4lo Beeping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imagine7721, Feb 7, 2009.
  1. Feb 7, 2009 at 8:52 PM
    Imagine7721
    Imagine7721 [OP] UNDESTRUCTABLE
    Casey
    Stuttgart, Germany
    06 Tacoma TRD Sport
    3" Toytec Ultimate w/ Total Chaos UCA, All-Pro Offroad Front and Rear plate bumpers, Shrockworks Rock Sliders
    Hey all,
    Quick question...
    When my 06 TRD Sport is in 4lo, it beeps, constantly. WTF?! Is that supposed to happen?
  2. Feb 7, 2009 at 8:54 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    It's not in 4lo if it's beeping. You have to be at a COMPLETE stop and you can only get into 4lo from 4 hi. So go in 4hi, until you're engaged, then stop COMPLETELY, then go to 4lo and you should be good to go.
  3. Feb 7, 2009 at 8:57 PM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    Make sure the clutch is all the way in if it's manual as well, otherwise it won't go into 4lo. As mentioned above, if it is beeping, it didn't work. You need to switch back to 4hi and try again.
  4. Feb 7, 2009 at 10:54 PM
    Imagine7721
    Casey
    Stuttgart, Germany
    06 Tacoma TRD Sport
    Thanks guys.
  5. Feb 7, 2009 at 11:00 PM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
    haha yeah, the first time i went to put it in 4 lo it just kept beeping and beeping and i couldn't figure out WHY it wasn't going-then i realized the clutch wasn't ALL the way down-like to the floor, as far as it will go.
    sucked because i was teetering on three wheels on a steep incline, not moving.....
  6. Feb 7, 2009 at 11:06 PM
    Imagine7721
    Casey
    Stuttgart, Germany
    06 Tacoma TRD Sport
    Mine is automatic, but I was just going straight to 4lo, not 4hi to 4lo.
    Unfortunately, I can't check it out for another couple of months..
    Thanks again.
  7. Feb 7, 2009 at 11:07 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    took me a while to figure it out to actually, all the 4x4 directions are on a little card right in your drivers side sunvisor :)
  8. Feb 8, 2009 at 3:37 PM
    Imagine7721
    Casey
    Stuttgart, Germany
    06 Tacoma TRD Sport
    Wo wo wo...
    I have to read?
    Nobody said anything about reading...
  9. Feb 8, 2009 at 3:41 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah when I put mine if 4low for the first time and started beeping at me I was like WTF!!!! Well I only had it in 4low once since I've had it since August of 06'!!!:D Tells you how much off-roading I do!!!:eek:
  10. Dec 26, 2009 at 6:55 AM
    briinh
    briinh Well-Known Member
    Maine
    08' Tacoma sr5
    you need to put it into N, then turn to 4LO, it will stop beeping and work
