4L-4H-2WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sergei K, Nov 14, 2020.
  1. Nov 14, 2020 at 7:17 AM
    Sergei K
    Sergei K [OP] Member
    Sergei
    2019 Toyota Tacoma
    Please help! I accidentally turned the 4H on while parked and didn’t notice it until the truck started squealing on sharp turns and starting rocking during that process. When I changed it back to 2WD it has problems switching back.. last time it wouldn’t switch back until as I was driving it knocked back into place... why was it having trouble switching? And are there any serious damages I may have caused?
    Junkhead likes this.
  2. Nov 14, 2020 at 7:20 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think you're alright. Sometimes the 4wd is just sticky. I'll have to switch back and fourth sometimes as well
  3. Nov 14, 2020 at 7:28 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The 4WD system cannot disengage under tension to save the mechanisms that operate the 2 shift yokes. There is a torque limit sensor. If your drivetrain is all bound up, you gotta sometimes drive and steer a little to release the tension and allow the 2 electric motors (one in ADD and one in T-case) to operate. Both these motors are protected from over torque.
    What you are witnessing is the system saving itself from damage.
  4. Nov 14, 2020 at 7:38 AM
    jdr3366
    jdr3366 Well-Known Member
    I couldn't switch from 4L to 2, accompanied by a whining sound. Called dealer who said that I was driving too fast for the change to 2 to take place. Don't remember the speed (made 40mph), but slowing down to a crawl made the change, no problem.
    Dealer also said the driving fast in 4L can cause damage probably to what is described by Stocklocker.
  5. Nov 14, 2020 at 7:38 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Consider yourself lucky, it's normal..my nissan xterra wouldn't switch for miles sometimes. Didn't like switching back to 2wd. Kinda annoying..
    Skydvrr likes this.
  6. Nov 14, 2020 at 8:07 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I think you are fine. On some days my truck engages 4x4 right away, some days takes a bit longer. I wouldnt worry about it.
    Zdarova!
  7. Nov 14, 2020 at 8:13 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Shift into and out of 4LO at a stop only. No syncros, that shift ain't happening at speed. Shift 4HI to 2HI at any speed. 2HI to 4HI will shift up to about 60 mph.
    You weren't getting a quick 4HI to 2HI shift because your drivetrain was bound up after that 4HI pavement driving. Drive a bit with slight turns, don't fight it, and the system will eventually relieve enough to get the shift done.
  8. Nov 14, 2020 at 8:14 AM
    Stocklocker
    17TRDORDCSBAT
    I’m not sure if it’s still required, but I stop and put the truck in neutral to switch out of 4Lo. I assumed this was still the case.
  9. Nov 14, 2020 at 8:20 AM
    ShimStack
    Ben
    NC
    Stocklocker[QUOTED] likes this.
  10. Nov 14, 2020 at 8:21 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    OP, you should occasionally operate in 4WD for a few reasons. Most importantly, driving a couple miles a month will keep the transfer case and front differential components, including the bearings, lubricated and coated with oil. Toyota recommends something like 10 miles a month/1000miles. It will also exercise the actuator(s) and electrical contacts, which can get stiff and corroded if they never move. Lastly, you will become familiar with engaging and disengaging the 3 modes, things that can help motivate the actuators to engage, etc so that when you need 4WD, you will be confident and likely not have trouble engaging. The drivers sun visor should have a 2WD/4WD drive mode instruction card in a pocket. My 2nd and 3rd gen both have one there.
  11. Nov 14, 2020 at 8:24 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    This
  12. Nov 14, 2020 at 3:24 PM
    jdr3366
    Oops. I blacked out the stickers.
    Benny blanco and GSDLVR123 like this.
  13. Nov 14, 2020 at 4:17 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Coming from a 2003 tundra that had a problem disengaging under acceleration I’ve always just lifted my foot off of the gas and pushed the button. There’s always been a clunk.
    I think we’re all a bunch of pussies! Think about all the trucks in the Sahara and all of the other far-flung places where Toyota rules the outback. Those trucks don’t see regular oil changes and never come out of four-wheel-drive. They are bulletproof. Stop being so soft fellas! LOL
  14. Nov 14, 2020 at 6:02 PM
    Sergei K
    Sergei
    2019 Toyota Tacoma
    I have a lease.. lmao bout to finance the next. Might have to pussy it until then lol
    Professor D likes this.
  15. Nov 14, 2020 at 8:05 PM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    as the saying goes - you can shift high on the fly (2 - 4HI vise versa) and you shift low going slow (neutral/stop). Oh and shifting on dry pavement doesn’t help if that was the case.
  16. Nov 14, 2020 at 8:12 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    This is why I don't buy used 4x4s.
  17. Nov 15, 2020 at 1:20 AM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    4 hi on the fly, 4 lo stop n go.
    As others have said, I'm not sure how much driving you did in 4hi, it's obviously not good to make sharp turns on pavement but you should be ok if it's still switching. You may want to change your transfer case oil a bit early though in case there's extra wear particulates in the oil from all the binding.
  18. Nov 15, 2020 at 2:08 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It usually helps to put the truck in reverse and back up a few feet if stuck in 4 lo. Doing that helps relieve the stress in the drivetrain.
    Boghog1 likes this.
  19. Dec 1, 2020 at 10:42 AM
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    I have a problem that just came about two weeks ago.
    When is switch from 2 to 4h, nothing happens, not even the 4 wheel light comes on.
    Then I notice if I shut the engine off, turn the 4H switch on before starting, then just turn the ignition key before starting, the four wheel indicator light comes on and when I start the engine, it remains in 4H until I switch it off. .
    However I have an intermittent problem that once I switch back to 2 wheel drive, I can't get back into 4 wheel drive unless I stop, turn off the engine, turn the switch to 4h and then turn the ignition key to turn it on. I can sometimes hear the hubs locking in.
    My guess is it's because being retired, I don't drive the truck enough. This seems to happen after we've had wet weather. In other words, something is sticking.
    Is there a way to oil a part of the 4 wheel drive system to keep this from happening ?
    Never mind, I just watched this video and it answered my question.
    https://www.youtube.com/watch?v=ayrrdRFcOdc
  20. Dec 1, 2020 at 11:14 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    you were going 40mph in 4L AND trying to switch back to 2 at that speed?
    cyked and whatstcp like this.
