4dr rock swatter....
Discussion in 'Solid Axle Suspension' started by bullcrew, Jan 17, 2015.
  1. Mar 30, 2015 at 7:29 PM
    #101
    bullcrew
    bullcrew [OP] Well-Known Member
    travis
    oceanside
    03 quad cab sas
    Took the kids to a cabin in big bear hiking wheeling and digging crystals....used the rear cargo area which worked out perfect....did some night wheeling made most of gold mountain in 2wd...used the suspension and speed to keep momentum...lol
    Was a good spring break kids had a 5o5al blast....
  2. Mar 31, 2015 at 11:43 PM
    #102
    bullcrew
    travis
    oceanside
    03 quad cab sas
    So took the old transmission mount out and cut what was left of the rubber mounts off....ground em down threw some 1.5 .120 tube with leaf spring poly bushings in....
    Called dealer and even at shop price the new Mount was too expensive....so after chatting with Brian at 4WU and eric at Yotamasters I made these....
    Knew what I needed to do just called them to see of they knew of any I'll effects long term to doing this...eric has been running g a pro,y Mount tranny and chain end front stock motomounts for 11 years now no issues....good enough for me....
  3. Apr 1, 2015 at 5:15 PM
    #103
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
  4. Apr 1, 2015 at 5:47 PM
    #104
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Yeah the rattle at idle is a bit more than I wanted but its not bad.....I will say that when hammering around square edge hits it doesn't ,make a clunk at all....its a
    Solid and translates the solid feel to speed and handling...
    I may do straps later but not likely ID prefer t keep it all poly and run It hard.
    Also you can run a softer durometer urethane or poly I have a buddy who makes his own and has different densities...this will eliminate a lot of the frame chatter....
  5. Apr 2, 2015 at 8:12 PM
    #105
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Decided to see the rings in blue...so was going to Anodize but as much as mine get smeared on rocks a good coat of metalast
    They are a semi close match to the king shocks....
  6. Apr 7, 2015 at 10:20 PM
    #106
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Cut 7/8" off the tranny mount on TG skid side ,lowering the transmission away from the tunnel....did a 3" hole below tcase for a quick access to the drain so no need to remove skid.
    started rear battery tray (Artec) and made the tubes and started welding...it'll be in place tomorrow.
    Will be a nice finished off look....
  7. Apr 8, 2015 at 9:03 PM
    #107
    bullcrew
    travis
    oceanside
    03 quad cab sas
    So started with a clean area and made a home for the battery....was good to get it out of the front and open it up.....
    Moved the fuse box sideways and against the support to open up....
    Large likes this.
  8. Apr 11, 2015 at 8:00 AM
    #108
    bullcrew
    travis
    oceanside
    03 quad cab sas
    OK....took it out to a small spot to finally gauge the suspension and handling....its time to start thinking about a cage....its fast enough now that its a bit too easy to keep speed going Into stuff and feel comfortable....it floats the faster it goes...
  9. Apr 11, 2015 at 5:13 PM
    #109
    bullcrew
    travis
    oceanside
    03 quad cab sas
    So added some better terminals a battery cut off switch and a starter cutoff as well...I wired the alarm of another constant power well as fuse box for memory so no loss there and someone can't cut power to mess with it...
    I will put a cap for the battery switch that will keep it from being touched while daily driving then wheeling I will open access to t for quick shutoff should I roll or have a issue....
    Also took it out on a little rougher run and its about time for a cage...its definently smooth the faster it goes and floats over stuff....
  10. Apr 13, 2015 at 10:32 PM
    #110
    bullcrew
    travis
    oceanside
    03 quad cab sas
  11. Apr 16, 2015 at 9:12 PM
    #111
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Got some new welding goggles from miller for those hard to see spots.
  12. Apr 19, 2015 at 12:53 AM
    #112
    bullcrew
    travis
    oceanside
    03 quad cab sas
  13. Apr 23, 2015 at 4:15 PM
    #113
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Stuck a yaesu ft-8800r ham radio in, going to mod the box.....
  14. Apr 26, 2015 at 9:16 PM
    #114
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Made a roof rack and a light Mount to it for the 42" led light bar
  15. Apr 26, 2015 at 10:38 PM
    #115
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Went and did some Wheeling today....
  16. Apr 27, 2015 at 5:37 PM
    #116
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Truck is looking great man!! :thumbsup:
  17. Apr 27, 2015 at 8:22 PM
    #117
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Thanks...pretty amazed at its capabilities....was worried leafs would hinder me...
  18. Apr 28, 2015 at 12:38 AM
    #118
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Wired the lights up today then took it out to aim them...
    1 main reason I wanted to mount the light back a bit was to eliminate light scatter in dust and hood right on front of the windshield. As yo can see the hood is dark....which s a good thing...no matter what color your rig is its white and or dusty when its lit up by dust and light scatter right in front of you....
    By setting it back it gives you a area of shadow to eliminate the scatter right in front of the windshield....
    Iva had em up front and laid back on my old race track and prerunmers...from experience I'll set them back or make a shadow blind to make a dark spot right front of me.
    Large likes this.
  19. Apr 28, 2015 at 2:50 AM
    #119
    Large
    Large Red
    So much pron in this thread..
  20. Apr 28, 2015 at 8:39 PM
    #120
    bullcrew
    travis
    oceanside
    03 quad cab sas
    .?pron...lol
    Porn!!!
    I see your spellcheckfu is strong.....as is mine...lol constantly misspelled or messed up words...my tablet here used all day and sits in the shop with me doing business...its seen a lot of use...
