4dr rock swatter....
Discussion in 'Solid Axle Suspension' started by bullcrew, Jan 17, 2015.
  1. Feb 16, 2015 at 6:49 PM
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    very nice DC! Looks really clean...for now:D
  2. Feb 16, 2015 at 6:55 PM
    bullcrew
    bullcrew [OP] Well-Known Member
    travis
    oceanside
    03 quad cab sas
    Thanks....
    Yeah I enjoy it for the moment...it will start to look like a raisin soon....mine always do...so I'll slap some tight armor and protect it where I can without adding a ton of weight....
    We are headed back to hammers again....I came out with minimal damage last week after KOH and yes we ran the hammers...just good line choice and rock gods were good to me....lol only time I've been and walked out almost unscathed.....
    (Rear bumper died, tow hitch, rear corners underneath, rear driveshaft, and dented the frame pretty good)
  3. Feb 17, 2015 at 8:32 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    awesome, someday I want to wheel the hammers. Ive been there for KOH but never with my own rig.
  4. Feb 18, 2015 at 3:49 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Its a fun place for sure....been there several times....and certain obstacles always bring the fun....
    Been fortunate we drive in run the stuff and drive home...all my buddies trailer rigs in.
  5. Feb 18, 2015 at 5:58 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    The more boring side of things...would rather be fabbing but couldn't chat Monday with other guys on trail...---
    .buddy gave me a new cobra 75 cb so Installing it and the race radio in the next week or so.....unfortunently we run a diversified group some have ham some have race and most have cb.....I run ham and have race but neglected a cb , planned on it but had t installed it.
  6. Feb 19, 2015 at 8:44 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Grabbed some shocks for the Toyota....
    The coilovers will be thrown up front minus coils and hardware for now till I link it.
    Bypass will go on rear to control leafs
    King 2.5 triple bypass 7/8 shaft
    King 2.5 coilovers 7/8 shaft
    Fox 4" hydraulic bumps
  7. Feb 20, 2015 at 7:57 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Wow this build just escalated quickly!
  8. Feb 21, 2015 at 1:34 AM
    JonEvans56
    JonEvans56 Well-Known Member
    Andrew
    Dead Truck
    Rust, dents, cracking plastic, oxidized paint...
    Nice build,First time I think I've ever seen a bobbed DC.
  9. Feb 21, 2015 at 8:06 AM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Yeah its gaining steam quick....I will be doing 4wu links fro t and rear very soon....I'll dial this in run it and then I will modify cause its there.....unless I get this totally dialed then maybe just front links....
    I've done leaf set ups oln prerunners in past so I know a little about dialing the progressive nature of a leaf spring...
    The shocks I'll valve Monday or Tuesday...12/15 front and 12/15 rear to start and keep it easy....the bypass should be on pretty spot....and tune with the tubes the front shock may be a little too much rebound for how soft my springs are but I want to add the one leaf back in for a bit more height now that it settled....
    The bumps I'll start out at 200 psi each run it hard and see whats left n shaft till I hit whoops and hard dips....plan is to leave 1/2" of shaft for safety on a "oh $h!t" moment....on the bumps...rear will start out 150psi no weight....
    Fox bumps are from 50 psi to 500psi as far as a workable range....trophy trucks start out at 300 and go from there....
  10. Feb 21, 2015 at 11:06 AM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Subd! You gonna Keep that axle in it when you do links?
  11. Feb 21, 2015 at 12:31 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    I am.....
  12. Feb 21, 2015 at 1:49 PM
    Large
    Large Red
    What did you use to cut the bed?
  13. Feb 21, 2015 at 8:15 PM
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Large, I used a sawzall and 4.5" cut disc.
    Going to box a shock mount into this. The bypass will be mounted by monday
  14. Feb 21, 2015 at 10:32 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Nice build bro, subbed.
  15. Feb 22, 2015 at 7:54 AM
    #35
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    You gonna put the tail gate back on?
  16. Feb 22, 2015 at 8:09 AM
    #36
    bullcrew
    travis
    oceanside
    03 quad cab sas
    For now....
    It will come off once I build out the carrier and rack....the floor will probably bet cut out and sides supported...
  17. Feb 22, 2015 at 8:15 AM
    #37
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Hmm… Im thinking about building a tire gate for mine in place of the tail gate. ill Leave the floor though and do a bed cage/headache rack that will tie into a tight exo cage.
  18. Feb 22, 2015 at 8:25 AM
    #38
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Like my black one I will do side armor tucked against the bed....I do it to my jeeps and Toyota so i can lay em against the rocks...
  19. Feb 24, 2015 at 5:30 PM
    #39
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Started the mounts...all boxxed in and will now work on hydraulic bumps and front coil over mounts...(remove hardware and run em till I link).
    After I get them all mounted I'll finish off the rear cage and all the work....it will all be dialed but spread out too get the shocks on and tuned first...then asthetics.
    The rear will all be tied in so no flex...the angle is vertical and triangulated upper so very little side movement its pretty vertical and column loaded...
  20. Feb 25, 2015 at 11:13 PM
    #40
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Revalved the king bypasses today (12/12) and then cycled it...it moves freely...so hydraulic bumps and front shocks tomorrow and valve them.
    Drops below body line and completely stuffs into wheel well...
    Drives so much better now I'll add some compression on tubes and dial it in after bumps and front are on...
