4L beeping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattb123, Jul 14, 2008.
  1. Jul 14, 2008 at 1:01 PM
    mattb123
    mattb123 [OP] Total Newb
    Gunnison, Co
    07 Double Cab TRD SR5
    Hi. I just bought a used 07 Tacoma 4x4 V6 TRD SR5. Generally it's great, but I tried to put it in 4L over the weekend for the first time and it just beeps at me and doesn't seem to go in. I did what the manual specifies, which is coming to a full stop, and I tried driving at different speeds to see if it need help to go in. I even backed up a little, but it seems to just beep repeatedly and stay in 4H. Turning the dial back to 4H makes the beeping stop.
    Does anyone have any suggestions before I take it to the dealer? The nearest one is about 1.5 Hrs away and if possible, I'd love to figure this out without having to make the trip. Could it be a fuse or something like that?
    Thanks!
  2. Jul 14, 2008 at 1:02 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Beeping means your not in 4LO. What exactly where you doing to engage 4LO?
  3. Jul 14, 2008 at 1:06 PM
    mattb123
    Gunnison, Co
    I was driving in 4H and came to a complete stop. I turned the dial to 4L and started driving again. Did I miss something? I don't have the manual or truck with me so maybe I missed something? Does the shifter need to be in a certain position? I tried it in the lower range gears (4, 3, 2, L) and it all seemed to behave the same.
    Thanks!
  4. Jul 14, 2008 at 1:07 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    If its an automatic transmission, you must be in neutral or else it will not go into 4LO. I dont know about manual transmissions.
  5. Jul 14, 2008 at 1:14 PM
    mattb123
    Gunnison, Co
    It is an auto. I think that may have been the one thing I didn't try. I'll give it a shot tonight. Thanks!
  6. Jul 14, 2008 at 2:03 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    You know one day I will be on here enough that when I know the answer to a question I may actually be able to post it, lol. The Master is the man.
  7. Jul 14, 2008 at 3:04 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    LOOK UP at the sun visor the card on that tell you how to do it.
  8. Jul 14, 2008 at 4:49 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    On the manual you have to be stopped and have the clutch pressed all the way down before you turn the switch.
  9. Jul 15, 2008 at 9:03 AM
    mattb123
    Gunnison, Co
    Well this is an auto, so no clutch. But I did get it figured out. Initially, I didn't realize the shifter had to be in N. Once I did that it went right in. I think I was so excited to get out in the new truck I didn't read that part of the manual well enough and it didn't stick. Anyway, it's all good now.
    Thanks for all of your help!
