4lo or 4hi for mudding
Discussion in 'Off-Roading & Trails' started by tmcmanus7, Mar 26, 2011.
  1. Apr 1, 2011 at 10:44 AM
    #41
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Great video. In Oregon we have some nasty thick mud, that is considered sand here. I mean no offense, just saying Crawling did not get you unstuck, wheelspin did, with a locker added to the situation. Open diff and you probably would have been stuck, Thank Toyota for the Factory locker. But those without a locker will have much more trouble in mud, opposed to the ones that do and must use momentum to get them through the slop. Kind of like fording a river, you must keep the wave pushing forward, unless you have a snorkel.
  2. Apr 1, 2011 at 12:44 PM
    #42
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    To OP: How deep is the mud? I can do an inch or 2 in my gfs corolla ;p
  3. Apr 1, 2011 at 7:28 PM
    #43
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I dont have lockers and have gone through more shit than a guy that has a 88 4runner on 38s! DRIVER SKILL plays a lot of part in it! Some of yall seem to know what your talkin bout cause you live around mud! Tha more you do something the better you get at it
  4. Apr 1, 2011 at 8:14 PM
    #44
    theallpowerfuljon
    theallpowerfuljon Well-Known Member
    Jon
    Wichita, KS
    09 TRD Off-Road 15 T4R Limited
  5. Apr 1, 2011 at 8:19 PM
    #45
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    2wd is where its at and a lot of momentum.;)
  6. Apr 1, 2011 at 8:44 PM
    #46
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    I am new to this but I try to use 4HI and go slow when the going is rough. My truck is new enought that I don't want to break anything so slow and mindful of things that can hurt under or on the paint.
    As I understand it.
    Without the "yellow wire mod" 4HI has LSD front and back and 4LO does not. (the yellow wire mod gives you LSD front and back).
  7. Apr 1, 2011 at 8:49 PM
    #47
    bowhunter11199
    bowhunter11199 Well-Known Member
    4 lo if im climbing a mud slide hill but 4 hi through puddles/lakes.
  8. Apr 1, 2011 at 8:51 PM
    #48
    wmdpowell
    Bill
    Essex county NY
    I thought there was in 09 and later, but just learned from reading here.
    All i know for sure is I have way more traction than I ever did in my VW, no matter which drive or slip settings.
    These truck are like tractors
  9. Apr 1, 2011 at 8:55 PM
    #49
    Sandhopper
    Sandhopper Well-Known Member
    4hi unless you are bogging down... unless I am crawling or tugging I start out in 4hi
  10. Apr 1, 2011 at 9:34 PM
    #50
    showmeballer
    showmeballer Well-Known Member
    st. louis
    08 trd off-road
    None yet
    So far, most of the videos posted are you guys just driving through big puddles. :) If this is what the OP intends to do then 4hi or lo doesn't matter all that much. Just line it up and give it some gas.
    I had a TJ with 35 mud terrains for many years and on sanctioned trail rides you wouldn't even be allowed on the trail without 35s and at least a rear locker.
    If you are going to spend hours in the slop on trails and not just running through some big puddles then you NEED good mud tires and will want to be in 4LO most of the day.
    If you are just playing around or you have some monster truck in the swamp with boggers then 4hi is fine. It really all depends on the terrain as to which one to use, but for really muddy trails you want 4lo and good tires. :cheers:
  11. Apr 2, 2011 at 9:13 AM
    #51
    802YOTA
    802YOTA Well-Known Member
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    LEAF SPRUNG SAS, 5" inch springs 5" shackles. Tacoma HIGH STEER, CHERRY BOMB 3" Straight pipe, TRIPLE CASES, 5.29s, (yeah she crawls) LOCKED FRONT AND REAR, Custom square stock front driveshaft 13" slip(been there for a year and hasnt failed yet.), Ruff Stuff 8 inch Perches, 2" RB body lift, K&N intake, Zoom high performance Kevlar clutch, herculined flares and rockers, trail gear rock sliders, rock lights.
    neither i just lock the rear and laugh at the people behind me :)
  12. Apr 2, 2011 at 1:55 PM
    #52
    randombob
    randombob Well-Known Member
    Eureka, CA
    2013 TRD OR
    stuffs
    If it's a no-biggie puddle then 4hi because it's not worth switching gears. But to me it seems if it's gonna be thick and possibly a SERIOUS mud thicket I swap to 4lo. It's a fantastic torque multiplier, and you can do 35-40+ in low anyway so you get the added torque and if you feel you NEED the speed you can still get it. 4hi can bog due to lack of torque if it gets a bit serious and then you're gonna be in a world of hurt.
  13. Apr 2, 2011 at 10:51 PM
    #53
    RedTaco2134
    Scott
    Portland, Or
    I see what your getting at Bob. Your point is Valid, although if you start in a low gear in 4hi and keep speed you should have enough low gearing from the clutch to keep momentum.
    Also those big giant truck's with 64" Michelin XML's need 4lo and all the torque the crate V8 and deep gearing can produce in order to get those babies just to roll. 4hi would never create enough low-end to move those beasts.
    Its all apples vs oranges..whatever works for you and keeps you having a fun time, and away from the headaches of being stuck or stranded.
  14. Apr 2, 2011 at 11:01 PM
    #54
    randombob
    Eureka, CA
    2013 TRD OR
    stuffs
    Using the clutch to mimic lower gearing = premature clutch failure. I mean it works but it's not as effective and can lead to bad things in bad places. There'd really mo "downside" to using 4lo
  15. Apr 2, 2011 at 11:07 PM
    #55
    Snoyota
    Snoyota Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    Dont go in the mud
  16. Apr 3, 2011 at 1:34 PM
    #56
    RedTaco2134
    Scott
    Portland, Or
    I don't understand how you are "mimicking" the gear ratio? You are definitely lowering your final crawl ratio by starting in 4lo, 1st gear, opposed to 4hi, 1st gear. As for premature failure, doubt it. how would it fail, unless it is slipping? and torque creates slip. The lower the gearing the less slip, unless you hammer down, causing more torque due to the low gear ratio. 4hi is for much higher speeds, where wheel spin is needed. Driving in 4lo and trying to drive fast is counter productive. It is way more effective to lower your final crawl ratio by starting in 1st and 4lo too. The cold hard fact is that 4lo is called " 4 wheel drive Low" for a reason, tada...Lower gearing, lower speeds and less wheel slip. Thats why rock crawlers use 4lo and not 4hi.
    Touche` :D about staying out of the mud.
  17. Apr 3, 2011 at 6:50 PM
    #57
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    And just to think . . . . All this arguing came out of such a simple question, "which is better"
    You shouldve just made a fucking pole and told noone to respond! Haha
  18. Aug 6, 2016 at 7:39 AM
    #58
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Bump just cause.
    PoweredBySoy likes this.
  19. Aug 7, 2016 at 12:35 PM
    #59
    Scrubber3
    Scrubber3 Not really here
    2016 T4R XP 4X4 MS
    I'd say tires play the biggest role. Next to that, know what's in the mud and how deep it is. Then select proper transfer case gear which is 4LO.
    Then turn on A-trac and lock the rear diff.
    Follow this and you'll be good to go in most cases.
  20. Aug 9, 2016 at 7:59 PM
    #60
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    It's all about the tires getting cleared of mud so they can grab the next rotation. Depending on the mud hole you go through will tell if your in hi or low. If your rolling a manual I like low.
