4cyl to V6 Engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SKTwenty, Sep 2, 2019.
  1. Sep 2, 2019 at 8:00 AM
    SKTwenty
    SKTwenty [OP] Member
    2012 Tacoma SR5
    So long story short, I bought a 2012 Tacoma SR5 and it's a 4cyl. I specifically bought the 4cyl because I knew either way, I'd be replacing the engine and I'd feel less bad about replacing a 4cyl than I would a V6. My question is, what all would I need to make a swap into a V6? I need to know the exact parts and whatnot like what kind of transmission, wiring, and so on. I'm still new to the modding scene but this is where I want to go in life, so any and all help is appreciated.
    I just don't want to hear "it'll be cheaper to buy a V6" because I don't want to do that. I'm deliberately making more work for myself
    Edit: so it seems a lot of people are against bothering with swapping to a v6, but obviously the 4cyl isn't going to fly with me, as I like to have more power. So if not v6, then what?
    In addition to the edit, since it's apparently not obvious. If you're not adding to the conversation and helping, save yourself the time and don't comment at all.
  2. Sep 2, 2019 at 8:20 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    KLiK and tinker_troy like this.
  3. Sep 2, 2019 at 8:44 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I'd second the 'Sell yours and buy a V6 Tacoma". BUT if you really have your heart set on doing the swap yourself. It might be better (and overall cheaper) to buy a V6 Tacoma that has been wrecked in the back end, or that has a rusted through frame but a good drivetrain.
    You're going to need stuff that's going to add up if you try and buy it all separately.
    That's my thoughts on it. Many may disagree.
    I personally wouldn't go through the hassle of the swap, them any issues afterwards
    ie electrical gremlins! !!!
    Good luck !!!
  4. Sep 2, 2019 at 9:04 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You stating that you deliberately bought a 4cyl so you won't feel bad eventually replacing it versus a V6, then asking to swap to a V6 is the worst financial strategy you could take in buying a Tacoma. Most will tell you to sell and get a V6 because it's the cheaper most safer route. A V6 swap is not cheap or easy. It's not just finding a V6 engine, trans, and ECU. It will likely involve mounts, upgraded suspension, axles,gears.etc..and lastly, hope that there's no check engine light after install due to some sensor issue.
  5. Sep 2, 2019 at 9:12 AM
    81shark
    81shark Well-Known Member
    At least do a v8
  6. Sep 2, 2019 at 9:19 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Hey, at least your truck already comes with a 4.10 gear ratio in the rear lol.
  7. Sep 2, 2019 at 9:21 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Agreed. It's not like the good old days when one could pluck an engine out of an old Chevy truck, bolt in a different one, and away you go.
    Dan 77 and whatstcp like this.
  8. Sep 2, 2019 at 9:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    At least you're truthful.
    ^^ This. x10
    If you don't do the one above (donor vehicle) and you're into tossing down $, the v8 is the right answer. Otherwise, when you are done, no one will know or have any appreciation for your work. You'll just have experience and an empty wallet for the same thing everyone else has.
    Don't do all that work and spend all that money, then be like
    blu92in99, Jimmyh and Climberclimb like this.
  9. Sep 2, 2019 at 9:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Add a turbo. Only help that I can offer. :D
    mojojojo78 likes this.
  10. Sep 2, 2019 at 9:54 AM
    sceptre001
    sceptre001 Well-Known Member
    ATX
    2006 RC Prerunner 5MT, 2020 DCSB
    Find a wrecked 4th gen 4runner with a V8. Engine, tranny, Ecu, wires . . .
    goforbroke123 and whatstcp like this.
  11. Sep 2, 2019 at 10:35 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Keep the bulletproof 4cyl.
  12. Sep 2, 2019 at 10:36 AM
    SKTwenty
    2012 Tacoma SR5
    I have been keeping an eye on some junkyards around me for some good deals. Even piecemealing the parts is fine for me in all honesty. I know these things take time.
  13. Sep 2, 2019 at 10:37 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I really don't understand this part.
  14. Sep 2, 2019 at 10:40 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    If you really want to do this, go find a parts truck to buy. It’s going to be even more difficult to find every single component piecemeal.
    To reiterate what was said above, just sell your old truck and get a v6 one like you want. If you’re going through the trouble of an engine swap at least do a 2UZ or something along those lines.
  15. Sep 2, 2019 at 10:44 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Good luck man. Most ppl here don’t have the skills to do something like this so they default to “it’s cheaper to sell it and get what you want”. The best thing to do is go to www.toyodiy.com and cross reference your year in both 4-cylinder and v6. Figure out every part that is different. Then source them as best you can.
    Start by focusing on the engine mounting, transmission system and electrical difference. Other shit will come up but you’ll just have to figure it out on the fly.
    Can’t wait to see the end result.
    D2. and tinker_troy like this.
  16. Sep 2, 2019 at 11:00 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    7k is still a deal if its rear ended and he can use all the parts to swap over.
  17. Sep 2, 2019 at 11:09 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Help or move on. Not cleaning this thread up again.
  18. Sep 2, 2019 at 12:04 PM
    SKTwenty
    2012 Tacoma SR5
    Would a V8 even fit in the frame...? To my understanding they're quit a bit bigger.
  19. Sep 2, 2019 at 12:06 PM
    Bishop84
    Bishop84 Well-Known Member
    The 4.7 isn't huge. The 4.6 and 5.7 are massive wide angle v8's.
    Mopar Mussel likes this.
  20. Sep 2, 2019 at 12:07 PM
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    Might as well go all the way and do an RB26DETT, ATTESA, and Super HICAS swap.
