4LO wont engauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Straightshot, Sep 9, 2012.
  1. Sep 9, 2012 at 6:37 AM
    Straightshot
    Straightshot [OP] Active Member
    Justin
    Utah
    2005, sr5
    Add A leaf, and new front coils.
    Ok so when I bought my 2005 double cab v6 sr5 I tested the 4H out and it worked no problem, but didnt test the 4LO. Last night I went river fishing ( fourwheeling on some sand bars ;) and ended up needing 4LO I tried every trick in the book and even read the book and it wont engauge into 4LO the knob turns but then the system just beebs at me know matter what I try. Anyone have any ideas as to why? Maybe somthing is wrong in the actuator?
  2. Sep 9, 2012 at 6:40 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    If it is beeping that means you are doing something wrong. Since you have a manual, make sure your clutch is pushed ALL THE WAY to the floor before turning the switch to 4 low.
  3. Sep 9, 2012 at 6:45 AM
    Straightshot
    Justin
    Utah
    2005, sr5
    Check Tried it multiply times last night.
  4. Sep 9, 2012 at 6:48 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Maticuno is correct.
    Switch on clutch must be actuated (clutch all the way down) before you switch to 4 Lo. Same coming out of 4 Lo.
    Try it with the engine off, in a quiet place with window down, and you will be able to hear the actuator work. If you don't do it in just the right sequence, no joy. That switch tells it ok to start, as well as ok to go in or out of 4 Lo.
  5. Sep 9, 2012 at 6:53 AM
    Straightshot
    Justin
    Utah
    2005, sr5
    ok thanks guys i can try it tonight when i get off work. I was trying it last night with the clutch ALL the way to the floor and the truck completly stoped then would try rollin forward/backwards sitting still. But didnt try it with the truck off. Could there be a problem in the actuator that wouldnt let it shift?
  6. Sep 9, 2012 at 7:15 AM
    Maticuno
    2011 Suburban 2500
    I could be wrong but I'm pretty sure if it's beeping that means something was done out of sequence. Did you switch straight into 4LO from 2HI or were you already in 4HI?
  7. Sep 9, 2012 at 7:18 AM
    Straightshot
    Justin
    Utah
    2005, sr5
    Was already in 4HI. The light would keep flashing along with the beep if that makes a difference.
  8. Sep 9, 2012 at 8:24 AM
    lipster
    Northern MN
    License plate frame
    I did not mean to imply the truck has to be off. Only that if you have it off, and are in a real quiet place, especially next to a wall, you can roll down your window and hear the actuators click and whirr, to see if you are doing it right.
    Yes, your actuator can be bad, and there is also a 4 WD computer module. I doubt if that is the issue though. I've had trouble when I first got mine as well. Has to be done in exactly the right sequence for 4 LO.
  9. Sep 9, 2012 at 8:32 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Pretty sure it's brake & clutch. Not just clutch.
  10. Sep 9, 2012 at 9:31 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Start by shifting into 4hi on the fly like you did. Then you have to be completely stopped and clutch floored, like when you start it. You have to get that part right BEFORE turning the switch to 4lo, if you are still moving a bit or don't have the clutch all the way down when turning the switch to 4lo, it won't retry until you cycle the 4wd switch back to 4hi, then 4lo again.
    The procedure is essentially the same for shifting back to 4hi.
    If that doesn't work, its possible the limit switch in the t-case actuator is faulty, possibly just dirty or gummed up from not being used. The motor in the actuator is fine if it shifts to 4hi. Search here for DIY on disassembly and cleaning.
  11. Sep 9, 2012 at 9:35 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I know for autos you have to be in neutral, maybe its the same for manual? Mine will beep at me if I try to put it in in gear. Perhaps that's what yours is doing too.
  12. Sep 9, 2012 at 9:42 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Mine won't go into 4lo as well, tried all the suggestions. 4hi is fine, I can hear it engage and disengage. I have the 6sp trans.
  13. Sep 9, 2012 at 9:45 AM
    Maticuno
    2011 Suburban 2500
    The only gear position that the manual transmission senses is reverse. Having the stick in neutral might help, but I don't think its necessary in this case.
  14. Sep 9, 2012 at 10:09 AM
    Straightshot
    Justin
    Utah
    2005, sr5
    Thanks everyone. Tonight when i get home I will keep playing with it and try some more. If all else fails my father inlaw is a mechanic and i'm sure he can help me clean it and check it out.
  15. Sep 9, 2012 at 10:28 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    The key is the truck being stopped. If the foot brake is on and the clutch depressed, the truck is stopped. For an automatic, neutral is the same as the clutch being depressed.
  16. Sep 9, 2012 at 1:45 PM
    benbacher
    Anchorage, AK
    So it's not worth trying in neutral?
  17. Sep 9, 2012 at 2:22 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    There are a couple of reasons why not. One is that there is no "neutral" switch. Second is there is a switch that detects the clutch being depressed.
    If it doesn't work, by all means try.
  18. Sep 9, 2012 at 7:26 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    does keep flashing mean the little green light on the dash was flashing when you were in 4hi? i had that same problem, ended up that i had no power to the front axle when trying 4x4 (which was impressive since i thought i had it and hit serious mud w/out getting stuck). i took it to a local repair shop, paid $50 for them to diagnose the no power thing, opted not to pay like $500 for them to fix it, and it started working on the way home.
    ive read in other threads that a lack of use causes the actuator to stick, you just have to smack it and keep trying to use it for it to fully engage
  19. Sep 9, 2012 at 7:56 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The actuators in the front end and T-case are shit. For some reason they collect condensation, which corrodes the terminals. You can take them apart and clean the sludge out, but if there is pitting present they won't last long. I ended up converting mine to a manual shift (hillbilly engineering method).
  20. Sep 10, 2012 at 4:46 PM
    Straightshot
    Justin
    Utah
    2005, sr5
    Looks like I will be braking into mine. I just spent the last 30 minutes trying everything possible and it still won't engage. Thanks for all of the help guys.
