4lo Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Mar 1, 2019.
  1. Mar 1, 2019 at 3:21 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Ok so the other day when off roading (and atleast once before) I tried using 4lo. I put it in N while on 4hi and then turned to 4lo. The 4lo didnt want to grab on to well. I put it in D then it grabbed on. When it grabbed on it kind of made a forced, but not too badly forced sound. It sounded like it could be normal, kinda like when you turn your CRAWL control on, but not as bad. Then it moved and ran fine in 4lo. When turning back to 4hi it again didnt want to disengage very well and made that same kinda popping in/out of place sound. Then this morning I put it in 4hi and drove like 100 meters. I then put it in 4lo (no engagement problems) and drove 5 meters, very slow ofcourse, and heard a sort of belt spinning kind of sound. I stopped and drove another 5ish Meters and kept hearing that belt sound. I disengaged it with no problems and went on my way. The exercise done this morning was on a cold engine btw. So, are those 4lo engagement sounds normal when engaging 4lo offroad? Are those sounds normal when using 4lo?
  2. Mar 1, 2019 at 3:24 PM
    eon_blue
    Azusa, CA
    Were you at a complete stop when you tried putting into 4lo? 2WD --> 4hi can be done while moving but 4hi --> 4low must be done at a complete stop
    CS_AR and Wixo[OP] like this.
  3. Mar 1, 2019 at 3:26 PM
    Wixo
    Hank
    Tint, LED interior
    I had it in neutral. May not have been super extremely even. May have had the slightest bit of movement from being on uneven ground.
  4. Mar 1, 2019 at 3:29 PM
    eon_blue
    Azusa, CA
    Slight movement (like 1 - 3mph) should be okay but it's best to be at a complete stop.
    Having a hard time understanding what you mean by 4lo "didn't want to grab on too well"...4lo should either engage or not engage, it won't partially engage. Usually if people have trouble getting into 4lo they will hear and feel grinding coming from under the truck. Once you're in 4lo it should be pretty obvious as their will be a lot more torque
  5. Mar 1, 2019 at 3:44 PM
    Wixo
    Hank
    Tint, LED interior
    Like a while back what happened was that it took a couple tries for it to engage and a couple for it to disengage.
  6. Mar 1, 2019 at 10:14 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Is this a common issue?
  7. Mar 2, 2019 at 4:45 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    You're fine. Depending on the position of the truck, current terrain and how often you use 4lo, the transfer case can be a bit clunky when shifting. If the transfer case is slightly bound up, it can also exhibit symptoms you describe when shifting out of 4lo. Letting it roll very slowly with no load on the transmission, while in neutral, can help with binding during shifts. The "spinning sound" you heard was most likely the transfer case spinning while in the lower gear range and is totally fine. The faster you travel in 4lo, the more noticeable that sound will be.
    johntoyota and Wixo[QUOTED][OP] like this.
  8. Mar 2, 2019 at 8:17 AM
    Wixo
    Hank
    Tint, LED interior
    Oh I see, thanks!
  9. Mar 2, 2019 at 8:20 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not normal but not sure if problematic either. So mine just kind of makes a thud in and out. Doesn’t sound forced but louder than a click. And I don’t have a belt sound.
    Wixo[QUOTED][OP] likes this.
  10. Mar 2, 2019 at 8:25 AM
    Wixo
    Hank
    Tint, LED interior
    That thud is more or less what I hear. When engaging 4hi I dont hear anything so thats why I described it as "forced" which I now see was incorrect. The belt sound was when I drove it on pavement and picked up a little speed, not really offroad where I go REALLY slow.
  11. Mar 2, 2019 at 8:26 AM
    JoeCOVA
    Joe
    Colorado Springs
    Ah ok so the engagement sound you are hearing is normal. I’ll take my truck out this morning and see if I hear that belt sound.
  12. Mar 2, 2019 at 8:35 AM
    JoeCOVA
    Joe
    Colorado Springs
    Just took the truck around the block. There is no belt sound but the engine does make a whirring sound due to the engine braking. I noticed it downhill at idle but not under power up hill
    Wixo[OP] likes this.
  13. Mar 2, 2019 at 8:37 AM
    Wixo
    Hank
    Tint, LED interior
    Thanks for checking that out. Im describing it as a belt sound, but again was probably wrong. It could also be described as a sort of whirring (how a belt whirs when in action) maybe I just explained it wrong. Ill take a video and upload it so you can hear it.
    JoeCOVA[QUOTED] likes this.
  14. Mar 2, 2019 at 8:38 AM
    JoeCOVA
    Joe
    Colorado Springs
    Haha ya describing sounds is tough.
    Video will do the trick
  15. Mar 2, 2019 at 8:42 PM
    Wixo
    Hank
    Tint, LED interior
    JoeCOVA likes this.
  16. Mar 2, 2019 at 8:43 PM
    Wixo
    Hank
    Tint, LED interior
    Oh man, its not letting me upload the file
  17. Mar 2, 2019 at 10:44 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    The belt sound, kind of like a groan noise? If you switch gears and it hasnt completed the actuation it will groan as you switch to drive and move. Got to wait for the dash to illuminate solid. Not saying thats what happened, but I've heard what it sounds like you are describing. Either way, Im sure you're ok.
  18. Mar 2, 2019 at 11:08 PM
    tcjacado
    tcjacado Well-Known Member
    Need to upload videos to YouTube then post link here.
  19. Mar 3, 2019 at 9:02 AM
    Wixo
    Hank
    Tint, LED interior
    I ran it a couple times and it more of a whirr like @JoeCOVA said and the engagement didnt sound very forced this time. Im guessing ti depends on the angle its in.
