4Hi grinding during deceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by owen06, Feb 10, 2011.
  1. Feb 10, 2011 at 5:06 AM
    owen06
    owen06 [OP] Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    I have an 09 with a 6" Fabtech lift. I noticed it started yesterday, never before, but when i switch into 4hi and lo, there is a grinding in the front end somewhere but only when I am decelerating, not when I speed up.
    It is pretty cold and snowy here, not sure if that has something to do with it. I checked out the CV shafts, no movement, but the front drive shaft has maybe 1/4" movement where it meets the front diff.
    I had the gears changed with the lift 8 months ago, but this just started. Can gear teeth become un-sync'd?
  2. Feb 10, 2011 at 7:32 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If they set up crappy, yes. Front is PITA to set it up. and prone to loose its setup if anything was not up to the spec. I would get that checked soon.
