4low to pull a bush out of the ground?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmgtp, Feb 17, 2016.
  1. Feb 17, 2016 at 11:31 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Alright, my turn to add to the redneck tree/bush removal thread
    Just cut them off at the base with a chain saw then put an old tire around the stump and set it on fire.
    Burns away to nothin.
  2. Feb 17, 2016 at 11:36 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Use a heavy Nylon strap, loop it around the trunk, gently get tension on the strap, and apply moderate throttle. It will come out like a rotten tooth.
    Beaglesridefree likes this.
  3. Feb 17, 2016 at 11:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    I pulled some decent shrubs last spring with a cheap cable come-a-long hooked to the hitch on the Highlander.
    Cranked the shrub with the Highlander just parked as an anchor for the come-a-long, chopped a few surface roots till the shrub started to tilt, then drove off, pulling it right out of the ground.
  4. Feb 17, 2016 at 11:53 AM
    iitywygms
    iitywygms Well-Known Member
    Norcal
    4x4
  5. Feb 17, 2016 at 12:05 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Another thing to do first is get a sprinkler or just use your hose and soak the base of the bushes for 20 minutes or longer depending if you have hard clay dirt or not. Softening the ground will help and shrubs should pull out easier.
    ColoradoTom and Clearwater Bill like this.
  6. Feb 17, 2016 at 12:16 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Its a bush for Christ sake. I pulled out bushes with my old 22RE.
  7. Feb 17, 2016 at 1:42 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    It is never a good idea to pull bushes out of the ground. So many things can go wrong.
    It is always a good idea to dig them out.
    Also, if the bushes are old and near the foundation I have heard of people damaging their foundation because the roots had merged into the foundation.
    Do not worry about some roots being left in the ground, they will just decompose. Get your shovel and spare your truck and possibly your life.
  8. Feb 17, 2016 at 1:50 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Yeah but what fun is digging it out when you rip it out with your truck !
    teamfast likes this.
  9. Feb 17, 2016 at 1:51 PM
    Nighthawk
    Levi
    Casper Wyoming
    All you have to do is dig down around the roots and tie low and tight. use a rope or a tow strap, ditch the chains and hooks. Not that dangerous and not that difficult.
  10. Feb 17, 2016 at 2:05 PM
    Pigpen
    Dan
    Northwest Montana
    The multiple leads were separate pretty much to the ground and I wasn't going to risk anything falling on the house. The whole tree was well within range of the house.
  11. Feb 17, 2016 at 2:12 PM
    devkurf
    devkurf Member at Large
    midwest
    I'll be the lone dissenter. If I had it to do again, I wouldn't.
    I cracked the front diff all the way around on my K1500 chevy pulling out a shrub next to my house. These were probably original to the house, and we were removing them to replace the sidewalk. Some of them were close to 6 inches around at the base about 5 ft high, with a spread of around 5 ft. I was able to pull several of them out then had to use some guerrilla tactics. I tried running the sawzall around the base into the dirt with a 10 inch blade thinking that should be enough.
    My first mistake was using reverse in 4 low. My second mistake was making it hop while spinning on the concrete . What finished her off was about a 5 ft run at full throttle.
  12. Feb 17, 2016 at 2:25 PM
    Pigpen
    Dan
    Northwest Montana
    No, you were doing it right :thumbsup:
  13. Feb 17, 2016 at 4:05 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Did the same thing to a loaded semi and it pulled it easily. The driver couldn't believe it when he started moving.
  14. Feb 17, 2016 at 4:54 PM
    tacoparadise
    tacoparadise Well-Known Member
    2012 tacoma 4x4
  15. Feb 17, 2016 at 5:01 PM
    #35
    tacoparadise
    2012 tacoma 4x4
    you know it will pull anything if the tow mirrors are out!:rofl::rofl::rofl:
  16. Feb 17, 2016 at 5:04 PM
    #36
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hate to tell you this but Tacoma's have CV joints.
  17. Feb 17, 2016 at 5:05 PM
    #37
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Gotcha
  18. Feb 17, 2016 at 5:06 PM
    #38
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Note to self cut the tree first.
  19. Feb 17, 2016 at 5:34 PM
    #39
    Pigpen
    Dan
    Northwest Montana
    Back to the bushes, I'd get to it with a shovel and an ax first, if they're old plants. Their roots can be surprisingly strong.
  20. Feb 17, 2016 at 5:37 PM
    #40
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    I'm sorry for your loss. :oops:
    Gonna say something here, and just keep in mind I'm ancient. Like, almost 53. But here's the thing:
    When you're in 4wd doing whatever. Getting yourself unstuck. Towing somebody else out. Pulling a stump. Whatever...
    Go easy on the throttle. Some big time physics are going on when you throw a bunch of hydrocarbon into a modern internal combustion engine. Things break, things go wrong. The motors were designed more for getting you onto the onramp and merging than for 4-wheeling or doing tractor functions (like the old time 4-wheelers were).
    When you're doing one of these stupid things with your truck, go all Andy Taylor. Be mellow. Try some throttle, see how it goes. If a little power doesn't start making everything good again, a whole bunch more may not either. You just might break something. Use your brain meat.
    If I'm in 4lo, I'd say I never apply more than about 1/3 throttle. When you're running that low a gear ratio, the ft lbs of force that are being applied at the wheels even at 1700 rpm with quarter throttle are pretty impressive. Use that power carefully.
    To the OP: If I was doing this with my truck today, I would give it a little tug and see what happens. If it starts to pull out and you hear roots ripping, tug a little more. If it's set in the ground like a telephone pole and doesn't even move, start digging a little. Dig some, tug some. Dig some, tug some. The advice previously about getting the root ball wet seems pretty smart. Makes digging easier too.
    Beaglesridefree and tacoparadise like this.
