4dr rock swatter....
Discussion in 'Solid Axle Suspension' started by bullcrew, Jan 17, 2015.
  1. Jan 17, 2015 at 7:44 AM
    bullcrew
    bullcrew [OP] Well-Known Member
    travis
    oceanside
    03 quad cab sas
    Went and picked up a project that has a partially finished front end.... on trailer with some boxxer parts we headed back to shop...
    03 quad cab
    Toy rear with e-locker with solid opinion spacer
    Rock assault 5" over front housing
    5:29 gears
    Detroit Locker front
    Tundra 231mm front brakes with fror brackets
    Skys manufacturing billet pitman arm
    Trail gear 3" SAS
    Creeper rear joints
    Bilstein shocks
    6 shooter knuckles,
    Trunion bearing eliminator kit
    Long field 30 spline
    Long field outputs
    Trail gear hydro assist
    1650 pump
    2x8" ram
    Abs eliminator
    Square tube front shaft
    Dual cases
    Hid headlights
    Warn 9.5 CTI winch
    Large capacity aluminum radiator so its above the frame rails
    Electric fan
    Tg bumper
    All pro sliders
    Raceline bead locks
    MTR Kevlar 37" tires
    ARP studs
    Upgraded hub studs
    Ifs box
    Plated frame front and rear
    High steer set up
    Wilwood brake proportioning valve
    Of the parts listed I'm down to finish.... this week
    Hydro assist dual cases and trunion bearing eliminator this weekend
    Front was almost finished so ripped into it Monday and between jobs got to this point....
    Nicks4x4LT and Large like this.
  2. Jan 18, 2015 at 11:19 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Rolled ot out and did the radiator fan on a switch till Tuesday when I'm back at work...then I'll write up the sending unit and relay to a thermal switch.
    Did a 40 mile drive to run it and see how it handles....all good 80 down the freeway steady and controlled....
    Will be doing wheel spacers in rear...its 5" over in front....
  3. Jan 24, 2015 at 1:38 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Built a rack, not finished yet still dimple die plates and attachments to go on as tie downs
    Pirhett likes this.
  4. Jan 24, 2015 at 4:47 PM
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    2001 4 Runner
    ADS racing shocks ext travel front, ADS FJC piggyback shocks rear, Addicted Offroad front plate bumper, 4xinnovations rock sliders and rear plate bumper, SCS Stealth 6s
    Sweet build so far man! Where'd you find that giant clamp for the Co2 tank mount? Looks like it works really well!
  5. Jan 25, 2015 at 8:37 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Got a good test run in....
    Here's a video of me dropping a ledge
    http://www.pinkbike.com/video/394487/
    Then 2 different bus dies Vlad and rowel both in white XJ'S flopped same spot and matching dents on side and roof...
    Pirhett likes this.
  6. Feb 2, 2015 at 7:12 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Well 3 days with hydro assist and figured out where I'm getting air in system....
    The trail gear ram is leaking on the shaft at seals....3 days old and its puddling a little here and there...explains then constant need to burp because of air causing pump wine...
    Yes my ram is horizontal with tie rod there's no side loading...
    It felt like stock just a smidge better but still having turn issues...noticed it would feel great then like crap..
    So I'll call trail gear tomorrow and get a replacement ram....ehhhhh shit happens not everything cant be perfect therefore there's warranty...lol
    So no love lost at this moment....
  7. Feb 3, 2015 at 1:01 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    nice truck! Good luck on the trail mart stuff!
  8. Feb 4, 2015 at 10:06 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Yeah it cant be all bad...
  9. Feb 7, 2015 at 5:59 PM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Sub'd. Looking great so far
  10. Feb 8, 2015 at 1:32 AM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Have so e good pkcs from KOH...we ran. Chocolate thunder and a few others....truck did good...
  11. Feb 13, 2015 at 8:05 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Bobbed 13" off the bed today...still need to do finish work.
  12. Feb 13, 2015 at 8:07 PM
    slander
    Hickory, NC
    Looks good!
  13. Feb 13, 2015 at 9:25 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Thanks....
  14. Feb 14, 2015 at 7:10 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    Bad Ass look'n rig!
  15. Feb 14, 2015 at 9:30 AM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Damn dude looks sick!
  16. Feb 14, 2015 at 9:39 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Agreed!
  17. Feb 14, 2015 at 9:47 PM
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    I have an 03 dblcab.
    Im living through you right now!!! Lets see pics of your truck running johnson valley. I dont know if Ill ever get down there so you gotta help a brother out!!:)
  18. Feb 14, 2015 at 11:40 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Trying to get the 2 guys info from camp that snapped pics and rode along...as well as there were several people.e at the peanut gallery taking videos and pictures I know for fact some will pop up....
    Usually i get pics but this trip was adrenaline and hammering down...we will be at coral canyon Monday and I'll have some from there then TDS which isn't bad then back to hammers...
    Cant link video of buddy flopping on his lid at backdoor....he rolled hid buggy back over and nailed it.
    I will dig up some...there were enough cameras....I know someone got the made up line at highway 19 in johnson valley as well....
  19. Feb 15, 2015 at 12:34 AM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
  20. Feb 16, 2015 at 6:43 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Let's hear it for bobbed beds lol...was dragging shackles in the dirt and rocks today.
    This ledge is NASTY...pics don't do it justce the left side is a wall and there is a gap ion rocks....i made it but have been denied a few times in the past on this as well as this spot claims axles....and yes left side is sitting non the wall.
