4hi manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jvitangcol, Jun 11, 2018.
  1. Jun 11, 2018 at 9:23 AM
    jvitangcol
    jvitangcol [OP] Active Member
    Jeremy
    2017 Tacoma TRD Offroad 4X4 MT
    So I have a 2017 TRD off-road manual, I went to climb a hill and didn’t have enough power to go up and had to switch it to 4lo. But my brother has a automatic and was able to go up on 4hi with no issues.
    So every time I go uphill do I have to put it in 4lo to climb?
  2. Jun 11, 2018 at 9:30 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    You should have been able to do it even better than the auto tranny - your gear ratio is lower! Did you try 1st gear or 2nd.
    shakerhood likes this.
  3. Jun 11, 2018 at 9:30 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Why did you think you didn't have enough power?
  4. Jun 11, 2018 at 9:32 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    What motor do you have?
  5. Jun 11, 2018 at 9:33 AM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    Yes, autos have the benefit of the torque converter that allows some slippage between the transmission and engine. At low speeds they aren’t connected directly but through a drum of fluid and fan-like blades. On a manual trans you really need to pay attention to what lies ahead and make sure you’re in the right gear.
    tonered and 0uTkAsT like this.
  6. Jun 11, 2018 at 9:44 AM
    jvitangcol
    Jeremy
    I was in 1st gear and as I was climbing the rpm would drop then stall. Before I switched to 4lo, I started it back up, put the ebrake and started to ride the clutch until I got at 2000 rpm, once I release the ebrake and let go of the clutch, the rpm would drop and I would stall. Then I switched to 4lo and it was a easy climb
  7. Jun 11, 2018 at 9:45 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I can assure you, it's your driving, not your manual!
  8. Jun 11, 2018 at 9:46 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    I use 4lo for just about anything uphill and offroad now
    TACORIDER and AdventureKid like this.
  9. Jun 11, 2018 at 9:50 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    It's got the power. You just stalled it. Might as well go to 4Lo if you're gonna be slow crawling though. Will be easier and less wear on the clutch.
    02Duck, tonered and 0uTkAsT like this.
  10. Jun 11, 2018 at 9:52 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Maybe your brother used his Crawl Control, which the manuals certainly don't have.
  11. Jun 11, 2018 at 9:56 AM
    jvitangcol
    Jeremy
    He didn’t used crawl just 4hi
  12. Jun 11, 2018 at 9:57 AM
    jvitangcol
    Jeremy
    Would having the AC on full blast affect my power that much
  13. Jun 11, 2018 at 9:59 AM
    jvitangcol
    Jeremy
    V6
  14. Jun 11, 2018 at 9:59 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    This cracked me up!!! :rofl:
    CANYONERO and 0uTkAsT[QUOTED] like this.
  15. Jun 11, 2018 at 10:34 AM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    This.
    Even most of the pro drivers use autos in their custom rock crawler rigs where they can choose any transmission.
  16. Jun 12, 2018 at 5:39 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Gear ratio lower in manual - why this worked.
  17. Jun 12, 2018 at 5:43 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Wait... you were wheeling with your AC on?
    That's against bro code bro, must open windows so mud and dirt fly in. Then you get to go to the car wash and show off your new pin stripes..just sayin.
    e6400ultra likes this.
  18. Jun 12, 2018 at 7:11 AM
    Smk8609
    Smk8609 Well-Known Member
    2016 dcsb trd sport 4x4
    I do feel like this engine lacks the low end torque to climb in 4hi without roasting the clutch a bit - i have always driven manuals and definitely struggle offroad with this one a bit more than my past tacomas. I use 4lo much more often than i used to, and have just accepted that i will be replacing the clutch earlier than i have in the past. I usually have to run 4lo on the beach or pulling the boat out of the water as well (its possible, but that sweet smell of clutch just isnt for me).
    doublethebass and 0uTkAsT like this.
  19. Jun 12, 2018 at 7:14 AM
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    You clearly don't understand how a torque converter works.
    Gearing doesn't mean shit compared a torque converter and its ability for torque multiplication.
    jowybyo likes this.
  20. Jun 12, 2018 at 7:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is nothing wrong with using 4Lo. There is a lot of speed range there also. 6th gear is almost 60mph at redline. Half that is more than enough for most anything. The crawling pace of 1st at idle is what makes it all great compared to the AT, not to mention the easy coasting descents with the MT.
