4cyl Double Cabs - Any gitty-up issues?
Discussion in '4 Cylinder' started by HammerHead, May 9, 2012.
  1. May 9, 2012 at 7:39 AM
    HammerHead
    HammerHead [OP] Well-Known Member
    Jake
    Georgia
    04 TRD OffRoad PreRunner SR5 DC
    Hey guys. I posed this question on the 1st gen page as well, but thought I would ask here too. I know this may be somewhere if I dig, but a friend just emailed and is looking at a 2004 Double Cab, 4cyl. Want to try to get him a quick response.
    Is there any issues with a 4 cyl on a doublecab frame, ie, slow or unresponsive? I told him as long as he's not towing alot, he should be fine, but wanted to confirm with you guys. You would think a v6 would be required on a double-cab frame, but does it really make a big difference?
    Hoping for a quick response so I can get back to him asap
    Thank you!!
  2. May 9, 2012 at 7:55 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Tell him to test drive it, it's the only way HE is going to know if it's got enough power for the type of driving he does. The 4 cylinder will move a double cab but it's not going to be a powerhouse. Some people are OK with the 4 cylinder power while it drives other people crazy.
  3. May 9, 2012 at 8:08 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I have to disagree with you on the V6 thing, ever see one of these before?
    My grandmother had one with the 22RE 4 banger I believe and it pulled it around just fine and held 70 on the highway. I wouldn't underestimate the 4, Toyota and Honda make some of the best 4 bangers out there. Mine has plenty of pep to it even when it is loaded down.
  4. May 9, 2012 at 8:15 AM
    HammerHead
    Jake
    Georgia
    So you're saying the 4cyl is good for towing? I don't think he plans on towing anything, but that is good to know.
    I'm just wondering if there are any issues with the 4 cyl double cabs that I'm not aware of. Logic would dictate that the bigger the frame coupled with a smaller engine would equal low response, but I'm not sure. :notsure: The only reason i was thinking it could be an issue, was because of the 4 cyl Isuzu I used to own. It was like trying to get a dead turtle to move, lol. Heavy frame.
  5. May 9, 2012 at 8:16 AM
    TJGARZA84
    TJGARZA84 Well-Known Member
    TIM
    SAN ANTONIO
    2012 TOYOTA TACOMA PRERUNNER SR5 - BLACK
    TINT - 20% FRONT - 5% REAR 3 INCH LIFT PAINT TO MATCH GRILL AND REAR BUMPER REMOVED ALL EMBLEMS
    I have a 2012 4 cyl double cab and had 2011 4 cycl double cab - hence the reaon i bought the same truck only newer.
    Anyways - its more then enough power.Allthough i havent towed anything with it and dont see any reason why it cant tow.
    Yes it can be a bit slow when trying to pass or on a steep incline -That when you drop gear and all is good again.(mine is an automatic)
    Have your friend test drive and compare - good luck ......
  6. May 9, 2012 at 8:17 AM
    2004TacomaSR5
    Jon
    Montana
    It varies really, I have towed 2580lbs with mine and had no trouble, it wasnt fast by any means, but people shouldn't need to go fast when towing anyways.
  7. May 9, 2012 at 8:18 AM
    Pugga
    Massachusetts
    If you put a small engine in a big frame, it will not be quick. The 4 banger will get the double cab moving but don't expect it to be a race car. The double cab isn't THAT much heavier than the access cab and has the same length frame I believe. Again, have him test drive the truck to make sure he'll be happy with the 'gitty up'. Asking an open forum will get you nothing but opinions, some bias to the engine they currently have.
  8. May 9, 2012 at 8:23 AM
    HammerHead
    Jake
    Georgia
    All good points. Yes, a test drive would be in order. I'll let you know how it goes as I may be helping to add another satisfied Taco driver to TW. :D
    Thanks guys, I knew I could count on y'all. :)
  9. May 9, 2012 at 11:19 AM
    2004TacomaSR5
    Jon
    Montana
    Isn't everyone still high? :D
  10. May 9, 2012 at 11:38 AM
    HammerHead
    Jake
    Georgia
    Huh?....:rasta:
