4lo question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Musictog, Apr 1, 2023.
  1. Apr 1, 2023 at 2:34 PM
    Musictog
    Musictog [OP] Member
    Hey,
    today I had a chance to exercise the 4x4 system … nothing crazy, just to keep everything moving… when I put it in 4lo, it did engage.
    However when I pressed the gas lightly I would start moving. The engine would rev to about 2k rpm still under 5 mph and hard shift into 2nd. Does that sound right?
    MTS, crawl control and lockers worked as expected
  2. Apr 1, 2023 at 2:40 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds about right. You probably noticed how 4 low whines vs 4 hi.
    Kolohe07, pltommyo, erok81 and 3 others like this.
  3. Apr 1, 2023 at 2:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That's normal.
  4. Apr 1, 2023 at 2:46 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    u PosTeD @ thhe wrrronngg TimmEE ,
    Stevie17 likes this.
  5. Apr 1, 2023 at 2:52 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mines the same. i tend to use the s-mode in 4lo. it shifts really weird if you keep in D.
    Musictog[OP] likes this.
  6. Apr 1, 2023 at 3:05 PM
    Musictog
    Thanks for putting my mind at ease…. Never had such a fancy 4x4 system.
  7. Apr 1, 2023 at 3:06 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is nothing magic about 4 low. All it does is reduce the trucks gearing by a factor of somewhere between 2:1 and 4:1 depending on the exact vehicle. I think Tacoma is somewhere around 2.75:1. Which means that if your 1st gear ratio is 3.60:1 in high range it will be about 10:1 if you're in low range.
    It doesn't provide any more traction and won't help get you unstuck if you're stuck in high range. In fact most of the time you're better off in high range in low traction situations.
    Low range allows you to drive SLOWLY and under control in rugged terrain while keeping engine RPM's very low. It also provides much more engine braking when going down steep hills off road.
    Since it is only needed when you need extremely low gearing it is best used only with the transmission in 1st gear or reverse. No need to put it in Drive and let it shift gears. Once the transmission shifts to 2nd gear, low range you have pretty much the same gearing as high range 1st gear.
    ThreeBeers and Musictog[OP] like this.
  8. Apr 1, 2023 at 3:14 PM
    Musictog
    Thanks for that explanation!!!!
  9. Apr 1, 2023 at 3:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not fancy at all. Actually, it's much more primitive than most.
  10. Apr 1, 2023 at 3:42 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Pulls stumps more better.
  11. Apr 1, 2023 at 3:49 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I have to admit, I dont use 4low often, but do sometimes just to lube it!
    zoo truck and Musictog[OP] like this.
  12. Apr 1, 2023 at 3:55 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Let it snap up top!
  13. Apr 1, 2023 at 4:05 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I plow snow with my truck in low range yes it improves your traction because it takes less power to move the truck. A spinning wheel has no traction. If you have an automatic it will instantly try to shift I don't know if you can drag the shifter into low mine is a manual.
    amyracecar and Musictog[OP] like this.
  14. Apr 1, 2023 at 4:17 PM
    Musictog
    My old truck. Did not behave like my taco in 4lo so that’s why I was concerned
    hiPSI[QUOTED] likes this.
  15. Apr 1, 2023 at 4:18 PM
    Musictog
    That’s what today was about
  16. Apr 1, 2023 at 4:24 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    About the only times I've used 4 Lo were situations where I needed to control my speed easier. 4 Hi in the same situation had me riding the brakes quite a bit which was also pretty hard on the suspension due to the speed and terrain. I had also done that same trail in 2WD, but 4 Lo made a big difference. So it isn't just for when you think you will get stuck.
  17. Apr 1, 2023 at 5:01 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Hey, good on you OP for learning how to use the system and how it behaves before you need it. That’s smart!
  18. Apr 1, 2023 at 5:14 PM
    Musictog
    Thank you all ….. I was kinda hesitant to post this on 4/1
  19. Apr 1, 2023 at 5:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Just don't ask anything on a Friday here.
  20. Apr 1, 2023 at 6:02 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Just asking, is it bad if you don't use 4 lo for years ?
    I know you should use 4x4 often for lubrication.
