4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Feb 6, 2013 at 10:33 AM
    #41
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    I noticed Brady and Erik have a few things mixed up on the 2005-2008 stock Tacoma Off Roads. Here's a link regarding 2005-2008 ATRAC/TRAC/DAC/HAC/VSC modes...
    Benson X's mod (the OP) is for 2009+ models standard with TRAC/VSC (NO ATRAC/DAC/etc.) with the vacuum brake booster. You can't compare the two.
  2. Feb 6, 2013 at 10:47 AM
    #42
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    Nice that sounds like an awesome setup. It does seem similar. I got my info from someone who did it on an 05 OR so I bet if you put power to your switch then you would probably end up with what I have. Having switches like that are great. Thinking about all this is making me want to do the locker anytime mod.
    I'll check to see if ABS comes on when I can later on. I think I am stuck in modded mode, without ABS, VSC or ATRAC. So if I didn't blow a fuse or anything and ABS deff doesn't come on then I am thinking it should only be a problem with my wiring right? Thats alot better than having something actually blown.
  3. Feb 6, 2013 at 10:56 AM
    #43
    BradyT88
    BradyT88 Well-Known Member
    Fixed:D I meant to say TRAC not VSC is still on in 4Lo, which is basically ATRAC at that point.
    Also your thread says that in 4Hi ATRAC is engaged instead of TRAC. I haven't experimented much with it, but I believe that ATRAC only functions in 4Lo and is just a much more aggressive version of TRAC.
    And yeah, if you are stuck in modded mode than your wiring is definitely grounding out the locker signal somewhere.
  4. Feb 6, 2013 at 11:18 AM
    #44
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    Yeah I am still a little confused about the differences in traction modes as you go from 05's to 09's, but I think the mod I did puts ATRAC on in 4HI and 4LO including when the locker is engaged. It deff takes ABS and VSC off all the time when the switch is on. I must have just plain old TRAC in 2HI. Either way right now I have no traction systems till I figure out what went wrong.
  5. Feb 6, 2013 at 12:19 PM
    #45
    GP3
    California
    4X4 TRD Off Road
    I said it's ATRAC in 4hi, because it is ATRAC.
    As you can see above, ATRAC is on in both 4wd modes. You feel that it's "more aggressive" because the extra torque from low-range requires extra braking power to stop the wheel. It only feels more aggressive.
    Anyways, sorry for derailing the thread further. Just wanted to point out some things.
  6. Feb 6, 2013 at 3:13 PM
    #46
    BradyT88
    I meant more agressive as in it prevents wheelspin more aggressively. In 4hi i can spin the crap out of 2 tires before it really starts to engage. In 4lo it engages almost as soon as there is wheelspin. I've read somewhere ATRAC is only active when moving slow, like 5mph or less. I'll have to try to find that when I'm on my computer.
  7. Feb 6, 2013 at 3:17 PM
    #47
    GP3
    California
    4X4 TRD Off Road
    2009 + OR with locker engaged.
  8. Feb 6, 2013 at 4:33 PM
    #48
    BradyT88
    Haha, I wondered if that might be the case with the slow rule.
    Ok I think I have the whole TRAC vs ATRAC thing figured out now. I was mixing it up with the 09+ system.
    Now I want to try an 09+ system just to see if their ATRAC is better than ours. In all the times I have used it, it has been pretty much useless. Didn't seem to perform any better than just open diffs and was way outperformed by my lockers.
  9. Mar 20, 2013 at 1:33 PM
    #49
    JerryTaco
    JerryTaco Well-Known Member
  10. Apr 19, 2013 at 10:58 AM
    #50
    HogBalls
    HogBalls Hog
    Shane
    Idyllwild California
    2010 Toyota Tacoma SR5
    Plasti Dipped all emblems, Painted Valance, Grill & Emblem Painted rear Bumper Painted Stock Rims 3" Spacer lift from Velocity Offroad 3" Differential Drop
    Hi Benson, So does this turn off the VSC 100%?
  11. Apr 19, 2013 at 11:01 AM
    #51
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Yes, the ABS Kill will disable VSC completely. The YWM DOES NOT disable VSC, since it relies on the VSC/TRAC to provide traction to the slipping wheel.
  12. Apr 19, 2013 at 11:03 AM
    #52
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    2009 + OR 4x4
  13. Apr 19, 2013 at 11:10 AM
    #53
    HogBalls
    HogBalls Hog
    Shane
    Okay sweet, took my truck to the dealership and had them recalibrate the VSC sensor but didn't make any difference. Then started turning off the VSC by holding the switch down for 5 seconds but it still was kicking on around corners. I have a 2010 4x4 double cab without the locking diff. but has the VSC this mod should work for mine right?
  14. Apr 19, 2013 at 11:14 AM
    #54
    OZ-T
    Peter North
    British Columbia
    You held the VSC button in while stopped for approx 5 seconds till the VSC OFF light is the only one illuminated , correct ?
  15. Apr 19, 2013 at 11:17 AM
    #55
    HogBalls
    HogBalls Hog
    Shane
    Oh yeah. Its off. I learned to do that first thing when I bought the truck and took it offroading and realized I couldn't throw a roost.
  16. Apr 19, 2013 at 11:48 AM
    #56
    HogBalls
    HogBalls Hog
    Shane
    Also once that switch is installed can I leave it off all the time? Meaning does it reset itself when you turn the truck off? The reason I ask is because my wife drives the truck occasionally so I just wanted to know if I need to tell her to flip the switch before she drives it. I really don't want that VSC going off while she is driving it.
  17. Apr 19, 2013 at 11:50 AM
    #57
    OZ-T
    Peter North
    British Columbia
    Huh
    Interesting it is kicking back on in normal driving conditions
    Something seems not right
    I have the same issue as you and drive in VSC OFF mode all the time and have never had it kick back on under normal conditions
  18. Apr 19, 2013 at 12:04 PM
    #58
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    That would mainly depend on the switch you use (momentary or on/off). With the switch I used in the write-up, it stays off all the time when activated, since it is breaking the circuit.
  19. Apr 19, 2013 at 12:40 PM
    #59
    HogBalls
    HogBalls Hog
    Shane
    Yeah, I talked to a guy at 4 wheel parts about it yesterday. And he said that it can be multiple things going on to make it go off. He said that when they do lifts on the Tacomas that the steering wheel has to be dead center when aligned and also that when he does the alignments that he sets the toe in at 1/4" and they haven't had any problems they also recommended getting the VSC sensor calibrated after the lift as you guys suggested. I might just take it to 4 wheel parts and have them align it and see if they can fix it. I'm still gonna install the switch because I really don't care for the ABS in the snow. Almost threw me into a tree the first time I tried stopping in the snow. Not cool.
  20. Apr 19, 2013 at 12:48 PM
    #60
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I agree, I only use ABS if it's bone-dry outside.
