4low to pull a bush out of the ground?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmgtp, Feb 17, 2016.
  1. Feb 17, 2016 at 5:47 PM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    StevoNB and tacoparadise like this.
  2. Feb 18, 2016 at 5:02 AM
    #42
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    He does a better job than some of the guys clearing the side of the roads in NB! There are several outfits in northern New England that do clearing with a big flail. Personally if I can't pull up brush with my tractor bucket and a chain it gets cut with the chain saw.
  3. Feb 18, 2016 at 5:10 AM
    #43
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    A friend cracked the frame on his Jeep pulling out a shrub. It's one thing to pull something that rolls, and totally another to attempt to pull something that is a fixed object. Remember that what you above the ground is only 1/3 of the big picture.
    NeedmoreTaco likes this.
  4. Feb 18, 2016 at 2:54 PM
    #44
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it won't pull it don't take a running start.
    Pigpen likes this.
  5. Feb 18, 2016 at 3:08 PM
    #45
    LinBaba
    LinBaba Active Member
    Andrew
    2012 Toyota Tacoma White TRD Sport
    Pshaw just pull em out, I used my old 4 banger on all these image.jpgimage.jpgimage.jpgimage.jpg
    Pigpen likes this.
  6. Feb 18, 2016 at 3:13 PM
    #46
    LinBaba
    Andrew
    Truthfully listen to the old guys that say don't yank, we pull -small- stumps out with pickup trucks all the time, larger stumps we grind (that machine weighs 8000 lbs)
    Pigpen likes this.
  7. Feb 18, 2016 at 3:55 PM
    #47
    imageomega
    imageomega Well-Known Member
    Jarrod
    After reading 3 pages of... sarcasm/Toolman Taylor/actual knowledge/fake knowledge/hilarity, this is closest to where I stand. Try it. Try it cautiously and with your brain. And if its not working, dont force it.
    Beaglesridefree and LinBaba like this.
  8. Feb 18, 2016 at 4:00 PM
    #48
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I've used my truck to pull a number of root balls out of the ground, no ill effect, and always using 4 low and judicious throttle control.
  9. Feb 18, 2016 at 4:12 PM
    #49
    OZ-T
    Peter North
    British Columbia
    That last pic is a pretty quick growing tree , what species ? Coastal Redwood ?
  10. Feb 18, 2016 at 4:31 PM
    #50
    LinBaba
    Andrew
    The last pictures is a Monterey Pine, the second picture is a coastal redwood
  11. Feb 18, 2016 at 4:32 PM
    #51
    OZ-T
    Peter North
    British Columbia
    Huh , wide growth rings
  12. Feb 18, 2016 at 7:05 PM
    #52
    LinBaba
    Andrew
    Indicate wet years in this instance
    It was a big tree, we charged $12,500 to remove it, took 2.5 days
  13. Feb 18, 2016 at 7:06 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Oh yeah , I know how it works , they are just consistenly wide from the core out , I was just wondering the species
  14. Feb 18, 2016 at 8:59 PM
    #54
    Pigpen
    Dan
    Northwest Montana
    Is there a market for the wood once you've removed it?
  15. Feb 18, 2016 at 9:21 PM
    #55
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    Use a tow strap damper in case it breaks.
  16. Feb 18, 2016 at 11:06 PM
    #56
    LinBaba
    Andrew
    Redwood or cypress yeah
    Pine and Euc not so much
  17. Feb 19, 2016 at 10:38 AM
    #57
    jmgtp
    jmgtp [OP] Well-Known Member
    2013 2.7 4x4 5sp
    None
    Not in the driveshaft - at least not mine. All u-joints. The Dakota has a CV shaft in the front driveshaft, which is what failed.
    Only CV joints in my drivetrain are on the front half shafts, where they belong. Not in the driveshafts.
  18. Feb 19, 2016 at 10:45 AM
    #58
    jmgtp
    2013 2.7 4x4 5sp
    None
    This thread got popular since the last time I visited! I won't be pulling any bushes until the snow is gone. But this is the rootball of the bush that fought my Dakota, it might not look like much but it broke traction in 4 low trying to remove it. We had to cut roots, clear with the pick and then finally pluck it out with the truck. That dirt patch in front of it is from another one we had pulled out image.jpg
  19. Feb 19, 2016 at 4:12 PM
    #59
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well you have a CV or if you prefer a constant velocity joint on your drive shaft it is a double cardan joint it's just not made with ball bearings. Dodge has a live axle it has to have more drive shaft movement the CV was a perfect answer to the problem. The ball type CV joint is actually stronger because of the larger surface area.
  20. Feb 19, 2016 at 6:00 PM
    #60
    tacoparadise
    tacoparadise Well-Known Member
    2012 tacoma 4x4
    :rofl: rootballs can be deceiving.
    I would shorten the strap though.
    This will help with upward pull, while also providing a downward force on the truck.:thumbsup:
