4h at 80mph?? ‍♀️
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LillyAZ, Nov 3, 2021.
  1. Nov 3, 2021 at 3:21 PM
    LillyAZ
    LillyAZ [OP] New Member
    Lilly
    Arizona
    2013 access cab 4x4
    After market fox shocks
    I have a 2013 and I let my boyfriend drive me home from Vegas while I was alseep. He drove a good 100 miles or more before I woke up and asked him to pull over bc my truck felt like it was driving weird. Immediately upon switching seats I noticed I was in high 4. Now my truck has a weird wobble at 55- 70 mph in 2 hi. My question is, what is the potential damage that drive could have caused?
    FishnTx likes this.
  2. Nov 3, 2021 at 3:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Whelp, first, sounds like you need a new BF if he couldnt figure out what the bright green dash light was.
    If driven in a straight line there shouldnt be a problem. But if turns etc were taken things will bind up and cause excessive wear/damage
  3. Nov 3, 2021 at 3:29 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Hmmmm.......something doesn't add up....... 4 hr at 80 mph would be nearly 320 miles. 100 miles in 4 HI at 80 mph on dry roads is not particularly sharp. Time at that speed and distance is about 1 hr, 15 minutes.
    But I don't think it would cause "..a weird wobble at 55- 70 mph in 2 hi" Suggest to check the wheel balance and the front suspension components and the lug nuts. Its more likely that a wheel weight has been lost or some component is loose.
    SR-71A and AJKlug1 like this.
  4. Nov 3, 2021 at 3:38 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Likely none. All the bits in the 4wd system are spinning anyway and when going mostly straight there isn't much of a binding force developed (lots of city street manovering and you'll get binding...you can feel it as drag in the drive train and hear it as tires scrub)
    My bet would be inspect tires and wheels first.
  5. Nov 3, 2021 at 3:47 PM
    LillyAZ
    Lilly
    Arizona
    2013 access cab 4x4
    Definitely need a new boyfriend lol. So those speeds in 4h on a straight away should be okay? My wobble could very well be from a number of factors I just wanted to make sure nothing is seriously damaged in my transfer case or anything like that. (4h =4high)
  6. Nov 3, 2021 at 3:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have no abnormal noises and the 4wd engages/disengages correctly you should be fine.
    The shimmy is most likely something unrelated to the 4wd system but it would still be a good idea to raise the truck up and inspect everything.
  7. Nov 3, 2021 at 4:22 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Not supposed to be in 4X4 on pavement at any speed. While theoretically you don't do significant damage as long as you're driving in a straight line you are pushing the transfer case, U-Joints, and other parts beyond what they are designed for. And I'm betting that at some point the wheels were turned to enter a business, or your home which can cause major damage. While it may not have broken today you, or someone, will be replacing expensive parts sooner than they should be.
    Stuff like this is why I won't buy used 4X4's. There is a good chance the next owner may end up paying for this.
    GarlicFarts likes this.
  8. Nov 3, 2021 at 4:31 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    BF or BFF? :facepalm:
  9. Nov 3, 2021 at 4:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Chances are that everything is fine.
    The front drive shaft definitely got a workout at 80 mph. Maybe, just maybe there is a remote possibility the u-joints could cause the wobble. But I seriously doubt it.
    Like Dm93 said, take a look underneath.
    If it looks good, drive it.
    And teach your boyfriend what switches go to what, and what the dash lights mean. Don’t be too hard on him. We all make mistakes.
  10. Nov 3, 2021 at 4:40 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You can drive as fast as you want in 4H. Given that speed I assume it was all highway miles, and the amount of turning and thus binding involved would be a complete non-issue. Guessing you have an unrelated issue, or just paying attention closer after the incident.
    :facepalm:
    U joints and CVs not suppose to spin? Unless you've bind up the tcase turning very sharply, it's not going to hurt anything driving on pavement in 4H.
    tacoman45, Junkhead, SR-71A and 3 others like this.
  11. Nov 3, 2021 at 4:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Very very likely ujoints.
    TnShooter likes this.
  12. Nov 3, 2021 at 5:40 PM
    nd4spdbh
    SoCal
    The tcase, front diff etc are FINE at those speeds in a straight line at highway speeds to long as tires are rotated to wear evenly front and rear. Its when turning and binding on high traction (pavement) surfaces that problems arise.
    Hell, drove a few days on just FWD with no rear driveshaft as I did some work to it, just was nice to the gas, zero issues 100k miles later.
    Hyperbarics and Junkhead like this.
  13. Nov 3, 2021 at 5:45 PM
    TheDude94
    TheDude94 Basement Operator
    Mom's basement
    2008 TRD Sport 4x4
    Workin progress...
    Driving my 3/4 ton diesel with my ATV in the back going 70 MPH down the highway for a couple miles in 4H before I remembered. Truck is fine. Granted its a solid front vs IFS but I've done 50 MPH down dirt roads in my taco and its been fine.
    I'm pretty sure you're fine... your BF on the other hand...
    Junkhead likes this.
  14. Nov 3, 2021 at 6:01 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You’re fine. Don’t listen to MarshallR. He bought a 4x4 and is scared to use it.
  15. Nov 4, 2021 at 11:26 AM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    Probably just tires worn a little unevenly from the high speed journey in 4H? Maybe try rotating the tires and see if the wobble goes away as a first test.
    My wife drove my truck to work everyday for a week a few years ago when I was away and out of phone contact. My guess is she was trying to turn on the headlights in the dark, and not being familiar with the control locations, she accidentally put it in 4H. Later in the week when I had a chance to talk to her she told me something was wrong with my truck because it bucked and jumped everytime she turned or tried to maneuver in the parking lot. She drove it like that for a week in stop and go traffic to and from work. I was concerned damage was done. I changed the transfer case and diffferential fluids and there was no sign of anything amiss. That was about 4 years ago and my truck hasn't shown any signs that anything is wrong. I wouldn't worry!
  16. Nov 4, 2021 at 11:31 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Toyota specifies a max speed to engage 4wd, I haven't seen a specified speed to not exceed in 4wd... granted driving safely may lower any specified speed.
  17. Nov 4, 2021 at 1:28 PM
    Dubiousveracity
    2018 TRDOR DCSB MT
    none
    This here is key, they specify 50 as the maximum to engage (as in actuate) 4wd...they don't then limit the vehicle to 50...OP's 4wd system is morre than likely just fine.
  18. Nov 4, 2021 at 1:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    This exactly.
  19. Nov 4, 2021 at 1:38 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    pdaddy, Thatbassguy and Green Jeans like this.
  20. Nov 4, 2021 at 1:46 PM
    RepoMarket
    RepoMarket Well-Known Member
    Scott
    Lehigh Valley, PA
    2017 DCSB SR5
    Eibach Pro / ICON Leafs
    lmfao
    Thatbassguy likes this.
