4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Oct 30, 2016 at 1:50 PM
    #321
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I read through the whole "original thread" linked in the OP. Sounds like if you put a switch on the yellow wire it will let you turn the blinking light off.
    What you'll have to do is switch to 4L like normal and the light will flash, then flip the switch to close the circuit. apparently this will stop the light blinking but still leave TRAC on.
    It sounds like the ECU for the TRAC system only cares about that circuit at the time of engaging 4L. but the light cares all the time
  2. Oct 30, 2016 at 5:23 PM
    #322
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    2015 MGM DCLB TRD Sport 4x4
    Not an overbrander.
    Ahh, well that's not worth setting up a another switch for me.
  3. Oct 30, 2016 at 5:26 PM
    #323
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    I agree. you got me really curious about it, but now that I've read up on it I don't think it's worth the trouble. Might just take the bulb out of the gauge cluster if it bothers me.
  4. Oct 30, 2016 at 5:37 PM
    #324
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Put a piece of electrical tape over the blinking light :anonymous: Ez Pz
    TK7692 likes this.
  5. Oct 30, 2016 at 6:27 PM
    #325
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    I wonder if there's any way to wire some sort of "interrupter" between the two ends of the cut wire that blocks the current the first time it passes through, but then opens back up on the second try.
  6. Oct 30, 2016 at 8:45 PM
    #326
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    You could use a time delay relay.
  7. Oct 30, 2016 at 8:45 PM
    #327
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    Researching it now.
  8. Oct 30, 2016 at 8:52 PM
    #328
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    So far I've only found the opposite of what we need: a time delay that cuts the circuit after certain amount of time (i.e. dome light).
  9. Oct 30, 2016 at 10:05 PM
    #329
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Look for double throw time delay relay. The double throw gives a common, normally open, and normally closed points. The relay still has to have some sort of control for the coil, such as a momentary switch that sends 12vdc to the relay coil.
  10. Oct 30, 2016 at 10:19 PM
    #330
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Well I'm not sure how that signal in the yellow wire works. I'd have to check with a multimeter before I could find a relay I think would work. if it's as simple as 0V when in 4H and 12V in 4L a power switched, on delay relay would do the trick. They are usually adjustable from 0.1s delay up to 10s or sometimes a couple minutes. not cheap though
  11. Oct 30, 2016 at 11:28 PM
    #331
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    Yeah I did find one from Del City for 60 bucks. Weird how the reverse of what we need is cheaper.
    I would imagine it's 0V until you switch onto 4L. That connector wouldn't need any other power into it. One thing I did try out of curiosity, was I grounded the end that goes into the connector. That caused the the 4LO light to flash indefinitely, even when 4LO wasn't engaged.
  12. Oct 30, 2016 at 11:29 PM
    #332
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    I thought about that as well. I'm trying to avoid having a switch at all at this point.
  13. Oct 31, 2016 at 11:20 AM
    #333
    Smar969905
    Zach
    Deer Park, WA
    Use the time delay relay to control 12vdc, then get a cheap SPDT relay with 12vdc coil, which is then used to control the connection of the yellow wire. Time delay controls basic relay, and it's done.
    Next question, how do you control the time delay relay? It has to receive coil voltage from somewhere, and that is the point of the switch. You could easily use a push button that doesn't hold to start the time delay relay, but at that point, just hold the button for 10seconds and skip all the relays.
  14. Oct 31, 2016 at 3:32 PM
    #334
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    I'll be honest. If that's the only way, I'll live with the blinking.
  15. Oct 31, 2016 at 4:54 PM
    #335
    Smar969905
    Zach
    Deer Park, WA
    There are multiple ways. They just vary by how much time they take to complete and cost of various materials.
    The 4lo light blinks at you with the yellow wire disconnect and truck in 4lo because it isn't seeing something it wants to see.
  16. Jan 8, 2017 at 4:26 PM
    #336
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    I know I'm Reviving an old thread but will this work on a 3rd gen?
  17. Jan 9, 2017 at 11:26 AM
    #337
    Smar969905
    Zach
    Deer Park, WA
    May be an old thread, but not necessarily outdated. Yellow wire mod would be easy to test. Somehow I doubt it will be exactly the same on 3rd gen, but should be pretty close I would imagine.
  18. Jan 9, 2017 at 11:57 AM
    #338
    Stoked4
    I should have been more specific
    I was referring to the abs kill switch mod.....
  19. Jan 9, 2017 at 12:59 PM
    #339
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Does ABS suck on the 3rd gens too?
  20. Jan 9, 2017 at 1:27 PM
    #340
    Stoked4
    In the first snow of this winter/ my first snow With this truck I had disabled the traction control And a few times the abs engaging did mess me up a little
    So yes?
    STacoS likes this.
