4H Pull
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joelt, Oct 8, 2013.
  1. Oct 10, 2013 at 7:06 PM
    #61
    joes06tacoma
    Joe
    Central Coast, CA
    Correct.
  2. Oct 10, 2013 at 7:08 PM
    #62
    joes06tacoma
    Joe
    Central Coast, CA
  3. Oct 10, 2013 at 7:12 PM
    #63
    joelt
    joelt [OP] Well-Known Member
    Joey
    Anchorage
    '17 TRD Off-Road
    Had my alignment on 23 May 13:
    Current measurements:
    Left front:
    Camber .3
    Caster .8
    Toe .05
    Right front:
    Camber .3
    Caster .3
    Toe .04
    Front total toe .09
    Front steer ahead 0.0
    Left rear:
    Camber -.6
    Toe .31
    Right rear:
    Camber 0.0
    Toe -.34
    Rear total toe -.03
    Rear thrust angle .32
  4. Oct 10, 2013 at 7:15 PM
    #64
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
  5. Oct 10, 2013 at 7:33 PM
    #65
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
    Aight...so long story short: I get a solid 4WD light (no flashy flashy), I can feel confident that EVERYTHING engaged as planned.
  6. Oct 10, 2013 at 7:36 PM
    #66
    Konvict KROG
    Louisiana
    Yes sir. as far as i know, never had a false alarm yet
  7. Oct 10, 2013 at 7:50 PM
    #67
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
    I appreciate all the feedback, and hopefully someone else besides me learned something.
    Ask my wife, I'm bad (OCDish) about resolving small squeaks, electrical shorts, etc. If something doesn't operate as intended, I have to know why and nip it in the bud. However, this was slightly beyond me. I'm not too familiar with the ADD, obviously, but feel much better about it considering the feedback provided. With all the monitors, sensors, and electrical tolerances, it's highly likely I'd get some sort of fault indication if something wasn't working as it should, especially within the 4WD system. The geometry issue brought on by the lift will just be something I have to deal with, unless a future alignment resolves the issue.
  8. Oct 10, 2013 at 7:53 PM
    #68
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Your Caster is terrible, you want ~2.5, and 3 is ideal. I bet the .3 on the right is not helping the pull, if not causing it all together, but I may be wrong. New UCAs wil get you to 2.5 or higher in caster.
  9. Oct 10, 2013 at 8:27 PM
    #69
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
    So, what part do you think may be causing the pull...how low the casters are or the difference in the L and R?
  10. Oct 10, 2013 at 8:35 PM
    #70
    Konvict KROG
    Louisiana
    I am no expert on alignment, never learned it
    doording and goufcustom both will hopefully fix me if i say somehting wrong here,
    but i would think the low caster is what makes it amplified, and the difference in the casters from side to side is what makes it "favor" one side
    Im pretty mechanically smart, but i may be using the wrong terms here since im not an alignment guy.. Just trying to make sense and help make sense :)
  11. Oct 10, 2013 at 8:39 PM
    #71
    Konvict KROG
    Louisiana
    ^ but ive driven some way bad and never had much issue. (at least the same as you describe)
    i bent the front axel on a 52k pound truck, a long way, and the tie rod as well (4-6 inches of toe) now that was a truck that had bad alignment and pulled :)
  12. Oct 10, 2013 at 9:02 PM
    #72
    Konvict KROG
    Louisiana
    oh ok, you two just sounded more knowledgeable :)
    So your in the same boat as me :)
  13. Oct 10, 2013 at 10:26 PM
    #73
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Needs more cowbell.
    ...I mean caster.
  14. Oct 10, 2013 at 10:39 PM
    #74
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
  15. Oct 10, 2013 at 10:43 PM
    #75
    bullaculla
    Da big big island!
    Mine is at 2.8 degrees and very stable. Low caster makes the truck "wander" and maybe being half a degree off from each other could possibly make it amplify the torque steer as DoorDing and others have said.
  16. Oct 11, 2013 at 6:20 AM
    #76
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
    New UCAs aren't in the budget just yet, but I did find this, FWIW:
    "Cross caster difference from right side to left side will cause a pull to the side with the least positive caster."
    https://www.uvu.edu/auto/pages/lessons/caster_angle.html
    Totally supports what DoorDing and others have said. Funny thing is - the thing drives like a champ in 2WD, straight as an arrow...and no 'wobble.' Of course, I've only had her up to ~75-80 mph. Dynamics do change when you've got 4 wheels pulling, vice 2. I'm heading to a reputable alignment shop this AM to discuss the issue and see what they can do about equalizing the L and R caster. I'd assume the caster is maxed, but we'll see soon.
  17. Oct 11, 2013 at 6:34 AM
    #77
    Konvict KROG
    Louisiana
    Right, even if its maxed, and if it was super screwed up. they should at least find the happy medium that matches.. Well a little different as far as i understand because the way the roads are designed to lean for watershed.. but, purely on guesswork, it just looks odd to have such different numbers i guess. who knows, i am cert. loopy.
  18. Oct 11, 2013 at 6:38 AM
    #78
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
    If caster delta does create pull to the side with the lower value, you'd think the L caster value would be slightly lower to compensate for road crown. My L is .5 deg higher.
  19. Oct 11, 2013 at 6:46 AM
    #79
    Konvict KROG
    Louisiana
    it must be my over tired brain from being up all night, i remembered a way off number.
    I dont think .5 degrees is or would be that dramatic.
    Im curious what the pros say!!
  20. Oct 11, 2013 at 6:58 AM
    #80
    joelt
    Joey
    Anchorage
    '17 TRD Off-Road
    L is .8 and R is .3. I'm curious as well!
    Up all night? What do you do?
