4hi DRY PAVEMENT STRAIGHT LINE LOW SPEED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Claudiomartinof, Jun 8, 2019.
  1. Jun 8, 2019 at 10:04 PM
    Claudiomartinof
    Claudiomartinof [OP] Well-Known Member
    2019 TRD OFF ROAD 6MT
    As the title says, I live in Miami, FL and I just bought a trd off road 4x4 (my first 4x4 vehicle).
    The users manual indicates to drive at least 10 miles a month on 4hi to keep all components lubricated.
    What does a person like me that does not off road as often do to keep everything lubricated as the manual says?
    Can I engage 4hi on my relatively calm neighborhood and drive DEAD straight for 5 blocks at low speed (max 30mph)? Will this damage my truck? Why? If I’m not turning AT ALL i don’t see how am I damaging the vehicle. Please explain. Please don’t be a dick... thanks in advance.
  2. Jun 8, 2019 at 10:05 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Perfectly safe to do what you’re asking.
  3. Jun 8, 2019 at 11:42 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    All good. I do this all the time when I don’t have a chance to get off road.
    It’s also not a bad idea, in an empty parking lot, to actuate into 4-lo and hit your rear locker once in a while to keep those actuators free. Again, in a straightish line. Sometimes you have to weave a little to get the locker to lock.
  4. Jun 9, 2019 at 12:00 AM
    eon_blue
    Azusa, CA
    You can go on a 100mph police chase in 4hi on pavement as long as you keep your direction straight. Potential damage only occurs when you bind up the drivertrain. As long as you stay in a relatively straight line you'll be fine.
    BartMaster1234 and mcharfauros like this.
  5. Jun 9, 2019 at 12:44 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    What about a road that has some slight curves in it. US1 in my area marked in red. Speeds between 60 and 65 max.
    skiergd011013 likes this.
  6. Jun 9, 2019 at 12:47 AM
    eon_blue
    Azusa, CA
    I wouldn't risk it personally but in all honesty you'd probably be fine. I drove over 100 miles down a stretch of highway this past winter that was probably 75% covered in snow/ice...with stretches of dry areas in between. I was in 4hi the entire time and never had anything bad come of it.
    At higher speeds you're safer taking gradual turns in 4wd than you are taking tighter turns at low speed.
    tonered likes this.
  7. Jun 9, 2019 at 12:47 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's fine man. Avoid parking lot turns that's all.
    TacoManOne and wood714[QUOTED] like this.
  8. Jun 9, 2019 at 1:02 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    @hiPSI is correct. Avoid turning tight and you’ll be fine, normal driving and slight bends in the road on dry pavement won’t be a problem.
    Claudiomartinof[OP] and wood714 like this.
  9. Jun 9, 2019 at 1:03 AM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Done great multitudes of parking lot turns in my Jeep in 4HI on the beach. I'd think the sand would give before anything broke.
    Way some talk about these trucks, I wonder. I'm talking 90 degree hard turns at parking speeds.
  10. Jun 9, 2019 at 1:42 AM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    You can do parking lot turns on the beach, I think the point is not on pavement where you have high traction.
    tonered, wood714[QUOTED] and BSFord like this.
  11. Jun 9, 2019 at 1:52 AM
    Junkyardjake
    Junkyardjake New Member
    Jake
    Spokane,WA
    2006 4x4 4.0 M/T access cab
    K&N intake, Spyder front projector+ led / rear led lights,17" aft blacked out wheels w/Toyo A/T tires
    I live in the northwest and can tell you that my 2nd gen doesn't mind driving in 4HI at 60mph on the highway and does just fine at lower speeds around daily driving turns (even a little drifting) on slick surfaces. Also have done light wheeling in my truck and asides from my aftermarket tires rubbing a bit on bumps while turning sharply does just fine. 4LO is a bit bindy on sharp turns but thats to be expected with almost any 4x4
  12. Jun 9, 2019 at 9:26 AM
    Claudiomartinof
    Thanks for the feedback. I’m confident now that I won’t damage anything as long as I’m going straight.
  13. Jun 9, 2019 at 9:39 AM
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    No problem going straight. If you’re worried, wait till it’s raining and there is reduced friction to avoid stressing the drivetrain.
    Claudiomartinof[OP] likes this.
  14. Jun 9, 2019 at 9:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You don't need to get 10mi in all at once. I get a couple miles per week on the mile-long straight section on the way to work.
  15. Jun 9, 2019 at 9:47 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If you've got a relatively straight road in your neighborhood just engage 4wd on that section a few times a month and you should be fine
  16. Jun 9, 2019 at 10:20 AM
    Claudiomartinof
    I take a 3 mile DEad straight stretch of road with traffic lights every day (the famous “Calle ocho” here in MIA). so if I just do it once a week I’m good.. 12miles per month...
    tonered and US Marine like this.
  17. Jun 9, 2019 at 10:25 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    ha, I have family right there. do A1A from flagler to ormond. 10 miles of straight road. Although us1 only has gradual curves. Have you done SR 11, between bunnell and deland? That road is beautiful. My sister and i did that this spring. Nothing but farm, ranch, and forest for over an hour.
  18. Jun 9, 2019 at 10:31 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I do the same with my 3rd gen. Get some slight binding going around switchbacks up to Schweitzer to go skiing and if I turn too tight in a parking lot in the winter.
  19. Jun 9, 2019 at 10:34 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Yes !!!!
  20. Jun 9, 2019 at 1:25 PM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    That's one of my favorite bike rides...11 to 40 thru the Ocala National Forest.
    US1 to 204 to 207 to 13 along the St. Johns River to 214 into St. Augustine is another good ride.
    skiergd011013[QUOTED] likes this.
