4cyl RPM on 6cyl cluster calibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by betterbuckleup, Jun 14, 2019.
  1. Jun 14, 2019 at 3:12 PM
    betterbuckleup
    betterbuckleup [OP] Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    So I stumbled upon this product that Dakota Digital makes that states it's capable of both adjusting the speedo for larger tires as well as altering the tachometer signal for a different size engine.
    http://www.dakotadigital.com/index....t_id=825/category_id=694/mode=prod/prd825.htm
    After initially purchasing my truck, I realized that the instrument cluster was from a 5vz 6yl and doesn't read correctly for my 3rz 4 cyl motor.
    Does anyone have any experience with this module and know if it would in fact make my instrument cluster read correctly? I've been using a scangauge II to read the true RPM's for now, but it would be awesome if I could make my cluster work how it should.
