4in tacoma lift
Discussion in 'Suspension' started by justinhartensteinjr, Oct 2, 2023.
  1. Oct 2, 2023 at 9:25 AM
    justinhartensteinjr
    justinhartensteinjr [OP] New Member
    justin
    2021 tacoma trd pro
    I want to know if i lift my 2021 4wd tacoma 4in in the front with just the struts will they fit? I hear i will need to do a diff drop but before i order one i want to know if i will need it for sure.
  2. Oct 2, 2023 at 9:28 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Most 4” lifts are done with drop bracket kits. Otherwise your CVs are going to be screamin due to the angle, which a diff drop isn’t going to be sufficient for.
    Most people otherwise stick to 2.5-3” max for 4WD.
  3. Oct 2, 2023 at 9:31 AM
    justinhartensteinjr
    justin
    2021 tacoma trd pro
    so what all will i need? also i am already lifted 3 in the back and im nose diving right now just trying to level out right now by getting a 4in.
  4. Oct 2, 2023 at 11:55 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What's lifting the front/back now and how much lift up front? 4" will be excessive cv angles... a diff drop won't be much help. Why not just lower the back?
    YF_Ryan likes this.
  5. Oct 2, 2023 at 11:57 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Drop bracket lift will be required. Easier to drop the rear, and level with front coilovers in the 2.5 inch lift range. Higher you go, shorter your CVs will last.
