogs - extra D-rings - Mag Lite mounts
    I had an '08 V6 4x4 sport that was awesome, but got an offer on a brand new (2011) xterra and the wife won out. But now I'm looking again. We'll most likely be moving to California soon, and I'm wondering. How does the 4cyl 5spd 4x4 do in the mountains and such. I don't speed around, but I do go camping/climbing/kayaking/ect. often. If you guys don't mind chimming in than I'd love to hear any advice! Thank you
  2. Apr 27, 2011 at 4:51 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Usually you can hold speed by going into 4th gear. Acceleration will be missing sometimes. If you arent loaded up and trying to do 75 mph its a steady reliable truck. Make no mistake though, it wont power you out n up like a v-6. I use mine going skiing /hiking. Corners better than most trucks, so ,on the windy river corners , i doubt you could ever be the holdup. If you get caught with a bit of a load and want to gain 10 mph on a grade , dont be surprised if the steeper grades make it real slow to 55 from 45.Good driving tactics and predicting the road, its lesser power wont be an issue.
  3. Apr 27, 2011 at 6:18 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    It does fine if I use 3rd gear, for 65, on the steepest grades. Just down shift early and you will do fine. I notice the speedo drops about 3-4mph (even when quick shifting,) when I down shift.
    I am in Colorado.
  4. Apr 27, 2011 at 6:18 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I have found the 5 speed to be pretty good on hills in 4th gear, Don't get the automatic version of the 2.7l.
  5. Apr 27, 2011 at 6:21 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah dont get the 2.7 auto you will lose out on the mountains. if your towing under 1500 lbs you will be fine!
  6. Apr 27, 2011 at 6:27 PM
    texastacobueno
    Andy
    08 4x4 Sport
    well i never tow, i just haul around 2 mountain bikes, or 2 kayaks, or 2 backpacks, or 2 snowboards, ect... I will never tow anything with it. I'm just interested ina trail/mountain capable small truck with a sporty look and solid reputation. oh I for got to add, OR 2 rhodesian ridgebacks. So the 4cyl would handle the steep inclines is what im gathering. In the way of tires are you guys staying stock?
  7. Apr 27, 2011 at 6:29 PM
    Tacoyota
    08 4wd
    I run the stock dunlops summer, and some same sized AT severe weather rated, winter tires.
  8. Apr 27, 2011 at 6:31 PM
    texastacobueno
    Andy
    08 4x4 Sport
    another questions guys. The only other debate I have is 4wd or 2 wd. I want to life it a bit, and I've always had a fear when lifting a 4wd truck. Like CV angles and stuff. Any of you lift yours?
  9. Apr 27, 2011 at 6:32 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    You will want All Terrain, passenger rated tires, if you are looking for MPGs and don't plan to do a lot of offroading (the stock size tires will work just fine 245/65 or 265/70.) If you get in to Offroading, get an LT tire.
  10. Apr 27, 2011 at 6:36 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    The only problem with lifting your truck is... you will continually want to buy more stuff.
    Get the 4x4 if you live where it snows.
    Go to http://www.wheelersoffroad.com/ to get an idea of the pricing on things.
    You can Google the items in my signature as well. I have a fairly "mild" truck and it does everything I want it to, with in reason.
  11. Apr 27, 2011 at 7:06 PM
    Tacoyota
    08 4wd
    2wd is around 300lb less. The prerunner might be to your liking too. I see some roads that dont need 4wd, just a bit more ground clearance. I suppose where you go sill determine if you think you need 4wd. The CV joint/3" lift issue worries me too, i like the idea of a simple lifted 2wd to go hiking or deer hunting where im at, but i got 4wd for skiing /elk hunting , and to get to work. being a "city worker" I do plowing n such for snow.I'm not required to have an awd/4wd , but i wont put up with no traction and sliding if i dont need to.
  12. Apr 27, 2011 at 8:07 PM
    canucklehead
    canucklehead Well-Known Member
    sunnyvale, ca
    05 Tacoma reg cab 4x4
    i have no problems w/lift and camper shell. but you might want to test drive one first since you had a v6. when i went to the dealer i refused to drive anything other than the 4x4 4cyl so i wouldn't change my mind
  13. Apr 27, 2011 at 9:17 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I have a camper shell and lift and when I drive over the mountains here in Cali I just take it out of overdrive and I'm able to stay with traffic.
  14. Apr 28, 2011 at 11:10 AM
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    I live in the Sierra foothills & have the ac 4x4 2.7l 5sp. it gets along fine.
    I think your satisfaction with the 2.7 will depend on your personality. I'm older and more patient then I was in my 20s. barreling up Hwy 88 like a raped ape is less appealing then it used to be. I just relax, turn up the radio and enjoy the ride. there is always someone slower then me on the road.
  15. Apr 28, 2011 at 11:23 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    A 4cylinder Tacoma will do fine in the mountains, as long your not in a hurry to go up hill. It will carry your bikes and dogs with no problem.
  16. Apr 28, 2011 at 4:14 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Ya, I love my new truck. Same as what you would be looking at. Once you take the secondary filter out I find its perfect for creeping along getting good mpg, but with the 5 speed you get a little better kick if you need it. I would never buy the V6 unless I was going to do off-roading with it, or needed it for towing. I almost did but Im glad I didnt. I love getting 700+kms out of a tank lol
  17. Apr 29, 2011 at 4:40 AM
    texastacobueno
    Andy
    08 4x4 Sport
    awesome info guys thanks! By chance have any of you ever heard of someone putting a TRD OR electronic locking rear diff in one of these?
  18. Apr 29, 2011 at 7:24 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    ya a few people have. cant remember exactly who but i will let you know when i remember
  19. Apr 29, 2011 at 7:26 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    Just get an ARB. It is better and you will be happier in the long run.
