4dr rock swatter....
Discussion in 'Solid Axle Suspension' started by bullcrew, Jan 17, 2015.
  1. May 30, 2015 at 5:57 PM
    #141
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Whats the frame height on this thing? I'm thinking about cutting mine up soon and shortening the wheelbase ~5", inboarding the rear springs, and lowering it a few inches.
  2. May 31, 2015 at 11:43 PM
    #142
    bullcrew
    bullcrew [OP] Well-Known Member
    travis
    oceanside
    03 quad cab sas
    27" on 40s....
  3. May 31, 2015 at 11:59 PM
    #143
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Broke a leaf spring today so now deciding if I should just link it....will decide tomorrow its late and I'm tired...
    Also grabbed Toyota factory full float 1 ton axles from a Buddy.. they came off a dually Setup and have some uniqueness to them.
    The housing is this thicker as is the tube section, they were early housings BT house a 8" ring gear set up. They have plates in center section for strength as well as the built on has ARB locker 4:88 gears (which need to be 5:29), , fj80 hubs and Chevy calipers and rotors...
    Its still a 8" but the housing is ally thicker and the axle is 63" wide
    presto likes this.
  4. Jun 1, 2015 at 6:34 AM
    #144
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Cool just trying to compare. I'm 27.25" in the rear and 28" in the front on 39.5's
  5. Jun 1, 2015 at 6:57 AM
    #145
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Why inboard the rear springs? My truck is 25.5" to the frame on 40's.
  6. Jun 1, 2015 at 8:44 AM
    #146
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    My truck has no weight in the rear so the springs don't move like they should.
  7. Jun 1, 2015 at 3:53 PM
    #147
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Not too mention inboard they will move quite a bit more and easily as you increased the axle leverage...so less shaft more articulation...with that ID outboard the shocks to dampen they roll a bit...
  8. Jun 1, 2015 at 4:24 PM
    #148
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah that's the plan. Basically going to move the spring mounts in 3" per side and mount the shocks were the spring mounts were.
    bullcrew[QUOTED][OP] likes this.
  9. Jun 2, 2015 at 6:22 AM
    #149
    bullcrew
    travis
    oceanside
    03 quad cab sas
    ear Head, post: 10315192, member: 89921"]Yeah that's the plan. Basically going to move the spring mounts in 3" per side and mount the shocks were the spring mounts were.[/QUOTE]
    Intrested to see....
    Almost bought the 3 link yesterday just to slap on for a quick fix....
  10. Jun 2, 2015 at 6:41 AM
    #150
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    what 3 link were you lookin at?
  11. Jun 2, 2015 at 6:57 AM
    #151
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Almost bought the 3 link yesterday just to slap on for a quick fix....[/QUOTE]
    Yeah man go check my thread to see how it turns out. I'm going to try and get everything cut off
  12. Jun 2, 2015 at 7:08 PM
    #152
    donahoo
    donahoo Member
    alabama
    tacoma 6" 35s-20s
    6" fabtech, 35s/20s, 4:88s, k&n intake, magnaflow
    are you happy with your trail gear set up? I'm in process of SAS & any advice would be appreciated! thanks & nice rig!
  13. Jun 2, 2015 at 8:16 PM
    #153
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Was going to do the trail gear but since I plan on doing a fuel cell and chopping off the whole rear frame ilk just wait and 4 link it.....
    As far as happy...hell yeah....so a spring busted this thing has been to hammers twice, corral canyon 6+ times, twin oaks 6 or 7 times, coyotes 1 time, tierra del Sol and we have climbed and ran about every tail including trying back door (first night didn't want to break so close though), sledgehammer, chocolate thunder, sos, claw hammer, several other lines there...been airborne several times, ran whoops 60+ mph several times and flat out worked this thing...
    So yeah I bought another set of springs and slapping them in tomorrow....worth every penny...realize I have ran all the big boy trails with exception of a couple and hammered down....YES I AM HAPPY.....very Impressed at how this thing works and so is a lot of other people....
    Only reason I'll link is its headed to straight crawler and because I can.....I want to chop rear and shorten ts departure so I need to link it....if I don't I will still be very happy and money WELL spent....
  14. Jun 2, 2015 at 8:18 PM
    #154
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Yeah man go check my thread to see how it turns out. I'm going to try and get everything cut off[/QUOTE]
    I will....I like to follow builds, fun to watch and see where stuff goes....
  15. Jun 3, 2015 at 5:53 PM
    #155
    donahoo
    donahoo Member
    alabama
    tacoma 6" 35s-20s
    your list of rides is very impressive... I'm ready to start cutting now!!
  16. Jun 9, 2015 at 9:09 PM
    #156
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Well boring stuff.....truck runs hot on big hills acts like a flow issue so went ahead and did Timing belt, pulleys, tensioner , water pump, thermostat and flushed whole system...added 1 quart Toyota red coolant, 1 container water wetter and 2 gallons distilled water...
    Threw on new spring packs in rear and bushings, rerouted the transmission lines to cooler and out of radiator,
    No real cool stuff just the important stuff....
  17. Jun 10, 2015 at 8:53 PM
    #157
    bullcrew
    travis
    oceanside
    03 quad cab sas
    So for all those pit bike guys or wheelers with kids and small bikes....
    Last 2 times out to hammers couldn't bring my kids crf 50 for him and felt bad....so made him a removable carrier...not done but myself 240 and buddy 250 bounced on it and it didn't budge...
    Cross between Chromoly and aluminum track super light....hitch pins on both sides on top of frame, I'll triangulate a bar down to the top of the tube.
    This still needs end caps welded on and eyelets for straps to hook to...
    This carrier will have a storage spot underneath it as well....and I will make another rack that uses both hitches like this but has a cargo area....so like the swiss army of carriers....
    You can see the notch pin hole and where it slides in by brake light on top of frame rail.
    Nicks4x4LT likes this.
  18. Jun 10, 2015 at 9:22 PM
    #158
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    You need an exo cage and a couple gopro`s :thumbsup:
  19. Jun 10, 2015 at 9:48 PM
    #159
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Nah....i dont need to rewind and watch my flops lol....
    I was there when it happened......
    Yes i bought 60 feet of dom but going to use it on a buggy and ill use chromoly for weight savings if i decide to make it...i have a design simple that im thinking about...
  20. Jun 10, 2015 at 11:59 PM
    #160
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    You need the cameras to show TW this monster in action
