4k rpm @ 70 mph...what to do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yawn, Jan 22, 2022.
  1. Jan 22, 2022 at 8:37 PM
    #61
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Agreed, those RPMs dont match. There is a phone app that will tell you RPMs from sound, but it's $9.00. Android there is apparently a free one.
    MalinoisDad likes this.
  2. Jan 22, 2022 at 8:55 PM
    #62
    WorldwideTacoma
    WorldwideTacoma Well-Known Member
    Jay
    2018 Cement Grey TRD 4wd/1999 Tacoma S/C TRD 5 Spd 4wd
    I just swapped in a cluster on mine with that slot and it works as it should.
    You can see when he throws it into neutral at the end of the video, it idles down to 1500. Way high. Op can try to redline it as @tacoma4 suggested lmao. We can compare rev limiters :thumbsup:
  3. Jan 22, 2022 at 9:02 PM
    #63
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I would assume they get the tach reading from the same place regardless of trans, but just points to the fact that that cluster is not factory.
  4. Jan 22, 2022 at 9:10 PM
    #64
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Also yes my 5 speed cluster has that middle strip but blocked off like OP's.
  5. Jan 22, 2022 at 9:17 PM
    #65
    WorldwideTacoma
    Jay
    I’m curious now since yours is the factory gauge, if it really doesn’t have the center piece for autos. I think my old one had it as well unless that one was swapped at some point too.
    You would think they’d be interchangeable for cost reasons on Toyotas part.
  6. Jan 22, 2022 at 9:18 PM
    #66
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Do your gauges have red numbers like the OPs? Looking at ones on ebay for 2000-2004 the white faced ones have black numbers. Just wondering if you’re on to something, hard to tell from a video but OPs cluster looks pretty new for a 2002.
    #66
  7. Jan 22, 2022 at 9:55 PM
    #67
    Nano909
    Xcab 3.4 4wd 5MT
    Mine look black, and are amber when the lights are on. I was going to post a video of my speedo mph with 33's on 4.10's for reference but I think the Admins/Moderators have me shadow-banned and cut my forum bandwidth speed or something cause it takes me 10 minutes to post and much longer to post a video. Click my profile and find my post about my video.
    #67
    davidstacoma[QUOTED] likes this.
  8. Jan 22, 2022 at 10:30 PM
    #68
    dalpal04
    dalpal04 Member
    Utah
    2001 Xtra Cab SR5 TRD V6 4X4 Super White
    Hmm. I don’t know if this is really any help, but is the truck idling high? And if it is at high rpm’s in general I’d check the throttle body to see if it’s clean as well as the tps and the idle air control valve. If these things are dirty it can make your truck want to run at higher rpms than it should. I recently fixed a 96 3.4 5VZ from being at high rpm’s consistently by doing these things. If these things don’t work then I would probably check for vacuum leaks and look more into your rear differential gear ratios.
  9. Jan 22, 2022 at 10:53 PM
    #69
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    might be stock .............????
    i doubt it
    of course the bigger is better mentality................mo powa ......... Mo Powa ....MO POWA !!!
    for something used 2-3 % o the time is burning up a lot o Wear/Tear ALL the Time !!
    trans also
  10. Jan 22, 2022 at 10:55 PM
    #70
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    That is the best explanation I've heard. If that truck as the V6, 5 speed, and 4.10 rear axle with P265/70R16 tires (stock stuff) it would be turning 2640 rpm at 70 mph in 5th gear. If the cluster is for a 4 cylinder that would read 3960 rpm. Those white face clusters with tachometer seem pretty popular too.
    LearningToFly and davidstacoma like this.
  11. Jan 22, 2022 at 10:57 PM
    #71
    davidstacoma
    David
    NC
    His first post he said he’s running 33s (32.8”) so somewhat less rpm’s at 70 mph.
  12. Jan 22, 2022 at 11:17 PM
    #72
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    At 70 real MPH, but the math for indicated MPH would be the same
  13. Jan 23, 2022 at 6:48 AM
    #73
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I’m thinking that the cluster receives a pulse each time a spark plug fires, instead of each revolution of the engine. That’s the only reason I can think that the two clusters would be different. Probably makes the needle more responsive.
    @BartMaster1234 do you remember if there’s an easy to tell difference between 4 and 6 cylinders clusters?
  14. Jan 23, 2022 at 7:14 AM
    #74
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    On the 4 cylinder ones, the area above 65mph shows no signs of wear :)
    Before I start a war here, I own a 4cyl, so I get to talk trash.
  15. Jan 23, 2022 at 7:15 AM
    #75
    davidstacoma
    David
    NC
    Haha I like it. Same here. Except my wear stops at 75 due to interstate. :D
  16. Jan 23, 2022 at 7:15 AM
    #76
    0xDEADBEEF
    *does not apply to reg cabs ;)
    Wsidr1[QUOTED] and davidstacoma like this.
  17. Jan 23, 2022 at 7:30 AM
    #77
    Squeaky Penguin
    Brett
    You guys are right, it is there on mine. :thumbsup: Just looks way more obvious on OPs video than on my truck. :notsure:
    Anyways, I read recently that the tach signal comes from the ignitor, so it makes sense that a 4cyl tach would read higher. A little more reading seams to indicate you need to make sure the engine size is correct when swapping clusters.
    mechanicjon and skeletron like this.
  18. Jan 23, 2022 at 7:34 AM
    #78
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Might question this but at that rate you should be getting worst than terrible gas mileage. Some thing in this picture doesn't add up.
  19. Jan 23, 2022 at 11:38 AM
    #79
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I believe there is but I don’t know off the top of my head. @mechanicjon would know.
    0xDEADBEEF[QUOTED] likes this.
  20. Jan 23, 2022 at 7:03 PM
    #80
    LearningToFly
    LearningToFly Well-Known Member
    Northeast Alabama
    2004 Double Cab
    Let us know what you figure out on this. Have you ran a carfax on this truck? I hope someone didn’t swap the cluster out in order to make it appear lower mileage than it is.
