4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Mar 28, 2015 at 2:26 PM
    #221
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Had no effect on mine.
  2. Mar 28, 2015 at 3:57 PM
    #222
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    2015 TRD Sport DCSB V6 6spd 4x4, same yellow w/black tracer wire as mentioned.....YWM = :)
    sddarkman619 likes this.
  3. Mar 29, 2015 at 1:37 PM
    #223
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    It always seems to take a few tries to engage or disengage.
  4. Mar 29, 2015 at 10:28 PM
    #224
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I've always came to a complete stop, waited about 2 seconds, put trans in neutral and then engage 4lo and hasn't hiccuped yet.
    YMMV
  5. Mar 30, 2015 at 11:22 AM
    #225
    replica9000
    2019 T4R ORP
    Just did the fluid not long ago. It always works right away when I'm testing it. But when I need it, it seems to take a few tries.
  6. Mar 30, 2015 at 11:27 AM
    #226
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    The way low engages (under 3 mph and only when in neutral) is to help it engage and not break shit. Every truck I've owned takes longer to find 4 low than 4 high. Not sure why even when those conditions are met it's such a bitch sometimes.
  7. Apr 1, 2015 at 2:48 PM
    #227
    Greenbean
    Zack
    Western NC
    Yup,
    Once I found out what the inside of my transfer case looked like I realized why 4Lo takes what it does to engage. Lots more going on to get into 4Lo.
  8. May 21, 2015 at 9:33 AM
    #228
    prodeer
    prodeer Don't know what normal is anymore
    Boise Idaho
    08 AC Tacoma
    Intake, Lift,, Custom Arizona pinstriping piant job, icon 2.0 rears and sway away Adjustable coil overs, KMFB sliders, KMFB Frankinsprings, cb mount, and p.a. System
  9. Jul 4, 2015 at 7:38 PM
    #229
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Done! Thanks for the write up.
  10. Jul 15, 2015 at 11:07 PM
    #230
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Hey all. I want to do the abs kill switch mod and I picked up this switch. I'm pretty sure that when wired normally the abs will be ON when switch is pushed IN and I'd like abs to be ON while switch is pushed OUT. Is there a way to wire the switch up so it works backwards? Some sort of relay trickery perhaps?
  11. Aug 1, 2015 at 1:12 PM
    #231
    Greenbean
    Zack
    Western NC
    Yup,
    Your going to just have to run the existing wiring for the ABS wire you want to sever through the pins on the
    relay that are normally closed, believe it's 30 and 87a,
    The switch when activated will power the coil in the relay, so your 12V output from the switch to relay is going to pin 86,
    pin 85 is ground for the relay. You won't use pin 87.
    That way when you hit your switch, the relay turns on but is opens the circuit and your ABS is off.
  12. Sep 5, 2015 at 4:55 PM
    #232
    reasonselzzz
    reasonselzzz TAMU '18ish
    Reason
    Temple, TX
    2010 PreRunner 1981 Pickup
  13. Sep 5, 2015 at 6:32 PM
    #233
    Greenbean
    Zack
    Western NC
  14. Sep 8, 2015 at 7:35 PM
    #234
    reasonselzzz
    Reason
    Temple, TX
    Would 14 gauge solid wire work?
  15. Oct 9, 2015 at 7:32 AM
    #235
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Can anyone confirm which mod I should use for my 08 sport 4x4 with lsd only. I don't have vcs or traction or anything. Just abs and rear lsd
  16. Oct 9, 2015 at 9:18 AM
    #236
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The 'mod' (4 low trac mod?) is for 2009 or newer Sport TRD (or other non-Off Road TRD) Tacomas to give them some traction control while in Low Range.
    Only a few special Tacomas had TRAC before 2009.
    All Tacomas had TRAC from 2009 on.
    The Off Road TRD 4WD from 2009 on has A-TRAC in Low Range, so don't need the mod, but all other models have nothing in Low Range, only in High Range (TRAC/ TRAC OFF MODES).
    TRAC is limited slip using electronics and brakes to slow wheel spin and allow traction tires to get power.
    A-TRAC is almost like lockers for stopping spin and equalizing power to both pairs of tires.
  17. Oct 9, 2015 at 9:25 AM
    #237
    pudge151
    Sean
    Connecticut
    I apologize. I am looking to disable my ABS before the snow falls. It is horrible and dangerous
  18. Oct 9, 2015 at 9:30 AM
    #238
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    If you have no traction control then just pull the ABS fuse. Done.
    Just a heads up, removing the ABS removes VSC if your truck is equipped with that. All ABS mods also turn off the VSC function. VSC, acording to the National Highway Traffic Safety Administration's (NHTSA) report, equipped vehicles compared to those without can effectively reduce single-vehicle accidents by 35% for automobiles and 67% for Sport Utility Vehicles (SUV).
    Source: http://www.toyota-global.com/innova...ty_technology/technology_file/active/vsc.html
  19. Oct 9, 2015 at 9:35 AM
    #239
    pudge151
    Sean
    Connecticut
    I only really need to abs disabled in snow right? In normal street conditions isn't it helpful?
  20. Oct 9, 2015 at 9:38 AM
    #240
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    If you aren't having any issues with your ABS you don't need to disable it.
    If your ABS is going crazy then disable it the day the weather turns cold, but practice threshold braking before hitting the open road.
