4hi questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black cx, Mar 7, 2011.
  1. Mar 7, 2011 at 11:39 AM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    I read the card on the sun visor. I wasn’t quite sure what it means when it said “keep below 55mph..
    Does that mean switching from 2wd to 4hi..keep it below 55mph?
    Or
    When driving in 4Hi, keep it below 55mph?
  2. Mar 7, 2011 at 11:42 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I'm pretty sure on the card it says to only switch to 4hi while not moving, or moving very slowly, anyway.
    4hi is a very low gear ratio... I don't think you could hit 55 in 4hi if you wanted to... You'd be screaming along at 7000RPM or something insane...
  3. Mar 7, 2011 at 11:44 AM
    lrak
    lrak Well-Known Member
    It means you can not switch between them above that speed. Being in 4hi imposes no speed limitation beyond what you have in 2hi.
  4. Mar 7, 2011 at 11:46 AM
    TacoTabe
    TacoTabe Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    I think you're confusing 4hi with 4lo. I can shift my 2011 into 4hi from 2wd at up to 62mph. And have driven in 4hi at 70mph- about 3000 rpms...
  5. Mar 7, 2011 at 11:47 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I think you have 4H and 4L mixed up...
    OP...I believe you have to make the switch at or below 55. You can drive in 4H faster than 55 but why would you ever need to? If the conditions are so bad that you need to engage 4WD hopefully you'd be driving a bit slower anyway...
  6. Mar 7, 2011 at 11:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Your sunvisor means....don't go faster than 55mph while driving in 4hi.
  7. Mar 7, 2011 at 12:14 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    these 2 conflict
  8. Mar 7, 2011 at 12:16 PM
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    It means don't switch to 4 high above 55 mph... I go faster then 55 in 4 high every day.
  9. Mar 7, 2011 at 12:23 PM
    OffroadToy
    4X4 Offroad
    I just checked my visor card. Mine says to keep vehical speed below 60 mph when shifting from H2 to H4. My owners manual says "to shift from H2 to H4 reduce the vehical speed to less than 62 mph. Also, it says shifting from H4 back to H2 can be done at any speed.
  10. Mar 7, 2011 at 12:25 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    thanks!
  11. Mar 7, 2011 at 12:27 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I haven't been OUT of 4-hi in three days. I DO drive over 55 quite regularly. Just stay off hard pavement with good traction.
    I believe it means to go slower than 55 while you shift into 4-hi from 2-hi.
  12. Mar 7, 2011 at 12:30 PM
    MQQSE
    MQQSE Afoot is the game
    Rob
    Palmer, AK
    x2, but I'm 2007 4cyl/5spd/4x4. (rpms a little below that at 70...if memory serves)
  13. Mar 7, 2011 at 12:47 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    On the newer ones: Change 4lo to h4hi 62mph or lower (I stop, press clutch, before going 4lo).
    I can not imagine a situation where I would be going over 62 in 2hi and realize "oh crap, I should be in 4hi"
    But, I might drive softer than others!
  14. Mar 7, 2011 at 12:48 PM
    Dadic 78
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Yep, you're right... Sorry man. Haven't had my morning coffee yet. *takes a sip of coffee....* :smack:
  15. Mar 7, 2011 at 3:53 PM
    Janster
    Jandy
    Lancaster, PA
    Your statement is confusing.
    When switching from 4lo to 4hi or 4hi to 4lo - you should be completely stopped.
  16. Mar 7, 2011 at 3:56 PM
    MQQSE
    Rob
    Palmer, AK
    Yep...you're correct on both points.
  17. Mar 7, 2011 at 5:51 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This
    Try to shift from h2 to h4 above 60 or so on mine and it just beeps at me. Once shifted, I can go as fast as I want.
  18. Mar 7, 2011 at 5:57 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Why in the hell would you want to go faster than 55 in 4hi.
    I would not switch in and out of, or drive faster than 55 in 4hi...
  19. Mar 7, 2011 at 6:22 PM
    udy2554
    Naples, NY
    Sometimes 4hi on the snowy highways is added control. Around here it's a given. I would think you have snowy highways up Saratoga way. I would figure there is enough slippage even at speed. Then again, if you got slippage, you should probably slow down:D
  20. Mar 7, 2011 at 6:55 PM
    Yoytoda
    Roland
    completely stock
    exactly! 4hi doesnt really add much stability at higher speeds. It seems to give too much overconfidence. i only use 4wd to get going, 2wd will keep you moving as fast as you "should" go.
    Basically what i mean is if you need 4hi to keep moving you shouldnt be going more than 55. 5-6" on the road and you can likely move with traffic in 2wd, 2' and even with 4hi you wont be able to go 55. :)
