4lo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbcs1987, Nov 26, 2008.
  1. Nov 26, 2008 at 10:58 AM
    cbcs1987
    cbcs1987 [OP] Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    When you guys put your trucks in 4 low does the truck start beeping inside? I'm new to this knob turning thing to engage 4wd so I didn't know.
    I'm putting the truck in neutral and going from 2 hi, then to 4 hi, then to 4 low. I've not actually used the truck in 4 low any, but just fooled around turning it on so i'll know how when time comes. It just seems like it shouldnt beep the entire time. That would get annoying
  2. Nov 26, 2008 at 11:00 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    If it's beeping, it hasn't properly engaged
  3. Nov 26, 2008 at 11:02 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    If you have a manual trans, make sure you push the clutch pedal in when putting it into 4 lo.
  4. Nov 26, 2008 at 11:26 AM
    javajunk-e
    javajunk-e Well-Known Member
    So. Cal
    '09, Super White, DC, LB, 4x4, SR5.
    Tacoma all weather floor mats, N-Fab Prerunner light bar w/ Hella 500ff lights, mag-lite mod, Hi-lift jack, Wet Okole seat covers, Revenge Fab sliders, ARE MX shell with Thule racks, and a Bed Rug.
    If it beeps you need to try it again. If you simply open your glove box take that booklet thingy out that is in there and read about how your 4 lo works it will tell ya! Don't mean to sound harsh...
  5. Nov 26, 2008 at 3:59 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    The owners manual helps with on hand training.
  6. Nov 29, 2008 at 7:50 AM
    cbcs1987
    Cody
    East Tennessee
    Thanks guys. Mine didn't come with a manual. The guy that I bought it from lost it. I figured it out though. thanks for the help
  7. Nov 29, 2008 at 9:07 PM
    news8000
    news8000 Active Member
    Southeast Manitoba, Canada
    06 Tacoma 4X4 Access Cab Stock
    ON STOCK UNIT: Rear Leaf TSB, Leer Cap w/ Windoors, Michelin LTX M/S on ION 133s, K&N Filter, Cruise, Python Command Start/Alarm, Toyota Class 5 Hitch, Metra IPod Adapter
    Put it in 4hi FIRST and make sure it's engaged i.e. the 4wd dash light stops blinking and stays solid ON. This often requires you be moving and baby the gas a bit. Once 4hi fully engaged, stop, put trans in neutral, and THEN switch to 4lo. There should be no more beeping and you can pull that semi out of the ditch.... :D
    Neil
  8. Nov 30, 2008 at 7:59 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    The beeping is stating you FAIL, please try again. My floormats were keeping me from depressing the clutch deep enough and I was getting the fail noise. :(
