4hi manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jvitangcol, Jun 11, 2018.
  1. Jun 12, 2018 at 4:38 PM
    #41
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I never lie.
    BassAckwards and brich999 like this.
  2. Jun 12, 2018 at 4:40 PM
    #42
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Ahhhhmmmmm, not sure what to say.
    Internet Logic for the win
  3. Jun 12, 2018 at 5:09 PM
    #43
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    There's a truck in my area that has a big sticker covering the back window that says "real trucks don't have spark plugs"
    I want to put a note on it that says "real trucks have 3 pedals"
    The truck in question is exactly what you would expect:
    6"+ lifted Chevy crew cab
    6' bed w/huge tool box so 4' of usable space
    35's on 22" black/chrome wheels
    8" diameter exhaust
    tonered and EatSleepTacos like this.
  4. Jun 13, 2018 at 8:06 AM
    #44
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    awwww you do need a hug :(
    I know in you're mind you're some sort of alpha male "triggering snowflakes"... reality is you're just revealing how lonely and sexually frustrated you are :rofl:
    And btw if you "could care less" that means you actually care :thumbsup:
  5. Jun 13, 2018 at 8:46 AM
    #45
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    LOL i just enjoy trolling online, apparently it works here too.
    No frustration here.
    I couldn't*
  6. Jun 13, 2018 at 3:42 PM
    #46
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Erm, of you're going to correct someone, you should probably double check yourself.
    *your
  7. Jun 13, 2018 at 3:46 PM
    #47
    Bishop84
    Bishop84 Well-Known Member
    Auto will always be better for trucks, torque converters are miracles in a can. They multiply torque and make every gear more usable. Water doesn't affect them like a clutch in a water crossing.
    The problem with autos in 4hi is they can do a whole trail as such but they converter creates shit tons more heat.
    I wish it was easier to switch from 4hi to 4lo like the older trucks, but for now we do what we must.
  8. Jun 13, 2018 at 5:20 PM
    #48
    jowybyo
    Joe
    Baltimore, MD
    FJ transfer case swap. Look it up. It’s pretty easy.
  9. Jun 13, 2018 at 5:34 PM
    #49
    Bishop84
    I wanted to do with it with my 16 when I had it, but it was a lease haha. Didn't make sense.
    Just wish the "offroad" was like the old FJ and 4runner that came with the levers.
  10. Jun 13, 2018 at 5:50 PM
    #50
    jowybyo
    Joe
    Baltimore, MD
    What do you have now?
  11. Jun 13, 2018 at 6:22 PM
    #51
    sodaryl
    sodaryl Well-Known Member
    Daryl
    Vancouver, BC
    2016 Blazing Blue DCSB M/T Sport
    -Relentless Off-Road sliders -265/70r17 Wrangler Duratracs -Diamondback HD -CCG Mesh grill -Pop & Lock PL8535 -BPF Heavy-Duty Front Tow Hook
    Can you explain this for me? Is the clutch not a sealed thing?
    EatSleepTacos likes this.
  12. Jun 13, 2018 at 6:40 PM
    #52
    Bishop84
    In between tacomas, 2 of my friends and my sister have 2nd gen's that I work on for right now haha. I have a subie that I tank around in currently.
    I was always taught during water crossings not to clutch as the water enters the friction surfaces and can prevent the clutch from re-engaging.
    Also during water crossings you shouldn't shift anyway as the power needs to be constant or you can bog down.
    Pick a gear and give er'
    RocTaco likes this.
  13. Jun 13, 2018 at 6:41 PM
    #53
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I believe in most cases yes, the housing is not completely sealed. There are wet clutches that are oil lubricated, those are probably sealed.
    If you don't change gear when clutch is submerged you won't have any issues.
    Bishop84 likes this.
  14. Jun 14, 2018 at 6:39 AM
    #54
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is no worse than water getting on a brake disk. This is how I ride around on my bike:
    I like spinny things.
    If you guys crawl under the Taco, on the left side of the bell housing is a black cover. Just pull on it and it will come off. It is the inspection cover for the clutch.
    Dry clutches are always vented.
  15. Jun 14, 2018 at 6:43 AM
    #55
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    You can shift while you're in the water because the flywheel will just throw the water off, same as a brake disc. If your flywheel is completely submerged you've probably killed your engine anyway. But you shouldn't shift while doing a water crossing because water crossings should be done smoothly.
    tonered likes this.
  16. Jun 14, 2018 at 5:42 PM
    #56
    sodaryl
    Daryl
    Vancouver, BC
    Good to know, thanks everyone! I've only gone through a couple of big puddles, probably not even up to the frame, but definitely noticed the extreme bogging down.
