4HI vs 4LO
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kerrdog, Jan 18, 2017.
  1. Jan 18, 2017 at 10:10 AM
    kerrdog
    kerrdog [OP] Well-Known Member
    2016 trdor mgm
    I mainly only use my 4WD system driving in mud. I always find myself using 4WD Hi. I have a TRDOR which has the MTS, crawl control, and rear locker which only works in 4 LO. It seems to me that 4LO is just to slow in these trucks to use it. I feel like my truck has enough power to just run 4 HI in mud and was wondering if any of you other taco owners especially ones who mainly drive in mud feel like 4 HI is all they need and 4 LO is just to slow and really not needed.
    PRE-K likes this.
  2. Jan 18, 2017 at 10:11 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    4lo is better for crawling, engine braking downhill, and generally anywhere where more power is needed vs speed.
    DustStorm4x4 and lose_money like this.
  3. Jan 18, 2017 at 10:13 AM
    lose_money
    lose_money Well-Known Member
    Dean
    2016 MGM TRD OR 4x4 MT
    King 2.5, Icon AAL, SCS Ray10 16x8
    you gonna need it for steep declines and crawling
  4. Jan 18, 2017 at 10:16 AM
    kerrdog
    2016 trdor mgm
    Yes but I am not around steep inclines just good old flat ground and mud. I can crawl through the mud but it just seem so slow doing it
    Mike likes Tacos likes this.
  5. Jan 18, 2017 at 10:20 AM
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Then don't use it.
  6. Jan 18, 2017 at 10:24 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    If you're able to get through the mud in 4Hi you don't need the rear locker or crawl control.
    If you're stuck and need the locker or crawl control, then 4Lo is infinitely faster than sitting still.
  7. Jan 18, 2017 at 10:31 AM
    kerrdog
    2016 trdor mgm
    I couldn't agree more with what you just said.
  8. Jan 18, 2017 at 10:32 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    4lo has its place
    My main gripe is why can't I use MTS in 4hi?
    IMO MTS should work with 4hi
  9. Jan 18, 2017 at 10:37 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    You would burn your brakes up in no time
    PRE-K and Lt_Dan like this.
  10. Jan 18, 2017 at 10:37 AM
    kerrdog
    2016 trdor mgm
    I agree and it would also be nice if the rear locker worked in 4Hi if needed
    PRE-K and tacoflavoredkisses1 like this.
  11. Jan 18, 2017 at 10:44 AM
    RIDERED67
    Nah there's not a practical reason for a daily driver taco to need a rear locker in 4hi
    It would be nice to have the ability to lock the rear in 2wd though
    siznarf and Apd like this.
  12. Jan 18, 2017 at 11:28 AM
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    100% agree. Not sure why it is restricted to 4Low. I was having a hell of a time getting my locker to lock the last time I used it, too. Then the flashing locker light would not go off until I turned my truck off.
  13. Jan 18, 2017 at 11:48 AM
    BeaverNation
    BeaverNation Well-Known Member
    It Saves toyota money by limiting rear locker use/exposure to damage.
  14. Jan 18, 2017 at 11:53 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    i have the same problem with mine!
  15. Jan 18, 2017 at 11:59 AM
    JoshyP
    Josh
    Northern California
    Serious? Did it lock then when you go to turn it off, it started blinking then never stopped until you turned the truck off?
  16. Jan 18, 2017 at 12:21 PM
    Apd
    Apd Well-Known Member
    707
    This ^
  17. Jan 20, 2017 at 1:57 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    yup i never got it to lock! i had the light go solid for a min once as soon and i drove off started blinking again! the only way to stop the blinking is to kill the car then start back up! i thought maybe its me, mybe the terrain need to be very soft to allow the tires to spin freely and allow to lock in place idk...
    4 hi, 4 low crawl control, mts all work great!
  18. Jan 20, 2017 at 2:39 PM
    mvusa
    mvusa Well-Known Member
    2016 Silver Tacoma TRD Off Road 4x4 Access Cab V6 Auto
    I know you said it started blinking when you drove off, but were you going 5 mph or above when this happened?
    With mine I noticed that I had the rear locker engaged (solid light) and drove off but once I went above 5 mph the light went to a (fast blink) and would not stop until I turned off the truck and restarted.
    Edit: I've noticed 4 light states: Off / On (Solid) / Blink / Fast Blink
  19. Jan 20, 2017 at 4:53 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    No as soon as I let my foot off the break it started blinking again! I didn't notice any direct speed in the blink! I tried it about 4 times so far all on gravel roads tried neutral park reverse forward back again in reverse never really heard it click or engage. I might need someone to show me how to get it to lock!
  20. Jan 20, 2017 at 7:45 PM
    JoshyP
    Josh
    Northern California
    Honestly, to get it to lock, you should be in 4LO, Push the clutch in (M/T only) then press the locker button. It will start to flash on the dash, if it does not lock in like 5 seconds, creep forward for a foot or two until it is solid. Then you should be good to go. I hear the locker does not work in reverse, though.
    I might test it out again this weekend. Find some mud or snow and go for it. I really hope it works, I do not want Toyota dealerships messing around with my locker...
