4G AT gearing changed to 3.58
Discussion in '4th Gen. Tacomas (2024+)' started by Dbarffish, Nov 28, 2023.
  1. Nov 28, 2023 at 2:11 PM
    Dbarffish
    Dbarffish [OP] Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I just saw this. This is not good. More regearing. Give a 25% boost in torque and then take the performance away with a gear change.
  2. Nov 28, 2023 at 2:18 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    Ok. Do you know the other part of this equation? The 8AT gear ratios.
    Hogleg918 likes this.
  3. Nov 28, 2023 at 2:22 PM
    Dbarffish
    Doug
    Montana
    Stock
    No. Just was watching all the posted you tubes and one mentioned this. I’m trusting he is accurate. You have a good point too
  4. Nov 28, 2023 at 2:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    One of the videos said the Manual Transmission kept 4:30 ratio.
  5. Nov 28, 2023 at 2:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's amazing to me that YouTube has become the authority of things not yet seen.
    BTW, the 3.58 will give a bit more MPG when running hwy in whatever gears are OD.
    So there is your 'why'.
    Phlogiston likes this.
  6. Nov 28, 2023 at 3:38 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    You cannot say what the performance change is without knowing the transmission ratios.
    Jeff Lange and Hogleg918 like this.
  7. Nov 28, 2023 at 3:54 PM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Exactly this, 1st gear in 2023 is 3.60. With 2 added gears I could see 1st gear being 4.10 or more.
    shakerhood likes this.
  8. Nov 28, 2023 at 4:31 PM
    Dbarffish
    Doug
    Montana
    Stock
    If it’s the Highlander transmission - 1st gear is 5.52 much lower than existing V6 3.6
    Hogleg918[QUOTED] likes this.
  9. Nov 28, 2023 at 5:02 PM
    shakerhood
    Southern Ohio
    The specs say 4.413 is AT 1st gear.
  10. Nov 28, 2023 at 5:06 PM
    Hogleg918
    Oklahoma
    Your Google skills are superior, I looked and couldn’t find that. 2 overdrives with 6 being direct?
    shakerhood[QUOTED] likes this.
  11. Nov 28, 2023 at 5:08 PM
    shakerhood
    Southern Ohio
    .793 and .651 are the 2 overdrives and 6th is 1 to 1.
  12. Nov 28, 2023 at 5:29 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    GBR and shakerhood like this.
  13. Nov 28, 2023 at 5:41 PM
    GBR
    19 TRD OR
    Thanks for grabbing that. Those MT numbers look like a nice improvement to me.
    shakerhood and BLtheP[QUOTED] like this.
  14. Nov 28, 2023 at 5:58 PM
    BLtheP
    Plano, TX
    Yeah, should be good. They’re exactly what I want for my regeared V6. Gonna wait and see if there’s a way I can adapt that trans to my truck. Pretty sure it’s the RC60F and if so, the most that would need to be done would be an input shaft swap. Time will tell.
    GBR[QUOTED] likes this.
  15. Nov 28, 2023 at 7:00 PM
    shakerhood
    Southern Ohio
    Looks like the Manual Reverse gear is improved over the 3rd Gen.
    6MTPro likes this.
  16. Nov 28, 2023 at 10:16 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Yeah and 1st gear manual in 4LO will be a beast
  17. Nov 29, 2023 at 4:30 AM
    Dbarffish
    Doug
    Montana
    Stock
    MT looks good for first and reverse. 4-5 looks like a big jump but doable.
  18. Nov 30, 2023 at 6:52 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    What is the new tire size diameter for 4G trucks? Same for all trim levels too?
  19. Nov 30, 2023 at 7:20 AM
    BLtheP
    Plano, TX
    From what I saw, 245/70R17 for SR/SR5, 265/70R17 & 265/65R18 for OR and Sport and probably limited, and then some form of 33's for Trailhunter and Pro.
    Supposedly there is an option for 33's on the OR, or you can slap them on yourself. I don't know if that means 285/70R17 or what. I'm curious what the wheel width and offset specs are.
    specter208[QUOTED] likes this.
